Results 1 to 11 of 11
    Jun 2012
    Rust? Should I even bother?
    So, I rubbed a big chunk of paint off my frame with my lockup chian and it's now rusty. Is this even really something to be concerned over or will the surface rust stop any more rust from happening? It's just going to get chipped again if I paint it again.
    Reputation: supersedona's Avatar
    Dec 2012
    If you do not want to repaint the area, shine it off with a fine grit and wax it heavily. The ideal would be to sand it and blend in some primer/paint then wax it. The wax allows the rubbing to slide without as much abrasion as well as it doesn't chip off.
    '93 Giant Sedona ATX custom
    '93 Giant Sedona AtX aero-edition
    '73 Schwinn Suburban
    '95 Fuji Suncrest
    Reputation: AlexCuse's Avatar
    With a thin tubeset you might worry about it rusting through but its highly unlikely to happen with tubing as thick as you find in a surly frame. I think the surface rust sort of forms a protective coating. There is a technical term for it that my brother (who works for a specialty steel company as a metallurgist) told me but I forget what it is. The only reason to paint over it is if you're concerned about appearance or resale value.
    Supersedona's advice sounds good if you're worried about the chain slowly rubbing away the rust (and therefore the metal)
    Yeah I only carry cans cause I'm a weight weenie.
    Jun 2012
    Quote Originally Posted by supersedona View Post
    What kinda wax? Brooks proofide?
    Reputation: mattbryant2's Avatar
    Apr 2005
    I wax my bikes with Turtle Wax. Why not?
    Dec 2012
    Good for car paint its good for bike paint. My Sedona is Cro-mo and has made it through 20 years of weather from tropical salt air to winter commuting with no rust. Plus it makes any dirt wash off easier.
    '95 Fuji Suncrest
    Reputation: asphaltdude's Avatar
    Quote Originally Posted by AlexCuse
    It works that way with aluminum and titanium but not with steel iirc.
    Ride more!
    Reputation: FatCloud's Avatar
    May 2013
    Paint chips are battle scars.
    Surly even says so themselves.
    I would just put a "sock" over your chain, I put an old tube on my U-lock for this reason. My paint is beat to **** (I figure on year 3 or 4 of the bike I'll give it a new paint job...I expect it to last me beyond a decade)
    Reputation: dfltroll's Avatar
    Quote Originally Posted by FatCloud View Post
    Grant Petersen refers to this as "Beausage."
    All good expeditions should be simple in concept, difficult in their execution and satisfying to remember--Alastair Humphreys
    Reputation: duggus's Avatar
    This
    I wax my steel frames as well as my aluminum... makes the water/rain glide right off.
    ...Be careful what you're looking at because it might be looking back...
    Jun 2012
    Can't really as it's the type the can be locked on any link. Look up pragmasis chain.
  1. why bother with tubeless?
    By Markleo in forum Wheels and Tires
    Last Post: 06-15-2013, 01:59 PM
  2. Help me justify or tell me not to bother
    By wgerow in forum Wheels and Tires
    Last Post: 02-10-2013, 12:03 AM
  3. Is it just me... or does this bother anyone else who rides through here.
    By UncleTrail in forum Colorado - Front Range
    Last Post: 04-07-2012, 09:50 AM
  4. BB7's......don't even bother to ask.
    By Limey Johnson in forum Brake Time
    Last Post: 11-30-2011, 01:55 PM
  5. Why even bother with the LBS in these cases? Seriously...
    By CoastieTX in forum General Discussion
    Last Post: 05-20-2011, 04:26 AM
