Page 16 of 18 FirstFirst ... 6 12 13 14 15 16 17 18 LastLast
Results 376 to 400 of 442
  1. #376
    Mar 2005
    Hi, rifraf.
    Thanks for the additional pictures. After a couple of months, I'm starting to experience more creaks and rattles on my Ogre, I think are due to the fenders. I'll look at adding more mounting points of the fenders to the front and rear racks, like what you have done. I was wondering if the single set of fender stays would be adequate on these, as all my other fenders in the past have had two sets of stays per fender.
    Thanks again!
  2. #377
    Dec 2012
    Quote Originally Posted by western_rider's_dad View Post
    Hi, rifraf.
    Thanks again!
    Where are your pics with fenders?
    Cant wait for a squiz.
    Cept for loose stones, mine seem pretty quiet.
    Some people swear by leather or rubber washers but mine arnt yet an issue.
    My Rohloff noise is more annoying to me.
  3. #378
    Mar 2005
    Quote Originally Posted by rifraf View Post
    So I've redrilled my fender to raise the stays in an attempt to nutralise the problem of the trailer wanting to wallop the fender stays when going over a bump greater than an inch:
    I finally got around to getting the fork crown stay of my Velo Orange Pass Hunter rack welded into a different position allowing me to fit it to my Ogre.
    I got the stainless engineer to make the addition of a tab to attach my Edelux headlight to one of the V-brake stays. I'm very happy with it.
    Other than some shiny steel eye candy, my wanting the small front rack was mainly for a secondary mounting point for my front fender.
    The roads are steeply undulating where I am and its been a bit of a worry thinking about my front fenders single top mounting point of the fork crown bolt.
    Now two attachment points have to give way to let the fender drop onto the front wheel and send me over the bars at speed.
    The Ortlieb handlebar bag I use means there wont be much real use for it as a proper rack whilst touring.
    Around home however it works well as a mounting point for my aluminum camera case which I like to be up front where I can keep an eye on it.
    Hi again, rifraf!
    Could you perhaps include a close-up picture of your additional front fender mounting hardware, that attached the fender to your front rack? Also, since moving the fender stays up higher on your rear rack, do you feel they are any more or less secure?
    Still working on stiffening (and dampening) my fenders. ;-)
    Todd
  4. #379
    Nov 2013
    I needed this info too, and am marking it
  5. #380
    Dec 2012
    Hi again, rifraf!
    Todd
    Hi Todd,
    I'll try to get my camera out over the weekend as I've put it away somewhere and not 100% where.
    I've got to find it for an upcoming tour so will do a search on Sat.
    In the meantime check out the colour pic on velo oranges page:
    VO Pass Hunter Front Rack - Racks - Racks & Decaleurs - Accessories
    The one with the rack bag on it. (Click it for a close up)
    If you run your eye up the rack stay that attaches via the brake boss, you'll see a cross member in the middle of the rack. This has an attachment bolt through the fender illustrated in this pic. Its roughly in the halfway point of the rack bridging the two sides of the flat rack. It has a threaded hole in the center which the bolt attaches after you thread it up through the fender from underneath.
    My rear fender seems fine since I changed the mounting position.
    I've noticed no difference or movement in it since doing this.
    I'm thinking a red reflective tape strip should adequately camouflage the two now unused holes.
    The Gilles Berthoud fender stays are heavy duty and being a single piece that wraps around the fender, are much stiffer than conventional stays.
  6. #381
    Feb 2012
    just an updated pic of my Ogre frame, back from my powdercoater. it's going to be back together this coming weekend i hope.
    much sparkle in the sun.
    news to me Rohloff no longer offer polished silver rather an annodised finish, i like it.
  7. #382
    Dec 2012
    Hi Stevejfromthestwitch,
    Nice colour.
    Cant wait to see your new build.
    Did you rob your previous Ogre build to make up a Krampus or ECR?
    I think I said earlier I was having issues with my Extrawheel trailer.
    It was hitting my Ogres mudguard stays.
    I moved the fender stays upwards and now enjoy approx 13 inches of upward trailer articulation.
    I've also added trailer nuts to my frame after grinding off the uppermost bottle openers from my two tug-nuts.
  8. #383
    Feb 2012
    Just got mine back together, need to get my B17 back on there
  9. #384
    Reputation: lextek's Avatar
    Love the blue color!
  10. #385
    Bout time this thread had a bump and I've some updated pics to add.
    Holy nalgenes batman! Where do you get bottle racks that carry nalgenes? Do you ride much off trail with those, will they actually hold nalgenes?
  11. #386
    Dec 2012
    Quote Originally Posted by drews256 View Post
    BBB XL Fueltanks from memory.
    I had to remove the top clips which are useful for coke bottle 1.5 litres but don't play nice with the Nalgenes.
    I was told to use some straps but so far the bottles haven't moved either full or empty.
    I tour with my bike so as not seeking any air, my riding, even off road, is fairly staid (slow)
  12. #387
    Reputation: L4NE4's Avatar
    Quote Originally Posted by SteveJfromtheSwitch View Post
    Looks awesome! What front rack is that? Looks like a salsa
    "Never mistake motion for action."
    "If I can bicycle, I bicycle."
  13. #388
    Feb 2012
    Yep salsa minimalist.
  14. #389
    Sep 2014
    My Front Loaded Bikepacking Ogre
    Thought I'd share mine. Weight upfront, which I like, seems to balance out the bike.
    Downunder racks with anything cages. Ground clearance could be better, but we'll see. I'm not doing tech single track anyways.
    I used 5mm nylon spacers on the anything cages to allow the down under rack's mid-fork attachment to get in position.
    And, yes, thats a 64oz beer flask.
    Ogre Build Thread-img_2849.jpgOgre Build Thread-img_2856.jpgOgre Build Thread-img_2858.jpgOgre Build Thread-img_2859.jpg
  15. #390
    Reputation: fire_strom's Avatar
    Hi all
    I've been loving my Ogre for a while but I've determined that the medium I bought is a bit small for me. Any chance anyone wants to trade me for their large? I am talking frame and fork only. I'll send pictures to anyone interested. Mine is the Army Green one.
    -Scott
  16. #391
    Jan 2015
    Wow... Tons of information and pics!
    I have a question and please forgive me if it seems lazy (maybe all the answers are already here). I'm set on getting an Ogre. It will cost $1700 to have it shipped to my LBS and assembled. I rode one; it's awesome stock and I would customize it with time.
    I'm wondering if it would be worth it to buy the frame and build from there to save a few bucks... Mainly, I could care less about the disc brakes. Everything else that comes stock is fine. I would prefer to just ride with one rear caliper brake.
    Could I find significant savings by scaling back the brake setup and finding the rest of the parts, or would it be a royal pain for an amateur?
  17. #392
    Dec 2012
    I don't think you ever save a penny from a self build.
    I think you just use what ever potential saving there might have been to buy upgraded components.
  18. #393
    Did I catch a niner+?
    http://i484.photobucket.com/albums/r...ps154f09af.jpg
    Dat color though....
  19. #394
    Dec 2012
    I just swapped out my Titec J-bar to the genuine Jones Loop bar today.
    Having the full loop and being able to now mount my Edge 800 in the centre of the front bar of the loop means I've more easily attained hand grip positions than the J-bar offered.
    I've also swapped out my straight Thomson seat-post to a set-back version as well as trailing a Brooks B17 Special to see how it fairs comfort-wise over my Champion Flyer Special.
    I've not yet done enough miles to make up my mind.
    If my Flyer Special goes back on, its getting some eye candy via a swop out of its black springs for some B67 chrome ones.
    I'm still enjoying my Ogre and although the idea of the World Troller is tempting, I'm inclined to stick with what I've got.
    I've found the Ogre more of a wet noodle heavily laden than I anticipated or heard about in forums but with my riding style being slow and casual, I can live with the foible.
    Oh another issue thats bothered me is the thread in the holes in the dropouts for trailer nuts was surprisingly sloppy (and yes I double checked I had the correct size and thread for the bolts I utilised).
    They tightened up ok after I dremelled off the head of the bolt and slotted it so I could use a screwdriver to wind it into the dropout trailer nuts threaded holes.
    Threading on the trailer nuts and tightening against the dropouts seems to have gotten things secure but I've purchased some thread tape and Locktight product and am going to have another crack at them.
    I don't want to lose a trailer nut out on the road miles from anywhere and I'm hesitant about tack welding them in place as was suggested by someone.
  20. #395
    Feb 2012
    keen to see how you manage to put the ortlieb handlebar bag with the jones bar. I just bought the bag and haven't decided yet but thinking about an accessory bar mounted lower just for the bar
  21. #396
    Dec 2012
    I've been rocking a Titec J-bar from the get go so grabbed a Thorn accessory bar to accommodate the Ortlieb Ultimate bar-bag.
    Here are some pics form one of my posts a few pages back of the Thorn accessory bar and Titec J-bar handlebar:
  22. #397
    Dec 2012
    The links I tried to copy didn't work for some reason so here is hopefully some new links to the pics:
    These were all posted some pages back with the Titec J-bar.
    My steerer is uncut and the accessory bar is halfway down the steerer.
    The handle-bars are slightly angled down at the grips end.
    No probs lifting the lid, which opens from the rear forewards, at all and the lid has no contact with the bars.
    The J-bars seem exactly the same size and angles as the 660 Loop H bars.
    My new bars are the wider H bar of 710 and although they are the full loop, as opposed to the J-bars cutout, there is no issue with the bar-bag.
    I'll try for a pic of the new Jones bar on the bike a little later and post.
  23. #398
    Feb 2012
    i'm not sure i left as much steerer as you. i've got the same adapter and i plan to try it on this weekend. flip it down, stem up, hopefully still enough to get the lid open and clear under the jones bar. stay tuned....
  24. #399
    Dec 2012
    Looking forward to seeing your pics.
    Looking at the pics I see my Thorn accessory bar is angled and I've fitted it with the angle pointing downward at the front.
    I think pic two shows this clearest..
    Love that blue of your bike.
    For anyone following in our tire prints, the Thorn accessory bar is available from SJS Cycles in the UK, in a few different sizes
    Be aware I'm using a very short 50mm stem
    Pretty sure the one I got was:
    Thorn Accessory Bar T Shaped 105 mm Extension - £16.99
    The bar-bag can be extended further out by an accessory
    This is the bracket and this is the extender.
    Despite what the description says, mine was supplied with clamps for both standard and oversized handlebars.
    SJS Cycles can also supply the chrome springs I was talking about to swap out the black ones of my Flyer Special for a little eye candy.
    Brooks Right Hand Coil Spring - £5.99
  25. #400
    Dec 2012
    Steve what size/model grips did you go with for your Jones bar.
    I got a bit stumped with the ESI Chunky sizing.
    Like yourself, I've a Rohloff in the rear.
    Can the ESI grips be cut down slightly if needed without looking raggedly?
    I've also a mirror on the "Hoff" shifter side which with the Avid Speeddial 7 levers take up far more realestate on that side of the bars compared to the left.
  1. surly ogre
    By 1971tch in forum Surly
    Last Post: 1 Week Ago, 04:46 PM
  2. I am an Ogre!
    By Dalton in forum Commuting
    Last Post: 06-03-2012, 12:22 PM
  3. Replies: 19
    Last Post: 02-15-2009, 04:46 AM
  4. Ogre Dung!
    By Joseph-da-trog in forum California - Norcal
    Last Post: 06-07-2006, 08:36 PM
  5. A Big Thank You From Ogre & Fiona
    By Ogre in forum Passion
    Last Post: 06-29-2005, 07:24 AM
