Results 1 to 7 of 7
    Weight difference between Orge and Karate Monkey?
    so i am noticing that these two have the same geometry, but different tube thickness and mounts. what are the frame weights? with or without fork.
    size small if it makes a difference or what ever your info is i can extrapolate.
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    I had no idea they had different tube diameters. No idea why weights aren't post on their site.
    A garage full of steel frames means happiness.
    Reputation: Hand/of/Midas's Avatar
    Quote Originally Posted by CS2 View Post
    Diameters are the same, the tube thickness is different. Ogre is thicker for more load bearing ability, and KM is lighter for more lofty singletrack action.
    No specific weights on hand, sorry.
    cut an pasted off the Surly site. . .
    Frame: 20˝ = 2.7kg (5lb 15oz); Fork (uncut): 1.2kg (2lb 10oz) OGRE
    No listing for the KM that I can see
    Reputation: ianick's Avatar
    2010 Karate Monkey specs: 5.5lbs for the frame and 2.6lbs for the (uncut) fork.
    ETA: for a 20" frame
    5.9375 - 5.5000= .4375lbs or 7oz. or 198.447g.
    both forks are the same weight. 2.6lbs
    so with only essentially with half a pound difference in frame, it is the same bike, with the orge having more mounting options and being stiffer.
    seems extremely redundant. the karate monkey although a popular seller is far from a race machine. making it slightly more supple is the difference in 3-5 psi tire pressure.
    marketed as a long distance single speed? whats the angle?
    is there something i am missing? or is surly getting rid of the karate monkey next year?
    Bedwards Of The West
    Oct 2007
    As I understand it the Ogre is just all about versitility with the same proven geometry... touring, racks, loaded, unloaded, with whatever configuration / utility options you might want. I think the 'angle' is the versitility you gain because of the mounting options and being stiffer.
    If I was just looking for a mountian bike frame, I would have gone with the Karate Monkey. But I wanted a commuter/tourer/mountian bike/singlespeed/geared/kid hauler/zombie killer/bikepack/dirt/paved/trail/fire road machine. Clearly, a few braze-ons make the difference.
    (no excuse for that either)
