Page 13 of 19 FirstFirst ... 3 9 10 11 12 13 14 15 16 17 ... LastLast
Results 301 to 325 of 452
Thread: The ECDM thread
  1. #301
    Jun 2010
    I'm probably telling you things you've already tried and are aware of but here goes. If its a threaded adapter the threads are left handed as I recall. Lefty tighty, righty loosey. Also put the flat spots on the adapter locked in a bench vise and use the rim to turn it off.Don' t forget to loosen the allen set screw if you used it on the adapter. I had one on a Rolf road set that was a PITA but eventually got it off. Since I dont use the set screw I very lightly use an anti sieze compound on the threads. Did I mention only a very little? You do Not want that stuff on any of you stopping parts!
    Good Luck!
    Ed and Pat Gifford
    the Snot Rocket tandem
  2. #302
    On my hub, the adapter is splined (slides on) with 3 retaining screws. I got it to pop off this morning with tapping via soft blow and then gentle prying with a cone wrench.
    It's a nice and sturdy hub with the steel freehub. I would greatly prefer a modern 142x12 setup to having to use "fun bolts." It's a topic for another thread though.
    2 wheels == True
  3. #303
    Why did Ventana raise the BB height on the 29er version 1.5" over the 26er version. Looks like they took the 26er and slapped on a longer rear end, adjusted the head angle, and called it good. I'm not complaining about the 29er, just noting the 15"+ BB height. It works really well through rock gardens. A real monster truck!
    2 wheels == True
  4. #304
    Oct 2010
    Could it simply be the difference in wheel size? Twenty nine minus 26 equals a three inches difference in diameter. Divide three inches by two and you get an one and a half inch difference in the radius and the height of the bike.
  5. #305
    Yes, that is what I was thinking. So if 13.5" was a good tried and true BB height, why didn't Ventana adjust the frame geometry on the 29er to get the BB height lower?
    2 wheels == True
  6. #306
    It's not only the wheel size, I asked Ventana directly and they said it was to give better clearance in real technical terrain. I'm also a little confuse because on the 26 they LOWERED the bottom bracket height between first appearance (in the 20th century !) and today's ECDM 26 tandems.
    The VERY high bottom bracket height on the 29 restrained me from buying it, I've already posted a question on this thread to know 29 inches tandem riders about their point of view and it seems it doesn't bother them. But still hesitating....
  7. #307
    The high BB is working fine for us. We do ride it on technical terrain, like Sedona, AZ and rockier trails around Boulder, CO. The high BB has made it so we can drop of ledges I didn't think were rideable. If I were riding less technical trails of a place like those of bay area Northern California I would be happier with the lower BB.
    Yesterday, the smooth and twisty trails of Eagle, CO were fun on the ECDM 29er but a little lower BB could likely rail around the turns a bit better.
    2 wheels == True
  8. #308
    Ultra Ventanaphile
    Dec 2001
    EB, not sure which forks Ventana was using for the specs, but it looks like they adjusted the geometry for 120mm 29'er forks. So that could explain the BB height increase.
    A2C given is 518mm which is akin to Fox's F29@120mm.
    -Aaron G.
    "Before D.W., "anti-squat" was referred to as pedal feedback."
  9. #309
    looks like I'm using a 140mm fork which would explain the height. The fork was supposed to be travel reduced down to 120mm when I got it from my brother. Guess I'll have to do that myself! It makes sense now that I've had to push my seat forward on the rails to get the seat angle to feel right. We used to use a 110mm on the bike and the geometry felt very good for climbing and general XC. 120mm will be good all around.
    2 wheels == True
  10. #310
    Am pondering getting back into a tandem. I had a Santana road back in the mid 90's, then a Santana mtn in the late 90's set up with a child stoker for my then very young son. Long since sold but on the wrong side of age 50 now I really need to get back riding. Pavement blows here in LA so dirt is the only viable option unless I want to get run off the road by some driver on his/her cell phone. My wife happily rides on the back of our GS motorcycle, so I figure she'll be ideal as a stoker (unlike my ex-wife who really didn't like the idea - there's a story or three there).
    At any rate, looking at Fandango DC-9 or a Ventana build. Mostly seems to be a question of DS or not. I'm thinking we'll be mostly fire road and probably some pavement (unavoidable). That seems to lean towards the DC-9 but comfort is king for an aging body.
    Advice/pushes either direction happily read. For ECDM there is the 26 vs 29 question as well. I'm 6'1" so taller bike isn't an issue.
  11. #311
    Quote Originally Posted by ybtodd View Post
    Hey Todd, we are pretty new to the tandem scene with only a few weeks on our mostly stock DC9 from Alex (mtbtandems.com). My stoker is pretty happy with the Thudbuster rear suspension as it gives a fair amount of flex for her. However, you should pick up the phone and call Alex and discuss the pros/cons - he'll point you in the right direction. Whatever you choose, just do it! It's a blast and you won't look back!
  12. #312
    Jun 2010
    Hi Todd,
    Pat and I have owned both a Fandango 26er and a Ventana ECDM 26er.We have ridden a Fandango 29er also. From the captains perspective I did not find any difference in the two 26er tandems as the ECDM and FandangoDC9 were set up exactly the same from Alex. Pat rode the thudbuster for a while and seemed pretty content until we had the oppertunity to ride a friends ECDM thru some rock gardens we had just completed on the Fandango. Her immediate response was "we are getting one of these!" Who am I to argue! Having owned the Ventana for a couple of years now I would say its the most comfortable and versatile choice. We also rode the Fandango 29er and my opinion is if you are after a XC type race bike than that would be my choice. I haven't ridden the 29er ECDM but there are a few owners of them on here. Whatever your choice Alex will provide plenty of honest information and a quality build at a reasonable price. Having a willing stoker will make the experience even more enjoyable. Good luck and let us know what you decide.
    Ed and Pat Gifford
  13. #313
    PMK
    PMK is offline
    Reputation: PMK's Avatar
    We have owned both.
    The ECDM 26 is capable of some pretty stupid fast speeds when gravity helps.
    Our Fandango was great at XC, but got unsettled at higher speeds on rough terrain.
    Jeanne rode a Thudbuster LT for many miles also.
    Like Ed and Pat, comfort and injuries was a reason for selling the Fandango. We loved it and did not want to sell it.
    We now enjoy the ECDM for all of our off-road tandeming.
    As for the 26 vs 29 choice. I still to this day have never had the front end tracking confidence in a 29, whether single or tandem that a properly setup 26 provides. Our ECDM is a 26. I'm being picky, but it is something I do notice at times other than straight ahead.
    PK
    Reps! We don't need no stickin' reps!
  14. #314
    Thanks for the replies - good to get feedback. Since I come from old school (most of my racing miles were full rigid - hey you kids, get off my lawn!), I'm comfortable with 26" and feel like on a tandem it probably is a stronger wheel with less flex relative to a 29". I've never been a fan of suspension seat posts as the distance/angle to the pedal changes and that gives my knees fits. My wife has younger knees but she's starting to feel some wear and tear from running.
    Sounds like I'm talking myself into an ECDM in 26". I need to spend some time on the new single I'm getting to make sure my knees/back are up for this, but I suspect that is the right course of action. Now just a question of cosmic orange or mango tango :-D
  15. #315
    PMK
    PMK is offline
    The Thudbuster LT is not bad in regards to movement if, like a suspension fork or shock, it is setup properly.
    The key is to install the proper elastomer stack combination AND to set the preload for very slight sag.
    Once set, the movement is minor until needed.
    This may take a little bit of test riding, plus don't forget that with each preload change a seat height adjustment is needed.
    As for a suspension bike, well, they work well for different reasons.
    Both setups can be very good.
    In regards to wheels. For me it was more the frame geometry of 26 vs 29 than wheel flex. Properly built 29 wheels are very strong and work fine on a tandem and have minimal weight penalty.
    I would add that in regards to flex, the ECDM rear frame has more flex than the 29 wheel when comparing our ECDM vs our previous, and loved Fandango. The suspension does make this less noticed.
    Recently we did a group ride on very technical sandy rooted singletrack. Some sections required the steering to full lock to navigate while others were very fast and swoopy. A longtime friend who had not ridden with us on the ECDM commented how much we flexed the ECDM frame.
    Everything is a compromise...
    PK
  16. #316
    So far so good with the back-on-the-bike experiment. Actually I feared it was over before it started as I managed to tweak my lower back hopping off the bike after doing some cockpit adjustments right after picking up the bike (a FS Salsa). After ice, meds, and a good dose of feeling sorry for myself a friend reminded me that often when his back goes out there are two things that feel good - lying down and riding. So Sunday I decided to do a spin down to the beach with the wife. Today I can still walk (actually back feels better) so full speed ahead with the tandem plans. Even after a short ride I know I'm sold on FS so really is a question of wheel size. In looking at the geometry I'm sort of between a 19 and a 21 (based on TT length). But things change with the wheel sizes so seems that it would be a 21/16 in 26" wheel or a 19/16 in 29" wheel with stem dealing with the TT differences. That is based on captain standover which iirc is important off-road.
    Any compelling arguments for 26 vs 29? While 29 is the new standard I don't see 26 going completely away any time soon.
  17. #317
    26" forks and wheels are a deal now and likely will be a for a while. I would expect the DH oriented 26" wheel stuff will be around for a good number of years still. I've heard the more XC/trail oriented 26" forks/wheels are going to be produced less in the near term with manufacturers pushing to 27.5" wheels as the alternative.
    2 wheels == True
  18. #318
    Reputation: ds2199's Avatar
    I'm probably going to regret getting sucked into the 26 vs. 29 debate, but I will add my .02 cents. As former owner of a 26" wheeled ECDM and a current owner of a Fandango 29 and a ECDM 29, I'll say that I am sold on the 29" platform for tandem use. The larger diameter front wheel on a tandem bike just makes sense. We are not able to lift the front end the same way that a single bike can. Being able to roll over objects with a slightly larger diameter wheel DOES help.
    I'm sure someone will say that the bigger wheeled bike is more sluggish or that it does not perform with the same precision as its 26" wheeled cousin. Maybe? But I'll take the larger front wheeled tandem ANY day on ANY trail. I rode both the 26" wheeled ECDM and the Fandango back to back for over a year before making the move to sell the 26" bike for the 29". Comparing the Fandango and the 29 ECDM may not be apples to apples either, but it made for real world testing of 26" vs. 29" wheels on the tandem. The answer to me is that we don't own a 26" tandem anymore.
    Is 26 going away? Maybe, but not anytime soon. Will 650b catch on? Probably. I don't think anyone can say that there is a new standard, but there is a lot of hype. If you ride different wheel sizes, you will likely find that a having a larger front wheel on the tandem is more profound than riding a larger wheel on a single bike.
  19. #319
    26 v 29 has been discussed a lot here, and first person experience as above is key. One other key is the type of trail you're going to ride. IIRC you mentioned living in SoCal near Santa Monica. Most of our trails in SMMNRA are smooth by national standards. You may not find the advantages of the big wheel to be as great.
  20. #320
    MTB Tandem Nut
    Reputation: TandemNut's Avatar
    Quote Originally Posted by Okayfine View Post
    I would respectfully disagree. The 29" wheels also roll faster over smooth terrain as well. So if the trail is relatively "open" in nature without lots of tight turns and technical features, the 29" wheel would be faster than the 26" wheel. Just my .02.
    MTB Tandems Inc.
    678-445-0711
    www.MTBTandems.com
  21. #321
    Fair enough. I haven't ridden a 29" tandem. My time on a 29" single hasn't been extensive, either, such that it might apply.
  22. #322
    Well after discussion with Alex and doing some measurements on my existing rides looks like the winning combination will be 19/16 with 29" wheels. I'm a bit in-between the 19 and 21 I think, but better to err on having more stand over and I can always do a bit of layback on the seat post and a longer stem if I want a bit more room. Thanks for all the input here - always hard to buy without riding but it should be in the ballpark.
  23. #323
    Jun 2010
    I have to agree with Alex. The brief time we rode a 29er Fandango at AORTA it was noticable how much faster and easier the bigger wheels rolled. We chose 26 wheels on our ECDM because Sherwood wasn't offering a 29 option then. We also ride tight techy terrain occasionally and wasn't sure how the bigger wheels would handle it. We are very happy with the all around capabilities of our ECDM. However ,if we were" in the market " to add to our stable it would be a Fandango 29er probably coupled. Good luck with your choice.
    Ed and Pat Gifford
  24. #324
    The ECDM thread
    Todd,
    Our trails here in north ga are almost all tight, narrow, rocky, root infested and...well, technical. While it took me some time to make the transition to 29" wheels on my single bike (trek Stache), it took no time on our new Fandango tandem. Given the open and smooth(er) terrain you described, it sounds like you made the right choice!
    Tell us how you spec'd out your build.
  25. #325
    PMK
    PMK is offline
    Both bikes are very nice. Each bike excells in certain specific conditions. Neither bike is uncapable of being ridden in either technical trails or fast open trails.
    We know since we have owned both and it was not uncommon to choose a specific weapon for the days riding based on where we planned to ride.
    One thing that often is failed to be mentioned, is you are, when comparing a Fandango to an ECDM are comparing a full suspension vs a hardtail.
    Jeanne and I will (would in ref to the Fandango since it was sold) ride very technical drops, or fast downhills with far more confidence on 26 wheels and rear suspension. On more open flatter or climbing smoother terrain the Fandango ruled. Once you add bumps larger than the tires size, full suspension is faster since you just don't slow down. We hammer across trail features that would have us choosing different lines on the hardtail.
    Which bike is better, neither. FWIW, we rode the Fandango far more than the ECDM when we had both bikes. It was our go to machine until we became really old and semi injured.
    As a captain, and suspension and chassis geek, I notice stupid details about how bikes handle. As I still will state, the 26 geometry works better when the bike is leaned over or carving corners. In a straight line there is not much difference. The saving grace of a 29 geometry is the tire having more grip.
    Again both are great bikes. With thousands of miles on both, and setup notes, ride log data to back it up, I'll say it again both are great and each can do certain things better than the other.
    It's is obvious Dan and his stoker (DS2199) and our team are diverging on which is best. If we lived where they do, our opinion would likely be the same as his. Possibly if team DS lived here in South Florida or even in the SE USA, they may prefer a different setup.
    Again, both wheel sizes are workable. and team DS has the ability to compare all. A 26 ECDM to a 29 ECDM and a Fandango.
    PK
