Results 1 to 3 of 3
    Reputation: Aushiker's Avatar
    Tektro RL520 Should Marry ...?
    G'day
    I have decided to upgrade my standard brakes on my Surly Long Haul Trucker with Tektro RL520 levers as suggested frequently here and elsewhere.
    My question is to which v-brake to marry them to. From what I have read the Tektro 857AL has been the recommend v-brake in the past in part because of the mudguard clearance (I have mudguards on the Surly). Is this still the best option?
    Also I assume that with the levers and v-brakes there are no other components required for a retro fit?
    Andrew
    May 2005
    Have you considered the TRP CX-9 mini Vs? I just built a Crosscheck for a friend and used the CX-9s. They seem pretty powerful and work with regular drop bar levers. Much better than cantilevers.
    But anyway, yes, all you need are levers that match the brake pull. I don't see how any particular V-brake will have more clearance for fenders than others, they all seem to be about the same shape. I used Avid V-brakes on my Crosscheck and LHT and they worked well. No problems fitting SKS P35 fenders under them.
    Quote Originally Posted by Thor29 View Post
    Same here.
    I do prefer full-Vs to minis, but the one time I had minis I also had a wheel way prone to going out of true, which minis are highly sensitive to. Full Vs are pretty bomb-proof and I am not sure how different any one is from another.
  1. Tektro RL520 drop levers in Sacramento?
    By Bokchoicowboy in forum California - Norcal
    Last Post: 07-16-2010, 01:18 PM
  2. Tektro RL520
    By harry2110 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-30-2009, 06:01 AM
  3. Tektro RL520 and Avid road BB-7
    By olasun in forum 29er Bikes
    Last Post: 01-03-2009, 10:34 AM
  4. Rl520
    By ink1373 in forum 29er Bikes
    Last Post: 10-05-2007, 11:17 AM
