Results 1 to 9 of 9
    Fork question. Niner carbon or RS Pike.
    I've been noodling about a Fandango tandem, and the fork is one of my questions.
    Anyone have any experience with a carbon rigid fork on a tandem? The Niner RDO has a 15mm thru axle and a theoretical "no rider limit". I'm sure the forces of a tandem are different than a normal bike with a 300lb rider, but are they THAT much different? I shot them an email, but I'm expecting a "no tandems" response.
    If we were to go with a suspension fork, I would think a RS Pike would be a good choice. I don't see many threads about that. Is that because of the price? It's a bomber fork on my enduro bike and it's put up with some amazing hits. The kind of riding we do on a tandem would probably put up less force With the dual position Pike, I can run 120mm, so the travel isn't an issue.
    Reputation: switchbacktrog's Avatar
    May 2013
    There's a thread here that talks about the Pike....................ECDM Geometry
    If you have any specific questions, I may be able to answer them as I have the Pike fitted.
    You can get the Pike travel reduced by replacing the air shaft, so there's no need to go for the more expensive duel height fork.
    Any response from Niner? I am considering a 29+ tandem build.
    "The fork will explode and you will die" So basically no go.
    If we do this, I'll do a 120mm Pike on a Salsa Powderkeg.
    Reputation: ds2199's Avatar
    Quote Originally Posted by trhoppe View Post
    Seriously? Sounds pretty dramatic.
    Tom, you can do much better than the Salsa Powderkeg.....
    Quote Originally Posted by mhopton View Post
    Uh Oh... Don't start that again!
    Sep 2004
    X2 Fandango's The Best....F___ The Rest...
  1. Niner carbon fork axle question
    By MadMacMan in forum Niner Bikes
    Last Post: 12-22-2014, 09:47 PM
  2. Niner RIP 9 RDO Frame + Rock Shox Pike fork
    By rjkowski in forum Where are the Best Deals?
    Last Post: 12-14-2014, 08:14 PM
  3. Niner rigid carbon fork question
    By BigwheelsRbest in forum Niner Bikes
    Last Post: 04-10-2012, 01:10 PM
  4. Another Niner carbon fork question
    By evoracer in forum 29er Bikes
    Last Post: 12-13-2011, 10:55 AM
  5. niner carbon fork and cane creek question?
    By nicolicious in forum 29er Bikes
    Last Post: 02-13-2011, 10:37 AM
