Results 1 to 9 of 9
    Bike Geek
    Reputation: slowlybutsurly's Avatar
    Regular 29"/26" tubes for Knard/Rabbithole?
    I think i've read somewhere here that regular 29'er tubes or 26" DH tubes would work with Knards on Rabbitholes. Can anyone confirm this? If true, any suggestions on size & brand?
    I use 26x2.7-3.0 tubes on my pugsley just fine. I imagine a standard larger 29er tube would work in a 29" knard.
    I'm using a 29x2.1-2.3 tube in my 27tpi Knard mounted on a Rabbit Hole and haven't had any issues. I bought a 26x2.7 tube thinking the extra width would be a better fit but haven't taken the time to mount it and doubt I will at this point.
    Reputation: vikb's Avatar
    I'm using 29 x 1.75"-2.5" tubes in my Knards. Works fine.
    Safe riding,
    Vik
    www.vikapproved.com
    Bike Geek
    Thanks for the replies, guys! I'll give the 29x2.3 Kendas that are available at my lbs a shot.
    Bike Geek
    Wow! Those Surly tubes are heavy! .407 kgs. each! I replaced them with your garden-variety Kendas that weigh around .217 kgs. Took off .380 kgs of rotational weight for 10 bucks...money well spent!
    PSYCHOLUST
    Reputation: scyule's Avatar
    Always looking to shave a few grams when I can, I run the same tubes I do in my other 29ers
    1) MAXXIS FLYWEIGHT 26 X 1.9/2.125
    2) CONTI TUBES MTB Supersonic 26 X 1.75/ 2.2
    Both of which are 95 grams
    I've been running the MAXXIS tubes on my KRAMPUS since I built in in April, no problems
    Thought I'd bump this because I'm buying tubes. I use the 26x2.4-2.7 Q-tubes Superlight on my fat rim and have had great success. Wondering how these will work with my 29 inch Rabbit Hole. I could always go with the 29 inch Q-tube, but that's claimed to be narrower.
    Dec 2010
    My Knards pick up a ton of thorns. After about 3-4 patched holes on each Surly tube I decided to go with 29x2.1-2.3 tubes. Saved a ton of weight! I also put some Stan's inside the tubes and haven't had a flat since. I'd highly suggest doing this to Knards. I just didn't want to mess with tubeless since there are so many mixed results on the Knard/RH setup.
  1. Xt cassette and chain "narrow" with regular chainset?
    By SQUIRRELSHOOTR in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-28-2013, 01:01 AM
  2. Replies: 0
    Last Post: 02-20-2013, 02:27 AM
  3. Double Amputee Competes in "Regular" Olympics
    By Ericmopar in forum Off Camber (off topic)
    Last Post: 08-13-2012, 11:06 PM
  4. "regular" spd vs. "caged" spd
    By vqdriver in forum General Discussion
    Last Post: 05-28-2012, 06:54 PM
  5. "Rhythm" or regular Bontrager strip for 5.1d
    By Broccoli in forum Wheels and Tires
    Last Post: 03-01-2011, 07:14 PM
