Results 1 to 8 of 8
    Surly KM Full Guards
    Hello,
    Scratching my head a bit fitting a rear full mudguard as there is no bar joining the stays together to attach the bottom end to it, stop the flapping about and rattling plus getting in the way of the front mech.
    Have you guys got any ideas or bodges in place to show me?
    G-Ted has some ideas, but his KM is single speed.
    http://g-tedproductions.blogspot.com...r-of-duty.html
    excellent, I'm getting serious about it here all ideas welcome, thanks!
    Recreational Racer
    Reputation: Jvan_wert's Avatar
    you could make a simple L bracket from some lexan. Find a good 90 degree bend for a mold then heat it in the oven bend it and drill some holes one for the fender one for the screw hole under the BB shell and you are set.
    “Let me 'splain. No, there is too much. Let me sum up.”
    already have the bracket, that my friend is an amazing idea! originally, i was going to drill 1/4 the way in on the bend of the frame attach a topeak bar extender, spacer it out and keep it on tight that way, you're method saves me drilling holes in the actual guard!
    Reputation: farley's Avatar
    I've had some success with other frames which lacked a chainstay bridge by just use a zip tie to attach the end of the fender to the seat tube.
    Fat, tired.
    Nov 2007
    ^Yep, X2 on the zip ties.
    Fat, tired.
  1. 29er Full Suspension vs Surly Pugsley
    By PaulRivers in forum Fat bikes
    Last Post: 10-03-2012, 10:27 AM
  2. What full-fingered gloves and shin/knee guards do you recommend?
    By Tony777 in forum Apparel and Protection
    Last Post: 07-27-2010, 02:11 PM
  3. Replies: 16
    Last Post: 10-10-2006, 07:24 PM
  4. Surly 1x1 + full length housing = *ting* *ting* *ting*
    By SpinWheelz in forum Singlespeed
    Last Post: 08-03-2006, 07:16 PM
  5. Any full leg wrap knee/shin guards?
    By Swoop in forum Downhill - Freeride
    Last Post: 01-13-2005, 12:04 PM
