Results 1 to 3 of 3
    Feb 2005
    Yes Virginia, Krampus is a Lefty, X Post
    I figured you Surly only folks would want to know this too, posted it on the Fatbike forum just now....
    Got the little beasts in this afternoon.
    Had a few odds and ends to wrap up first, but got right down to business as soon as I could. Laced it up offset, turn out I could have gone symmetrical, which I will before riding it, just because.
    I've had a huge number of folks wanting to know, will the 29x3 Knard/Rabbit Hole fit a Lefty.
    More importantly, will it fit a conventional Lefty, as opposed to the custom offset jobbers required for Fatties.
    Yes, they work. Just fine.
    Clearance may be a tad close for some, but I think most will find it more than adequate, assuming a nice stiff built wheel.
    Travel clearance will need to be on a case by case basis, but the wheel fits the chassis, so the rest is up to ya'll.
    In this case, I used a moldy oldy 130 Max. A to C is 510, Krampus fork A to C is 485. I can squeeze about 90 mm out of it as it sits.
    So on a Krampus frame, you'd be looking at less travel, a 490 A to C fork like a Speed 110 would likely net around 60 to 70 mm. Respectable, and close enough to keep handling neutral.
    Or, toss a longer fork on your bigger bike, and go to town with 100+ using a 140/520 A to C.
    Yee Haw!
    Attached Thumbnails Attached Thumbnails Yes Virginia, Krampus is a Lefty, X Post-k1.jpg
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Dec 2010
    Install it on a Krampus. I dare yah
    Feb 2005
    Quote Originally Posted by sasquatch rides a SS View Post
    Just waiting for the build "stuff" and a 44mm headset.....
    Playing with what travel/a to c fork to use too, hmmm, decisions decisions.
    - FrostyStruthers
