Results 1 to 2 of 2
    Apr 2013
    Hope Pro2 Evo hub adjustment....
    Is there a way to adjust these things?? I don't see that there is, but the front hub has a tiny amount of play, even with the skewer is set on the tight side....
    Tandem content: It's on my Fandango.
    Any input?
    MR
    Apr 2013
    In case anyone was wondering....via Alex N I received this reply from Phil Dean at Hope:
    "Do the bearing's fit tightly in the hub and the 15mm end's in the bearing's? Do you have access to another fork with a 15mm axle you can try the wheel in to see if it's not just an undersized 15mm through axle?
    We have had people report this issue only to find there is an issue with the through axle. Also if you squeeze the fork leg's together then tighten the axle does that help?"
    So, no adjustment on these hubs....I haven't pulled the axle to mic the precise size yet, but I will do so.
  1. Hope Pro2 Evo to WTB i23 29er
    By TR in forum Wheels and Tires
    Last Post: 08-18-2013, 12:55 AM
  2. Hope Pro2 Evo XX1 X12 conversion
    By TANK01 in forum Wheels and Tires
    Last Post: 03-20-2013, 10:14 AM
  3. Hope pro2 hub rear
    By vince7870 in forum Wheels and Tires
    Last Post: 10-07-2012, 11:10 PM
  4. Hope Pro2 Evo SS Conversion
    By irv_usc in forum Wheels and Tires
    Last Post: 06-04-2012, 04:30 PM
  5. Hope Pro2 10mm Conversion, which on?
    By thrasher_s in forum Wheels and Tires
    Last Post: 02-16-2011, 04:16 PM
