Results 1 to 3 of 3
    Reputation: abikerider's Avatar
    Problems with new shimano shadow derailleurs on older 2000 ECDM tandem
    Has anyone else found that their old design ECDM with rear facing dropouts doesn't work very well with the shadow derailleurs. The shadows all seem to have this humpback near the derailleur mounting bolt that interferes with rear wheel removal. See the attached picture. I am tempted to grind the humpback down but it might serve an important function. Anyone else run into this problem?Name:  SLX 9 speed derailleur.JPG
    Well I went ahead and ground down some of the hump and am now able to take the wheel on and off so the problem is solved. I didn't have to take too much off so I'm pretty sure I have not compromised the strength. I hope this is useful to others.
    Problems with new shimano shadow derailleurs on older 2000 ECDM tandem-shadow-derailleur-mod-2.jpg
    Problems with new shimano shadow derailleurs on older 2000 ECDM tandem-shadow-derialleur-mod.jpg
    the ECDM 29er is tough to get the rear wheel off with a 2.3 or so sized tire on the rear. The chainstay yoke hits. I've let some air out of the tire to make mounting easier.
    2 wheels == True
  1. Help with identifying some mounts/tabs/ect. on an older Lippy tandem frame
    By Andy FitzGibbon in forum Tandem Mountain Bikes
    Last Post: 06-08-2015, 04:50 AM
  2. xtr shadow plus alignment problems
    By Ntrdr00 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-25-2012, 10:20 AM
  3. Shimano Shadow +
    By DJ/UF in forum All Mountain
    Last Post: 08-27-2012, 02:37 PM
  4. b-screw adjustment on Shadow derailleurs
    By JonathanGennick in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-16-2012, 12:01 PM
  5. Tandem ECDM / Single Bike Question.
    By PMK in forum Ventana
    Last Post: 03-09-2011, 05:45 PM
