Results 1 to 14 of 14
    Reputation: XC Mike's Avatar
    Sep 2004
    Let's talk 20mm front wheels....
    With my fork coming from Alex on Monday I need to find / build a front wheel at this time I'm just looking to get a front wheel but I do have plans for rear disc down the road.
    Team weight under 270lbs
    my guess most of you run 36-40H so looking for a front hub that won't cost me big bucks I found on ebay a 36H SHIMANO XT 20MM CENTERLOCK DISC HUB anyone use these?
    I'm also looking on Pikebike and my local CL to find a Freeride wheel that would work anybody using 32H wheels?
    Thanks Guys
    Reputation: ds2199's Avatar
    Quote Originally Posted by XC Mike View Post
    Thanks Guys
    A well built 32h will work fine for your team weight. We are actually running a 32h on our 29er front wheel. I generally run 36h front and rear, but running a Maverick fork, and it so happens that the Maverick hub is 32h. Long story, but it works.
    I have a wheelset that I would sell for a reasonable price. They are White Industries hubs 36h laced to Velocity Chucker rims. Nice wheels, but we sold our 26" tandem.
    Sep 2004
    Quote Originally Posted by ds2199 View Post
    Cool pm sent
    PMK
    PMK is offline
    Reputation: PMK's Avatar
    I would not go centerlock if avoidable. Stay with 6 bolts stuff.
    What fork are you getting and why?
    PK
    Reps! We don't need no stickin' reps!
    Sep 2004
    Quote Originally Posted by PMK View Post
    PK
    Hi Paul
    I went with the Marzocchi 55 R that Alex had it's the 120mm
    I'm hoping that the 120 doesn't lift the front to much if it does I have a buddy that has a Enduro that wants it and I will just pick up the DJ that he has.........
    You may notice the lift (and change in steering feel) going from a rigid fork to the 120mm, if your frame isn't corrected for a 100mm fork. You probably won't notice the difference between 100mm and 120mm on a tandem, and the sag you set will take care of most of that anyway.
    Sep 2004
    Quote Originally Posted by Okayfine View Post
    Yup that's what I was thinking.......I can't wait to get it all together now
    PMK
    PMK is offline
    Hi Paul
    I did not realize that Marzocchi offered a short fork.
    I did give a quick look of their site, but didn't see a 120mm listed. Do you have any more details?
    Most Marzocchi's are pretty easy to reduce travel on.
    For us, when we owned the 2001 Cannondale, I had a Manitou Sherman with adjustable travel. I believe but may be wrong that it was a 110 / 150 range. I never came to terms with the longer fork, not bad when turning wide radius turns. Tighter turns had a noticeable point where wheel flop occurred and required some effort to maintain or recover.
    PK
    Sep 2004
    From what Alex told me they did a special run of 55 R forks in the 120mm for MTB Tandems
    Been there, do that
    Sep 2004
    So Paul how do you reduce it down even more I'm not sure if this fork comes with any spacers that can be moved around.
    I checked around on the web site they don't have much info on them in the Tech section
    PMK
    PMK is offline
    Mike, honestly I have never been inside a 55 that I recall.
    When you get the fork, upload a readable copy of the parts breakdown page. Normally I'll fabricate a spacer in the desired length.
    I'm guessing that this is what was involved in the MTBTandems version. Possibly Alex had Marzocchi USA install a second negative spring, or a spacer.
    BTW, from my tandem experience, it works better to not let the sag / preload be soft to lower the front. Limit the travel exactly where you want it, then run additional preload to give the bike chassis better feel and less wallow.
    Our Fox 40 is this way and the bike is planted and easy to pedal. The difficulty is installing the fork cap with the spring fight you.
    As a comparison, consider two motorcycles. One a lightweight long travel performance MX bike, the other a performance street bike such as a 1000cc sport bike.
    If the sport bike ran light preload, soft suspension like an MX bike it wouldn't work well. If the MX bike ran the firmer more preloaded setup of the sport bike it would deflect off everything. Granted, we ride off-road, however the forks we run are designed as single rider loads similar to the MX bike. For a tandem, a happy medium seems to work well for us. Run a spring RATE that is reasonable, but run a lot more preload than seems good. The combination will offer a rate to use full travel with minimal or no harshness, but the preload will keep the front tire planted and limit dive under braking, when "dropping in", or backside of logovers. Also, if you have ever experienced headshake on a vehicle, it will minimize the chance of that. Headshake on a tandem is real sketchy, the frame acts like a bullwhip...hang on honey.
    PK
    Reputation: 4slomo's Avatar
    XC Mike,
    I tried to respond to your PM, but apparently your profile is set up to not receive PMs. PM me your email address if you're interested.
    Hey everybody, ride my wheels! They ride good, real good.
    I'm a wheel builder. SRLPE Wheel Works. Send me a PM.
    PMK
    PMK is offline
    Quote Originally Posted by 4slomo View Post
    XC Mike,
    Shoot me a quote
    Rear wheel only
    DT 540 6 bolt IS disc hub,36 hole, 145mm
    Velocity B43 rim, black
    DT alpine triple butted spokes, brass nipples
    Laced 3 cross, with left and right inner spokes following direction of rotation and outer spokes into direction of rotation.
    Tension max rated per Velocity,
    PK
