Results 1 to 17 of 17
Thread: White 1x1?
    White 1x1?
    What year were the white models? A local seller has a 1x1 for $350. Looks to be a bit older, but $350 is pretty cheap. I want to turn it into a cheap commuter/beach cruiser. It has a suspension fork, figure I'll swap it for a rigid fork. From the pics I can't tell if it has rear brazeons for a rack. Do all years have rear brazeons? Anything I should look out for?
    Reputation: htnswches's Avatar
    Question: Wouldn't another $100 get you a brand new one? Price seems high to me. Bottom bracket has a serial number, that should tell you the age. Go to the Surly FAQ's sections, there's a formula to figure out the manufacture date via serial number. Good luck
    On-one 456 "Cocoa"
    Surly 1X1 "Ginger"
    Stubby-legged
    none of the 1x1 has rack mounts. Save your cash and buy a Troll. Or better yet a Pugs!
    Quote Originally Posted by htnswches View Post
    It is a complete bike. $450 new would be frame only. I don't have spare parts to build up, so new would cost significantly more as a complete bike.
    I already have a Salsa Vaya and El Mariachi. However, they are too nice for leaving locked up at the store, beach, etc. That is why I was looking at a used 1x1 as a commuter/beach cruiser. I figure less of a thief bait.
    $350 is probably a good price for an older 1x1 in decent condition. Still seems kind of high for just a beater bike, though. Most places old steel MTBs can be had for a $100 or less.
    Anyway if you go with the 1x1, there's a few things I'd look out for having just bought a older Surly myself not too long ago. Be sure there's no frame damage - bends, cracks, etc. A little surface rust is okay, but there shouldn't be crazy rust. Check the components for anything that's going to need replacing right away and factor that into your decision and maybe your offer price. Afterall, its no good to get a used bike cheap, thinking your saving money, and then have to turn around spend another $300 on new wheels, tires, brakes, cranks, etc. The crankset is the one that got me. I didn't check it thoroughly enough when I bought the bike. A few months later I was having chain problems and THEN I noticed that two of the chainrings were jacked up and needed replacing. Cha-ching. Cha-ching. Sometimes people are selling their bikes cheap because it needs a bunch of maintance and they don't want to pay for it. They just want to chuck it and get something new. Just something to be wary of.
    Reputation: slimhazy's Avatar
    Quote Originally Posted by bolandjd View Post
    If it has anything resembling decent parts and no serious rust buy it. You can easily get that a month/year from now for a 1x1.
    Steel beater MTB for $100 maybe, but not a singlespeed, or one with a threadless headset/steerer that can easily swap to a suspension fork.
    Quote Originally Posted by slimhazy View Post
    True, but the OP said he was going to swap in a rigid fork to the bike he's looking at, so why does that matter? I just figured that old rigid steel MTBs are pretty much functionally the same as an old 1x1 if all you want is a cheap beater for beach cruising. Same 26" wheels. Same 4130 steel. Anyway, old 1x1's are cool. If I could find one for cheap, I'd snap it up too. You just gotta be careful that that $300 doesn't turn into $500 or more because you gotta replace a bunch of worn out parts to ride the thing.
    I am not sure on the parts. I do know that it is rim brake and not disc. Also, I have met the owner on a couple of rides and he is well known locally and I an avid rider, so I am confident it isn't thrashed. It is just over an hour and a half out to where he lives, so I haven't seen the bike. Since it won't be my main MTB bike, not having disc brakes shouldn't be too big of a deal. I could always add later I suppose.
    I have a CrossCheck that is getting a new owner, so I am familiar with Surly. I wanted a SS for simplicity, so I was looking at 1x1, KM, Troll, and Ogre.
    Here is a pic:
    Dec 2010
    There are threaded holes for a rack on the dropouts I believe. Since you don't have disc brakes your rack will fit fine. I've even gotten a rack on using an aluminum spacer to get the arm out past the caliper. Go to your LBS and pick up some rubber coated clamps that come with racks (I know my LBS has way too many), you can wrap them around your seatstays up by your seatpost. They are rubber to protect your paint and have a hole in them to attach the rack to. Let me see if I can find a Google pic...if not, I'll take a pic of mine when I get home
    Dec 2010
    These are what I'm talking about:
    Or get one of these that will wrap around either your frame or seatpost and adapt to fit the upper rack mounts. (you can use the 1st pic adapters near your dropouts if your frame does not have a rack mount.)
    your better off just getting a Troll since it's a 1x1 with more options
    Dec 2010
    Quote Originally Posted by gyeswho View Post
    You fail to see that OP is looking for an inexpensive beach/cruiser singlespeed bike. He's looking at a complete 1x1 for $350, he's not looking to buy a Troll for nearly 4x as much. He can make a rack fit on the 1x1 just fine.
    From the OP "It is a complete bike. $450 new would be frame only. I don't have spare parts to build up, so new would cost significantly more as a complete bike."
    Quote Originally Posted by sasquatch rides a SS View Post
    Quote Originally Posted by BikeThePlanet View Post
    he never ruled out a troll, i suggested it only cuz it'd be good for expanding upon later on if he ever wanted to. he can only be locked down with SS on a 1x1, but can do much more on the troll that is a beefed up version of the 1x1. yes it would be more $ up front, but he would probably never be left saying he wanted more out of the frame.
    Dec 2010
    You can run gears on a 1x1 no problem. Just need a derailleur hanger.
    I actually thought about going 1x9 on my 1x1 (sounds funny doesn't it?)
    Not sure if it helps much but my straight top tube 2006 Karate Monkey came with brake posts and disc tabs. It's probably older than that.
    IIRC I looked to buy a 2005 1x1 last fall, white w/ white stickers and v-brake only. Similar to this.
    Dec 2010
    I can see in the picture that it does not have disc brake tabs on the frame.
    Rhymes with fartmaster
    Yep. Origin-8 derailleur hanger. Worked great when I had my 1x1 set up as a pretend CX bike with an 11-26 cassette in back and skinny-ass 700x32 Kenda Smallblock 8s on it.
