Results 1 to 7 of 7
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    Pacer Brake Help
    Has anyone used short reach brakes, especially Campy, on their Pacer? From what I can see they might not have a long enough reach.
    A garage full of steel frames means happiness.
    Ariolimax columbianus
    Reputation: nativeson's Avatar
    Apr 2005
    rat tail file.
    CS2
    CS2 is offline
    Quote Originally Posted by nativeson View Post
    rat tail file.
    I was hoping for something a little less extreme. But I'll give you extra credit for ingenuity. I've got enough spare Campy parts to put together another bike, like I really need one. I need brakes though. So, before I buy I'd figure asking would be cheaper in the long run.
    What year frameset is that? AFAIK before 2011 you could use short reach brakes, newer frames need long reach brakes.
    Marcin
    CS2
    CS2 is offline
    Quote Originally Posted by marcinski View Post
    Marcin
    How do you tell? It's the current green color. Is the year in the S/N? It's nice frame and would probably make a nice general purpose bike.
    Look at the serial number stamped under the bottom bracket. The number following the letter M is the year of production, i.e. M2**** is 2002 and so on.
    Marcin
    CS2
    CS2 is offline
    Marcin
    Thanks, I'll check it out when I get home from work.
