Go Back   Mtbr Forums > Mountain Bike Manufacturer Forums > Surly
Reply
LinkBack Thread Tools Display Modes
Old 01-24-2012   #1
mack_turtle's Avatar
Rep: mack_turtle is just really nicemack_turtle is just really nicemack_turtle is just really nicemack_turtle is just really nicemack_turtle is just really nice
user gallery
shift housing stops on new KM
I have a 2011 KM and I would like to put a RD on it for road riding purposes. the frame seems to have been designed to use full housing for the derailleurs but I would rather not have full housing all the way down. how might I at least replace the length of housing along the top tube?
mack_turtle is offline   Reply With Quote
Old 01-24-2012   #2
1x9 or Avada Kedavra
Guy.Ford's Avatar
Rep: Guy.Ford will become famous soon enough
user gallery
The only idea I've got Problem Solvers Backstop
See also Universal Cycles -- Interloc Double Housing Stops
Personally I'd prefer the Problem Solvers Ive used there products before and it looks like a much sturdier build.
__________________
Guy.Ford
I'm not really an @sshole, I just act like one online.
Guy.Ford is offline   Reply With Quote
Old 02-02-2012   #3
Rep: keevohn is on a distinguished road
user gallery
If your KM uses the 3-sided "trip guides", there may be another option to the cable stop shown above.
You might be able to use a Jagwire cable stopper in the middle guide slot (facing down). Jagwire part #CHA056 is for 5mm housing slots. Since the slot is pretty open, you would need a zip-tie to keep the stopper from falling out.
Unforunately you can only do one derailleur this way, and you can only have an open cable run along the top tube. You would have to go back to full housing as it travels down the seat stay to the rear derailleur.
keevohn is offline   Reply With Quote
Old 02-02-2012   #4
concrete-bound
slimhazy's Avatar
Rep: slimhazy is on a distinguished road
user gallery
Wouldn't adding two bolt-on clamps negate the weight savings of a small length of bare cable? Or are there other reasons as well?
slimhazy is offline   Reply With Quote
Old 02-02-2012   #5
user gallery
i am not interested in saving weight. I want to monster-cross my KM with dirt drop and bar-end shifters. this would require a LONG stretch of shift housing, which would result in lots of friction and sloppy shifting. breaking up the housing for al least 18 inches somewhere would presumably eliminate a little of that. right? why does every other bike on the planet have cable stops on it? why don't we all just use full-length housing?
Old 02-03-2012   #6
Rep: dickyelsdon is an unknown quantity at this point
user gallery
Friction in gear cables comes from kinks and bends in the outer or poorly maintained cables. The housing would be straight on the top tube so no added friction there (assuming you greased your cables) and if you are not looking after your cables then full length cables will have less friction anyway, as there are less open ends for the water to get in. The main reason not to go full outers is cost, full length outers are expensive if you want to buy quality gear, but then they may last longer (if your the sort of person who dosnt bother looking after your gear).
dickyelsdon is offline   Reply With Quote
Old 02-03-2012   #7
Fat boy Mod
Moderator
donalson's Avatar
Rep: donalson will become famous soon enough
user gallery
yup full length housings are going to let less crap get into the lines...
__________________
www.PORC.org Pensacola off-road cyclists
- Trek Sawyer
- Surly 1x1
donalson is offline   Reply With Quote
Old 02-03-2012   #8
concrete-bound
slimhazy's Avatar
user gallery
Gotcha. Perhaps you could epoxy some cable ends/ferrules into the hose guides? Or use low-friction cable like the Gore stuff?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Hot Deals
Latest Mountain Bike Articles
Latest Lights Shootout Articles
Press and News Articles
Interbike - Virtual Trade Show Booths
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
Search Engine Friendly URLs by vBSEO 3.6.0
