Results 1 to 22 of 22
    K&K
    Reputation: ki5ka's Avatar
    Powerlink failure
    Powerlink failure
    Sram 9 spd powerlink on a Sram 9 spd chain.
    I recently removed the chain (drive chain, not timing) for maintenance, but we have ridden it since and considering that the chain will not seat if the link hasn't locked into place I don't think that is the cause.
    We ARE having issues dropping the chain off the small ring and jamming it between the BB and crank. Seems likely this caused the failure, but an examination of the half of the link we recovered shows no failure or deformation leading me to ponder other possibilities. Of course, the other half might be trashed and I wouldn't know...
    I have the impression that Powerlinks have a stellar reputation. Am I correct? Anyone else have a failure story? Kinda seems like a new poll is brewing
    Have been running bottom-rung SRAM 951 chains for over 7 years and have never had a PL failure. Have broken drive chains two or three times and finished the rides with a second PL. Also have two PLs in our sync chain at all times.
    There can be damage done to the chain in the BB/crank cavity via a ring bolt coming around. Some work with the Low limit screw on the FD should cure that for the most part. We have that occur rarely, and usually we can catch it and backpedal to reseat the chain.
    K&K
    Quote Originally Posted by Okayfine View Post
    Your experinece matches ours. This is our first PL failure, and have similarly had chain failures on other links. Failure to keep the chain out of the BB is the cause I expect to confirm.
    Thanks for the input.
    k
    PMK
    PMK is offline
    Reputation: PMK's Avatar
    Not Jinxing us...
    PK
    Reps! We don't need no stickin' reps!
    Timely thread. We just blew apart a sram 9sp drive chain last weekend. On a very rough section of trail coming out of a roller at speed and hitting some big roots, I made a bad shift and the chain sounded like a gun shot as it exploded at the powerlink. It took about 2 min to fix with a new conex quik link.
    That's the first I've ever broken a quick link. I didn't think twice about it and just assumed the torque and stress of the tandem was too much.
    Sep 2004
    Just picked up a spare today never know...
    Whenever I change chains I keep the old PL and put it in my pack. If you have a spare, you're guaranteed not to need it on the trail, but someone else might. I've given two away.
    Sep 2004
    Talking about chains how many miles should I get out of them before replacing them??
    Impossible to specify. 6-months to years, depending.
    Best practice is to check with a ruler over 12", pin to pin, and replace when necessary. The more wear you run, the more you wear your chain rings and cassette, and only chains are cheap. I generally change the drive chain 1-2 times a year, depending on how much we are riding, and the sync chain every 2-3 years. But we're a heavier team and have a lot of hills. Lighter teams running the flats (our Burley road tandem, for example) could extend that kind of service for much, much longer.
    K&K
    OK, had another Powerlink fall off. I know that on a tandem, shifting is a whole new world... making this a post for here, rather than elsewhere. I'm going to do a poll.. but I don't feel like doing it now, so just watch out for it, OK?
    K&K
    I don't even know what to ask. Did your powerlink fail? That wouldn't be very useful information. Any ideas?
    Quote Originally Posted by ki5ka View Post
    I've ham-fisted enough shifts over the years, still have not had an issue with the PL.
    Reputation: reamer41's Avatar
    Been using the power links for years. 12, maybe longer. Never had a problem.
    Well I've had some problems, but not involving a powerlink.
    --Reamer
    SC Tallboy LTc
    Ventana ECDM 26
    ventana el Ciclon
    Litespeed Classic
    Seven Ti Axion Tandem
    1989 Stumpjumper
    PMK
    PMK is offline
    Poll or not, without jinxing us, we have had excellent results with high SRAM chains and PL.
    We have witnessed some snapped chains, and other driveline issues. As you mentioned, the tandem is a bit different when shifting. Watching others, they would not anticipate a climb, or would mash the pedals to get over stuff and boom, broken chain. Others seem to prefer running dry lubes and I suspect they simply wear out the chain and it fails.
    Higher rpm, anticipate the upcoming feature, and ensure the chain is lubricated. Outside of that, Rohloff that does not bend the chain and will shift while coasting and not pedaling.
    Also, on a full suspension machine, it is imperative that the cables can flex enough to prevent ghost shifts. If in doubt run a full outer housing.
    PK
    K&K
    It's weird, they haven't broken, just fallen off. Usually during a bad shift under high load. Thought it had to do with the chain getting damaged from when it dropped into the bb, but have since fixed that problem and still had it happen. Saw something about installing a Powerlink "backwards" but I don't think the 9 speed is directional, as far as I can tell. No arrows on mine.
    Reputation: DHMASTER's Avatar
    Oct 2010
    "I recently removed the chain (drive chain, not timing) for maintenance, but we have ridden it since and considering that the chain will not seat if the link hasn't locked into place I don't think that is the cause. "
    The only time that I've see this type of failure is when the links are not fully seated before shifting under load. Unseated links can pass through without binding, pedaling or on a stand. I have found that all of my current powerlinks need to be fully loaded full weight to make them pop/ seat into their final resting place. If you did not put full standing weight on that link (with intent of seating it) prior to the mishap, I propose that this could be the issue.
    DW-DHR,VPX,SLX,SX,Stump Jumper ht.,Specialist, Bicycle Fabrications DH Tandem,Gravity Bike,Bamboo 29rs,Profile Uni,Renovo R4.
    K&K
    Quote Originally Posted by DHMASTER View Post
    DH, that makes good sense. Have you had this happen; a Powerlink fall off?
    Our regular ride has many demanding climbs which we routinely stand on. I can't imagine that we didn't do so many times before this PL "fell off". Of course, I could be wrong, that is the rub, isn't it?! I also have looked pretty carefully at the link before riding, since we HAVE had issues, and it LOOKED like it was fully seated.
    May 2014
    Had this happen to me today, on a pc951. One of the pins on the powerlink was ejected. I ended up losing it and walking back. Not that I could have fixed it even if I had the tools and no spare powerlink. The days before I had lots of shifting problems and chain drops. Just before the incident I was in small gears torquing for speed on some smooth sections.
    Not sure If I should just buy a new chain, or look to get some spare powerlinks. I have less the 500 miles on the chain/bike.
    K&K
    It seems there is always some time beforehand where things get wonky. I'm getting to the point where I know it's going to happen before it does. I think that means it has happened a lot!
    Reputation: switchbacktrog's Avatar
    May 2013
    Quote Originally Posted by jokaankit View Post
    I've never managed to get much more than 350 miles from a tandem primary chain before it's beyond the 0.75% stretch limit. I always carry spare powerlinks though, and only ever used them on someone else's bike.
    Quote Originally Posted by switchbacktrog View Post
    Same.
    When I put a new chain on the tandem, I keep the PLs and put them in my pack. I have half a dozen or more.
    Also keep in mind that SRAM chain quality can vary (as can any manufacturer). There was a spat of chains a few years back that regularly broke. Then a new batch came out and they were as tough as ever. If your chains/PLs that you're having trouble with were ordered at the same time (I buy in batches, maybe others do as well) then that could be another reason. The PL, in particular, isn't prone to problems IME.
    It just occurred to me that I've been using KNC chains and their power links for a few years.
    Before that used SRAM for many years. No troubles with either
    --Reamer
    SC Tallboy LTc
    Ventana ECDM 26
    ventana el Ciclon
    Litespeed Classic
    1989 Stumpjumper
  1. SRAM powerlink is stuck, Help.
    By dochou in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-18-2012, 03:46 PM
  2. Help with Chain/Powerlink
    By hankscorpio in forum Beginner's Corner
    Last Post: 09-09-2012, 06:01 AM
  3. SRAM powerlink
    By captnpenguin in forum Singlespeed
    Last Post: 08-09-2012, 06:39 AM
  4. SRAM 10-spd Powerlink on a KMC chain?
    By TiGeo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-16-2012, 02:18 PM
  5. sram powerlink
    By Eric Z in forum Beginner's Corner
    Last Post: 07-15-2011, 07:29 PM
