Results 1 to 3 of 3
    Dec 2010
    Troll chainline question
    I am thinking about building up a "parts bin" Troll. I have an old set of XT m750 triple cranks and a 73x110 bottom bracket and I am wandering if that will work on a Troll frame? I am going with standard Mtn 9 speed setup in the rear. I am trying to keep the cost as low as possible but I could spring for a more modern external bearing crankset and bottom bracket or a BB with a longer spindle if I need to. Thanks!
    Obi
    Obi is offline
    -_-
    110's gonna be too narrow if you plan on running a 9spd setup. Gp with a 113mm spindle and you'll be set.
    Dec 2010
    Oh well, guess I'll put a BB back in the budget!!
