    Surly Singlespeed Hub
    So, is it just my hub, or are freewheels stupidly hard to remove from this hub. Two separate freewheels, put on with not more than hand pressure, required me to use a vise, and an incredible amount of force to remove (so much so that there was spoke deflection). The freewheels did finally break free, but only after a loud crack. The hub and the freewheels were undamaged.
    Any thoughts?
    Reputation: lpt1's Avatar
    Use anti-seize lubricant when turning on a freewheel, and You would be ok.
    For removing freewheel I use proper removing tool, fixed on the axle with bolt or QR, and big alligator wrench. Without vise, any sound and overtorque.
    Everytime you pedal you are effectively tightening the freewheel on to the hub. Anti-seize compound makes it easier, as mentioned above.
    I guess I should have prefaced by saying: the above happened within 5 minutes of putting the freewheel on. I removed the other one (understandably difficult, as it was the original on the bike, and had never been removed before), greased up the threads, installed, removed the cone to pull a spacer, loctited it back on, and then went to remove the freewheel to allow it to cure. That is when the above happened.
    I guess I'm a bit stymied by the process, since I've never had to use anything other than grease, and in my daily taking off and putting on of freewheels at the shop, this is the first time I've ever encountered something like this. I will give the anti-seize a go when I replace it before the ride on Sunday.
  1. Surly Mr Whirly singlespeed chainline?
    By lolmaus in forum Surly
    Last Post: 01-18-2013, 10:12 PM
  2. Removing Surly singlespeed cog from Hope Pro Evo 2 hub
    By shackleton47 in forum Tooltime
    Last Post: 12-03-2012, 06:48 PM
  3. Replies: 41
    Last Post: 09-27-2012, 08:56 AM
  4. My First Singlespeed - Surly 1X1
    By weekdaywarrior in forum Singlespeed
    Last Post: 09-12-2012, 03:40 AM
  5. Replies: 0
    Last Post: 01-21-2011, 08:17 AM
