Results 1 to 5 of 5
    180mm rear disc racer X frame, will it fit?
    Can i run 180mm disc at the rear on my racer x frame?
    Brought some brakes said they were 160mm turns out there 180mm wondering if i should send them back or not.
    Joel
    Follow me on Twitter @OnOneCarbon456
    Hi I'am an On-One Carbon 456 mountain bike, follow me to find out what i get up to...
    Send them back. If it fits or not, that bike is not designed for a 180 rear brake.
    Quote Originally Posted by sclyde2 View Post
    What will be the consequence of running a bigger disc?
    Bigger rotor = Better braking for heavy downhills
    No downside except more weight.
    Given the likely purpose of the bike, i doubt you'll benefit from it.
    The rotor could hit the chainstay. You should be able to tell be looking at it with a rotor on it.
    Given that you have the option of sending it back...
    Happy Trails
    Reputation: Scott In MD's Avatar
    I have 180mm on my RX29 for several years now. No problem. But I agree that you should set it up 160mm like it is supposed to be set up. There's not a whole lot of clearance ... About 2mm.
  1. 180mm Disc with Carver Carbon Fork Creaking
    By Dooms101 in forum 29er Bikes
    Last Post: 04-09-2013, 04:47 PM
  2. 180mm rear disc on a Big Top, why not?
    By big err in forum Yeti
    Last Post: 08-27-2012, 07:42 PM
  3. SLX 180mm front/160mm rear...rear has more power??
    By Bryank930 in forum Brake Time
    Last Post: 03-09-2011, 10:15 AM
  4. adding rear disc to older steel frame- custom welding
    By 2silent in forum Frame Building
    Last Post: 02-22-2011, 06:57 PM
  5. Rear mounted sidestand for disc frame..
    By DougGuy in forum Cannondale
    Last Post: 02-20-2011, 09:16 AM
