Page 11 of 13 FirstFirst ... 78910111213 LastLast
Results 1,001 to 1,100 of 1212
  1. #1001
    Oct 2015
    #notinstagram
  2. #1002
    Feb 2015
    what?
    maybe just think of it like a link to any other website?
    so what is instagram?
  3. #1003
    Oct 2015
    I meant why are you using hashtags? I was kidding more than anything
  4. #1004
    Feb 2015
    I was being young, fresh, hip, beard oil!
  5. #1005
    Sep 2014
    Quote Originally Posted by Matterhorn View Post
    best description that I've heard. Gets hard to hear things like, any road, all road, road less traveled, etc... and see pictures of cross bikes. Our paved roads are rougher than some forest roads elsewhere. Best of all, no crowds. #monumentalloop
    in new mexico,no one can hear you whining!
    for one thing,no people,the other,the 30mph winds drown it out!
    yup,i have a 2.1 inch tire on the front of the straggler mostly because of the roads,but i have discovered there just isnt a whole lot of pleasant off pavement straggler country around here...in general its seems like 3 inch tires are about the minimum needed for anything that might fit the bill as "any road" around here...
  6. #1006
    Reputation: noosa2's Avatar
    Quote Originally Posted by ChargeCookerMaxi View Post
    What size tires? 5" tires use significantly less air than 4" tires.
    4" tires.
  7. #1007
    Quote Originally Posted by hamsterspam View Post
    but,a better answer...
    get a good pressure gauge like the meiser accugauge which i believe is available from jensonusa for about 15 bucks and a good frame pump and play around with your pressure and figure out what works for you and your local conditions...
    I have a meiser accu-gage and it is great. My plan was to take it to the trails this weekend and play with pressure but I was looking for a good place to start.
  8. #1008
    Sep 2014
    really all you can do,tire pressure is gonna depend a lot on what you're riding as far as the trail conditions...
  9. #1009
    fat guy on a little bike
    Does anybody have a carbon fork on their ICT? What are your thoughts about stiffness/handling changes? I love the feel of the steel frame but the steel fork is way too flexy for my taste.
    i ran a Borealis Echo 490mm carbon fork on my ICT and my Wednesday. it worked better on the ICT, as the Wed has a 468mm fork standard.
  10. #1010
    Oct 2015
    Happiness in a picture. A Wednesday, ICT, and Tacoma. Just need some 29+ wheels.
  11. #1011
    Done. Although they are on a different bike...
  12. #1012
    Gimme free stuff
    Reputation: tims5377's Avatar
    Oct 2010
    Quote Originally Posted by Rodney Jekyl View Post
    What size lizard skin is that? I got one but it was too big of diameter...
    Kona Process 134DL
    Ice Cream Truck
    Misfit DiSSent (L) (For Sale)
  13. #1013
    Feb 2015
    Quote Originally Posted by tims5377 View Post
    I'm really immature.
  14. #1014
    Oct 2015
    Also, why the heck are you running one on the non drive side?
  15. #1015
    smallest one i could get.
    because flats. i got sick of cleaning 510 black marks off the frame.
  16. #1016
    Mar 2013
    Anyone having issues with brake squeal and loss of power in the snow? I have a two year old ICT and have had issues since the start.
    I've sanded and alcohol'd pads and rotors, swapped brakes pads, re bedded and still get horrible squeal and loss of power whenever any snow touches brakes. It will disappear for a time if I drag brakes down long hill (similar to re bedding process), but will inevitably reappear shortly thereafter.
    Thinking about replacing the Guide RS' with SLX or XT.
  17. #1017
    Sep 2013
    Quote Originally Posted by notregistered View Post
    The only issue with Shimano brakes is the effectiveness, or lack of it, with mineral oil in the cold temperatures. I would stick with the Guides for cold weather usage...
  18. #1018
    Sep 2014
    At what temperature do you have issues with XT brakes? I must have been oblivious to this issue, or didn't ride cold enough this winter. I replaced my bb7's with XT only because I anticipate needing an extra set of disc brakes in the next year. Happy with the upgrade.
  19. #1019
    Sep 2013
    Quote Originally Posted by ETChipotle View Post
    There is a lot of discussion about this...heated(no pun intended) topic around here! I've had issues with SLX brakes riding in the 'teens. Other people have not so YMMV...
  20. #1020
    Anyone having issues with brake squeal and loss of power in the snow? I have a two year old ICT and have had issues since the start..
    sounds like a possible rebleed is needed.
    I have Guide R on my ICT and Guide RS on my Wednesday. I do have the snow/cold squeal/clown horn, but so does everyone else in those conditions.
    As far as not having power, only time i have that issue is when i do stream crossings in below freezing weather. Ice forms around the caliper, and reduces breaking. If i drag the brake for a bit, it will warm up and resolve itself, only to freeze again later.
  21. #1021
    Oct 2015
    I have some cheapo Shimano BR-M486 brakes on my ICT. I took off the Guides for them because they never make a sound when wet.
  22. #1022
    Oct 2015
    I'm going to attempt installing a RaceFace Aeffect Cinch crank with 170mm spindle on the ICT later today. Will report back with pictures, happiness, or expletives depending on what happens.
  23. #1023
    Oct 2015
    Update Time!!!!!!
    I got the cranks, shoved them in, and the part the drive side arm attaches to did not stick out all the way. Please note: I had absolutely *zero* spacers on the spindle whatsoever. Whoever posted the 170 cranks working on an ICT in the other thread definitely had his BB sanded narrower. There was lots crank/chainstay clearance so it could work if the BB was made narrower. I ain't doin' that
  24. #1024
    Sep 2014
    c'mon,a couple minutes work with a belt sander and yer good to go,slap some carbon bits on there and weight weinie the hect outta it!
  25. #1025
    Oct 2015
    I'm actually thinking about trying this on the frame Surly screwed me with... no warranty so might as well try it. I don't want the giant 190 Q-factor, but saving a pound of rotating weight with the same Q-factor would be very temping. And I'm not a weight weenie anyway, hence why I'm not using Next SL cranks and carbon rotors. Uh, hence why my frame is steel.
  26. #1026
    Sep 2014
    i was just givin yah flack...i never really notice the whole q factor thing except in certain rock garden sections where ive never managed to convince myself the pedals are going to fit no matter how frantically i stair step the pedals....i need to build some rock gardens out behind my house to practice in,not that we dont have great rock gardens on the trails,but sometimes it doesnt seem like a good idea to be doing bone break area stuff alone miles out in the desert...the ground is my enemy at this point in life,it seems to hurt far worse than i remembered as a youngster....
  27. #1027
    Oct 2015
    I'm incredibly duck footed and for some reason very large Q factor bothers my knees. The stock Q (same as RF170mm) doesn't bother me at all.
  28. #1028
    Sep 2014
    i guess i must have "birthing hips"....
    its funny because when i rock climbed i had bad hip turn out but the wide bottom bracket doesnt bother me
  29. #1029
    Oct 2015
    Yes, but you are 6'99" and I'm just an ordinary person.
  30. #1030
    Sep 2014
    im just an ordinary person,theres just more of me is all...
  31. #1031
    Oct 2015
    I meant that I was an average sized person!
  32. #1032
    Sep 2014
    lol,im average size among all the people i know with xxl surly frames!
  33. #1033
    Oct 2015
    I might fire up the ol' random orbital with some 40 grit later... slowly and carefully!
    I kinda want to get this Cinch stuff on my bike... maybe try an oval chainring
  34. #1034
    Aug 2010
    That's the spirit Charge! I'd consider taking it to the bike shop to have them face the BB shell when you're done. I was thinking about this last night and wonder how long it would take to cut that BB shell down with a BB facing tool (like the Park BFS-1). If it's only 1mm/side, they might be able to do it with a lot less risk than you with the sander. Of course, I do appreciate your ingenuity, though. I'm super curious to hear how it goes. You've probably already thought of this, but I'd tape the crap out of the chainstays to avoid sanding away your paint in the area near the BB. Good luck and please keep us in the loop with how it goes!
  35. #1035
    Oct 2015
    I'm starting to appreciate pressfit that is for sure!
  36. #1036
    Feb 2015
    Quote Originally Posted by SlipperyToad View Post
    Just yesterday saw someone on MTBR did the same with the Park Tool and said it took 30 minutes. Think he ended at 83mm on a 100mm Pugs bb. It CAN be done.
  37. #1037
    Oct 2015
    Matt, if you give me a link I will never be able to repay you
  38. #1038
    Oct 2015
    Seems crazy that somebody could take 17mm off the Pug BB without the arms hitting the stays!!
    I'm only talking about removing less than 1mm from each side!
  39. #1039
    Oct 2015
    Matterhorn, thanks for the heads up! I found it.
    83mm BB on a Pugsley and Other Goodies
    ^^ Awesome stuff!
  40. #1040
    Feb 2015
  41. #1041
    Oct 2015
    SUCCESS!
    Got it all working great, but my BB shell DEFINITELY needs facing. There is a stiff spot for sure. Once I get that done I'll be rolling on my narrow Q factor ICT!
    Pics to come.
  42. #1042
    Sep 2014
    i should be rolling a drop bar ict by the end of the week...
  43. #1043
    Oct 2015
    I should be rolling a carbon fork by the end of the week if Nextie ever gets it to me... I will NEVER mess with Nextie again.
  44. #1044
    Sep 2014
    there was a new salsa carbon fiber fat bike in the shop last week...i was impressed by how light it was but i just cant seem to get past the feeling those things are more fragile than they really are...the frame felt like paper mache to me...like i could squeeze it and break it no problem...
  45. #1045
    Oct 2015
    That's how I feel about carbon dude! I'd be afraid of breaking a carbon frame, and I don't like the ride. Steel is definitely my material of choice for frames, love the ride and flex! Just didn't like how flexy my steel fork was in high speed corners. I could care less about the weight savings.
  46. #1046
    Aug 2010
    Hope that fork comes in Charge, and I look forward to the pics of the narrower BB shell. I'm also curious about the drop bar ICT, hamster. I don't remember what group you have on your bike; are you going with bar end shifters?
    I just laced my 29+ front wheel last night, Sun Ringle Duroc 40 to DT350. I accidentally ordered sapim lasers instead of race spokes, so it's taking me a while to get them up to tension. I ended up using a white crayon to make a line down each spoke, so I could see when they start to wrap on me. It works well, but holding the the spoke while tightening takes a lot of time. On the plus side, the shallow rims are super easy to work with, nipples just plop right in.
  47. #1047
    This video changed my views on carbon https://www.youtube.com/watch?v=xreZdUBqpJs
    Still a steel fan, but carbon isn't scary to me anymore.
    Jason
    Disclaimer: www.paramountsports.net
  48. #1048
    Sep 2014
    i have an xt 11 speed on the ict,im going to use a problem solvers light mount that clamps to the bars to mount the shifter on since the drop out is not sram compatible...for brakes i have some tektro long pull drop bar levers that will work with the bb7s although possibly i may use the trp hylex brakes i have if it feels viable...and if that doesnt work i can take the sram setup i have and try it on the krampus...
  49. #1049
    Oct 2015
    My LBS is really busy right now, so I likely won't be getting the BB faced for a little while. Just wanted to keep y'all updated
  50. #1050
    Sep 2014
    why?
    because...
    drop bar ICT...
    woodchipper bars,TRP hylex brakes,problem solver bar mount for the shimano xt shifter...
    Surly Ice Cream Truck-dsc04901.jpgSurly Ice Cream Truck-dsc04903.jpgSurly Ice Cream Truck-dsc04904.jpgSurly Ice Cream Truck-dsc04906.jpgSurly Ice Cream Truck-dsc04908.jpg
  51. #1051
    Oct 2015
    Hamster is going to have *all* the KOMs now.
  52. #1052
    Sep 2014
    im the king of the low hanging fruit!
  53. #1053
    Reputation: cassa89's Avatar
    Jun 2014
    Awesome!
    Surly Krampus
  54. #1054
    Sep 2014
    now to go find some slow moving roadies to ride down!
  55. #1055
    Oct 2015
    Oh la la!
  56. #1056
    Sep 2014
    ooh,fun,truck goodies!
  57. #1057
    Oct 2015
    Got some Ti bolts too... my steel ones were getting pretty crusty. Hamster, do you approve of these?
  58. #1058
    Aug 2010
    It's good to see you put the full Surly crazy to the ICT hamster! I finally got my 29+ wheels built up, just waiting for the Park extensions to show up for the truing stand so I can complete the rear wheel. I went to put it in the stand and realized it wasn't built for a 197 mm rear axle. It's going to be a tough wait for our trails to dry out enough for me to try it out. I guess in the mean time, I'll just try to stay out of hamster's way on my cross bike!
  59. #1059
    Sep 2014
    lol,what,no color? that there looks like weight weinie stuff!
    i have a feeling the shifter kludge may be a no go but the bars and trp hylex would work dandy on the krampus as a ss...also i have a 10 speed bar end already so it would probably work better in the long run...
    its fun to play with surlys,its like a lego set...
  60. #1060
    Oct 2015
    Sarcasm I hope? They are blue! That's why I asked the bling master!
  61. #1061
    Sep 2014
    the internet has been around long enough that there should be a sarcasm font...
    yeah,giving you guff as usual...more of a "blue steel"...going for a zoolander look? lol
    warning...dont go too far down the rabbit hole,i ended up with gobs of spare parts trying to get free shipping on jensonusa orders when all i wanted was 4 dollar valve stem caps!
    just got back from a little test ride on the truck dropper...
    the shifter,not so annoying after all,only slightly awkward...
    the bars passed a big test...was able to bunny hop from the drops and the hoods,the woodchippers are more comfy for me than the soma junebug bars,actually pretty nice in this context...
    i will find out tomorrow....matterhorn has a wee little ride planned for us...i fear he's been looking at google earth again which usually means there will be (un)expected nastiness of some form....be it soul crushingly long hike-a-bikes or thorny bushwhacking im near certain blood will be shed...
    its funny though,even hip-deep in these rides i often find myself thinking "why do so few mountain bikers do this kind of stuff?" it seems like the very essence of mountain biking to me...the uncertainty of it,the willingness to fail,but the spirit to keep going,even when it was clear an hour ago you made a really really dumb choice!
    should be fun...been a while since i rode until i felt like puking!
  62. #1062
    Oct 2015
    Only reason I asked is one of my colorblind friends actually thought they were black.
    Those bolts were a great price, one of my friends sells them.
  63. #1063
    Sep 2014
    i would actually buy ti rotor bolts...bling is one thing,but it absolutely needs to be better than whatever it replaced or at least equal...i would rather put something heavier on the bike than have something break...
  64. #1064
    Oct 2015
    I didn't do it for bling. Honestly, after a year in the midwest the steel bolts are really nasty and corroded. This should take care of the problem.
    I was going to get some chinese Ti bolts, because $40 a wheel for Avid Ti bolts is crazy. These are very high quality European Ti bolts that cost a fraction of the cost.
    Stay away from chinese Ti, they strip out really easy. Actually, stay away from all knockoff bike parts. I wonder what material said knockoff "Ti" really is.
    Hamster, if you need any Ti bolts PM me. I got you
  65. #1065
    Feb 2015
    No promises of course but there should be no, or minimal HAB. Really maybe NO HAB at all. Looks like about 41 miles to the petroglyphs but maybe a slightly shorter return trip.
    Can't wait to see that drop bar nonsense in person!
  66. #1066
    Ict
    Had a couple of rides on the new to me ICT and it is a blast although it will probably take me a couple more rides to get really comfortable with the steering.
  67. #1067
    Oct 2015
    Your bike have Onyx hubs?
  68. #1068
    Yep.
  69. #1069
    Oct 2015
    You buy that bad boy from Jason?
  70. #1070
    Sep 2014
    just getting back from a cracker of a ride with matterhorn...that crazy bastard is still out there riding or taking a nap or something...i had had enough of drop bar fat biking for one day at mile 47....i still had 10 or so miles left to get home when i finally cracked..or at least started cramping up bad enough to say fuqit....and i also knew i was not far from a buddy with a pickup truck...
    big country...the 20+ mile approach ride didnt help...it was nice though,got to the meat of the ride just after the sun came up...good ride,nice stout climb to start things out,generally pretty nice dirt roads,then a not so nice descent down an unending series of rocky,sandy,chunky nonsense...but it was sure pretty...aside from the untimely collapse of willpower an awesome day of back country riding...
    Surly Ice Cream Truck-img_20170321_082834359.jpgSurly Ice Cream Truck-img_20170321_082841625.jpgSurly Ice Cream Truck-img_20170321_083217288.jpgSurly Ice Cream Truck-img_20170321_092129597.jpgSurly Ice Cream Truck-img_20170321_094615551.jpg
  71. #1071
    Sep 2014
    Surly Ice Cream Truck-img_20170321_103143250.jpgSurly Ice Cream Truck-img_20170321_104601038_hdr.jpgSurly Ice Cream Truck-img_20170321_104757501_hdr.jpg
  72. #1072
    Yeah, we actually traded bikes and I swapped out a few parts.
  73. #1073
    Interplanetary Traveler
    Reputation: Phat Cactus's Avatar
    May 2016
    Because I'm OCD about color coordination...yellow decal set for the Bluto
  74. #1074
    Aug 2010
    Looks like quite a ride hamster and Matterhorn - there's nothing quite like that here in Iowa. I finally got done building the wheels for summer. Here's a pic:
    Oh yeah, they weight 3.2 lbs less than the stock salsa/RD with Jumbo Jims that I had on there. It's like pedaling a road bike now!
  75. #1075
    Feb 2015
    SlipperyToad--yeah, not quite like Iowa! Where in IA are you?
  76. #1076
    Aug 2010
    I've been in eastern Iowa most of my 42 years, with the exception of a brief stint in the SF/San Jose area. In Iowa City now.
  77. #1077
    Reputation: makkot's Avatar
    Mar 2017
    Quote Originally Posted by Phat Cactus View Post
    Thank you for sharing.
    Im going to setup a bike like yours by the end of the year, mixing my actual fatbike bluto equipped on a ICT2017 frame.
    And i was wondering how well could the rockshoks yellow decal apply to the fork, replacing my green one.
    I think the result looks excellent.
    GREAT looking BIKE
  78. #1078
    Oct 2015
    A little urbex with my 'Truck.
    Surly Ice Cream Truck-img_0030.jpgSurly Ice Cream Truck-img_0021.jpgSurly Ice Cream Truck-img_0023.jpg
  79. #1079
    Gimme free stuff
    Oct 2010
    We will start with the question. I just took the casette off my truck and really had some trouble. Had to hit it with a hammer. Not fun. The casette really tore up my free hub. It is a sram casette on DT big ride hub. Should I buy a shimano casette to stop this?
    On to the exciting bit... I got my 29+ wheels ready to roll! Rabbit holes on Big Rides with a Dirt Wizard up front and a Chronicle out back. Also had put flats and Ergon grips on a bit ago. Sorry for the shit pic but it's been raining all day here so the basement is what we get.
    Editors note: Still need to trim the steer tube. Casette not installed due to first question. Tires were purchased used so they are dirty (no, I don't know how it rides). I need a way to cover the red on the seatpost but haven't found anything good yet.
    Cheers!
    Kona Process 134DL
    Ice Cream Truck
  80. #1080
    Oct 2015
    Looks damn nice Tim!
    That is pretty normal for the cassette to tear up the freehub. That is why you run a steel freehub. Or you can invest in a higher end cassette with aluminum carriers. What SRAM cassette do you run?
  81. #1081
    Sep 2014
    what maxi said...it will still work fine,just a pain to deal with...
    nice truck!
  82. #1082
    Gimme free stuff
    Oct 2010
    Not sure what casette is. Would need to look after I leave this brewery... (Never leaving tehe)
    So the DT steel freehub body is $90 and an Xt 10 speed casette is $50. Will the new casette saved new freehub so I don't need to replace two of them?
    Kona Process 134DL
    Ice Cream Truck
  83. #1083
    Oct 2015
    I don't really understand what you are asking Tim. Trying rewriting it when you are less drunk
  84. #1084
    Sep 2014
    So the damage is already done but you can still put another cassette on it. Or go xd and 11 speed
  85. #1085
    Gimme free stuff
    Oct 2010
    Lol. Whoops.
    I don't want to destroy the freehub on my 29+ wheels (similar to the pic from my fat wheels (see above)) with the sram casette if a shimano will be fine as the new freehub is $40 more than the new casette. Would the shimano casette actually be easier on the freehub?
    Kona Process 134DL
    Ice Cream Truck
  86. #1086
    Oct 2015
    Depends. If you get a cassette with aluminum carriers, yes. If not, no. I'd just get a steel freehub if I were you. It will last longer than an expensive cassette.
  87. #1087
    Question for those of you that have a set of 29+ tires. What fat and 29+ tires do you run and what is the change in BB hight?
  88. #1088
    Sep 2014
    im running bont barbegazis for fat and wtb ranger tough for 29+,ive run the maxxis minions
    and chronicles as well...the minions i didnt like for the desert,the barbies are a better tire i think,maybe not as tough as the minions,but they also dont go shooting off to one side everytime you run over a rock...the chronicles do fine in the dirt but pull too much on the road,the rangers do better overall...
  89. #1089
    Aug 2010
    I'm running the rangers in the tough casing too. They are pretty much identical in height to the Jumbo Jim 4.8s I had on the RD rims, I don't really notice any difference in bb height. The bike is just a hell of a lot easier to haul uphill.
  90. #1090
    Good to know - thanks.
  91. #1091
    Gimme free stuff
    Oct 2010
    Quote Originally Posted by noosa2 View Post
    Dirt wizard up front. Chronicle out back. Pretty similar height to my bud and Lou.
    Kona Process 134DL
    Ice Cream Truck
  92. #1092
    Jan 2016
    Hello Ice Cream Truck drivers! I'm a new ICT owner. Got a quick question about the rear brake. It's the stock SRAM Guide brake. The brake caliper appears to be a millimeter or two too high. You can see the top edge of the pads are above the brake disc in the photo below. Is this a problem? I can adjust the caliper position fore and aft, but not up and down. The only thing I can think of to fix this would be to shave a bit off the caliper mount adapter. Any other suggestions?
  93. #1093
    wanna ride bikes?
    Oct 2013
    perhaps the adapter is flipped around, aka installed improperly. or maybe it's the wrong adapter. or the wrong rotor? probably best to figure out what's out of place instead of "shaving" anything and putting a band-aid on an improper setup.
    If you can't track down the problem, take it to a bike shop.
    Rigid SS 29er
    Fat Lefty
    SS MonsterCross
    SS cyclocross
    all steel
  94. #1094
    Jan 2016
    Quote Originally Posted by *OneSpeed* View Post
    The adapter has the arrow pointing to the front. The wrong adapter would put it +/- 20mm too high or low. The rotor is the stock 160mm rotor. Best I can tell, the caliper mounting tab was welded on a smidge too high. LBS isn't going to be able to fix that.
  95. #1095
    wanna ride bikes?
    Oct 2013
    Quote Originally Posted by cjbiker View Post
    seems you've got it all figured out. why'd you bother asking?
    Rigid SS 29er
    Fat Lefty
    SS MonsterCross
    SS cyclocross
    all steel
  96. #1096
    Jan 2016
    In case I missed something less obvious.
  97. #1097
    Oct 2015
    The rear caliper mount has up/down adjustment. Forward and up, back and down. Where the mount bolts to the frame. I can get you a picture later if you want.
  98. #1098
    Jan 2016
    I would like to see a pic. The rear caliper mount on mine has the slots parallel to the ground. On all the other Surly bikes I've had, the brake caliper mounts allow adjusting like you said.
    Edit: here's a pic of the ICT:
    And a Surly Wednesday. You can see the top slot is at a 45 degree angle to the ground.
  99. #1099
    Sep 2014
    A little night ride along the river, a stop at Casey's General Store on the way home to pick up a 2 liter diet coke that I can't come anywhere close to finishing...
    Glad I took all the Winter stuff out of my Anything Bag!
  100. #1100
    Oct 2015
    Looks like it is in the down position... same as mine.
  1. The Ice Cream Thread...
    By DIRTJUNKIE in forum Off Camber (off topic)
    Last Post: 1 Week Ago, 04:56 PM
  2. Paid SPAM: Surly Black Floyd with Surly tubes
    By tracerprix in forum Fat bikes
    Last Post: 11-15-2012, 09:02 PM
  3. Going for Ice Cream
    By norona in forum Marin
    Last Post: 06-18-2012, 01:46 PM
  4. Which fork? Surly Instigator VS Surly Troll
    By Bokchoicowboy in forum General Discussion
    Last Post: 09-02-2011, 08:21 PM
  5. Replies: 0
    Last Post: 01-21-2011, 08:17 AM
Members who have read this thread: 190
