Results 1 to 3 of 3
    Good job! Swapping frames from compete builds (Spec Stumpy Comp 29 to a Karate Monkey): help?
    Hey guys,
    I'm finally going all Surly for my stable. I currently have a Cross Check, and I just finally found someone willing to swap frames + forks for my 2009 Specialized Stumpjumper Comp 29. They're giving me a 2008 Surly Karate Monkey frame + fork + $ in exchange.
    Quick background: I'm not a pro when it comes to bike building, but I'd say I'm more knowledgeable than most, this is my 10th mountain bike, and I've built each of them up on my own.
    That being said... will I run into any major issues with swapping components over? Incompatible components, etc?
    - So far it appears my Thomson seat post and Thomson seat post clamp will not swap, and that's fine, I'll grab new ones.
    - Also the front derailleur clamp will not work. Is there an adapter that I can purchase, or should I swap front derailleurs too?
    Other than that... I can't seem to find any other issues off hand. Any thoughts?
    Below is my build list for my 09 Spec SJ Comp 29....
    Cane Creek S3 Threadless Headset (1-1/8", sealed bearing) *this will go with the frame
    Thomson Elite X4 Stem (110x31.8mm/0 rise)
    Easton EA70 Monkey Bar Low Rise Handlebar (685x31.8mm/8 bend/4 upsweep)
    SRAM X-9 Front & Rear Trigger Shifters
    Avid Elixir CR Front & Rear Brake Levers
    Avid Matchmaker Brake Lever & Trigger Shifter Clamps
    Ergon GX1 Leichtbau Grips
    Avid Elixir CR Front & Rear Hydraulic Disc Brakes w/160mm Rotors
    Shimano SLX M660 Front Derailleur *KM has a smaller clamp diameter
    SRAM X-9 Rear Derailleur
    Shimano Deore Hollowtech 2 FC-M542 Crankset (175mm)
    Shimano FC-M542 Hollow Bottom Bracket *should I just use the existing KM BB?
    Shimano M520 Clipless Pedals
    Shimano SLX HG61 Cassette (9-speed, 11-34t)
    SRAM PC-971 Chain w/Power Link
    Thomson Elite Seatpost (30.9x410mm) *will buy a new one/include in trade
    Thomson Seatpost Clamp (34.9mm) *will buy a new one/include in trade
    Specialized Phenom Saddle w/Hollow Cr-Mo Rails
    DT Swiss X470 29" Rims
    DT Swiss 1.8mm SS Spokes w/alloy nipples
    Specialized Hi Lo Disc Front Hub (sealed cartridge bearing)
    DT Swiss RWS 9mm Quick Release (front)
    Shimano M525 SL Rear Hub
    Shimano SLX Quick Release Skewer (rear)
    WTB Weirwolf LT 29x2.55" Front & Rear Tires
    Thanks much for your help. Glad to finally have 100% Surly, I've been waiting.
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    Sounds really good so far.My brother did the same thing with an old Trek road bike and a Pacer earlier this year. If you can score the donor bike cheap enough it usually works. Good luck and post some pics when it's finished.
    A garage full of steel frames means happiness.
    Bad ass.
    Well, I just did some research and found that shims are available for the front derailleur mount, so that is one issue down.
    I suppose the last problem would be the bottom bracket issue, and if my existing crankset from the Stumpy donor will bolt up to the new (to me) bottom bracket currently installed in the Surly KM frame, since we'll leave both the headsets and bottom brackets installed.
    Thoughts?
    Looks like I've got a Thomson seatpost and Thomson seatpost clamp up for trade for a smaller size to fit the KM if there are any takers out there.
    I have....
    Thomson Elite Seatpost (30.9 x 410mm)
    (mine are near mint)
    I want....
    Thomson Elite Seatpost (27.2 x 350+mm)
    Thomson Seatpost Clamp (30.0mm)
  1. Karate Monkey Townie Builds
    By Ixnay in forum Surly
    Last Post: 06-25-2011, 12:27 PM
  2. Replies: 13
    Last Post: 03-27-2009, 10:50 PM
  3. 20" Karate Monkey frames in stock Anywhere??
    By long hazy daze in forum 29er Bikes
    Last Post: 11-21-2005, 09:44 PM
  4. Spec a Karate Monkey for a 365 6'4" Guy...if you like to do that stuff
    By jumborider in forum Clydesdales/Tall Riders
    Last Post: 09-25-2005, 06:17 PM
