Results 1 to 27 of 27
    No Dirt Wizard 29x3"
    Looks like the new Surly catalog only lists the 29+ Dirt WIzard in a 2.75" width? No 3" width for the front of my Krampus?
    Reputation: thickfog's Avatar
    Oct 2010
    Do you have a link to the catalog? I can't find it.
    CRAMBA Chairman
    http://surlybikes.com/uploads/downlo...14_catalog.pdf
    Dirt Wizards detailed on page 33.
    Oct 2010
    Re: No Dirt Wizard 29x3"
    Quote Originally Posted by Bikenanigans View Post
    CRAMBA Chairman
    Reputation: vikb's Avatar
    Quote Originally Posted by bike hippy View Post
    The Knard 29 x 3.0" fills the back of a Krampus to the max. Hence to add knobs they had to shrink the tire casing a tad.
    If they didn't they'd be making a tire their own customers couldn't use on 29+ specific bikes and making these niche tires is expensive enough they can't afford to do a ton of different sizes.
    2.75" is still huge and fits both ends of the Krampus and ECR.
    BTW - this also means it will fit quite a few suspension forks with reasonable clearance unlike the Knard which either didn't fit or fit with marginal clearance.
    Safe riding,
    Vik
    www.vikapproved.com
    Word. I'm just wondering if it will be super mis-matched to have the smaller 2.75" on the front, I plan on keeping the Knard on the rear.
    I don't think it will be a big deal running mixed 29+ rubber.
    Safe riding,
    Vik
    www.vikapproved.com
    Dec 2012
    I'm wondering if (aka hoping) the 29x2.75 might stand a chance of fitting an Ogre. Anyone know yay or nay?
    Quote Originally Posted by BATRG3 View Post
    A chance? Yes. Someone stuffed a 29 x 3" Knard into the rear of a KM - barely. So a 2.75" tire would have a better chance at fitting. However, if it does fit it will be pretty tight in there.
    A Knard fills up the rear of my Krampus to the point of minimal clearance for any wheel wobble.
    Safe riding,
    Vik
    www.vikapproved.com
    Some more test fitting - doesn't look so good...
    Quote Originally Posted by haentz View Post
    Hi guys! I installed the Knard 27tpi on the rear wheel of my Karate Monkey. While it technically fits when I push the axle all the way to the back I dont think this really works. There's about 3mm of space between the wheel and the chain stays. Because the steel frame flexes so much the Knard still scrapes on the chain stays when pedaling hard on in turns. Also mud and snow will quickly clog up the space. I only did a little 50km trip on mostly just slightly muddy ground though. The grip even on very wet mud puddles was fantastic though I have now installed the Knard on my front wheel, which of course works fine.
    Here are a couple of pics, article is only in German, though: Surly Knard 3.0 im Karate Monkey Bikelog Mountainbike Blog
    Safe riding,
    Vik
    www.vikapproved.com
    Dec 2012
    I keep thinking the 2.75 has a better chance of fitting than a 3.0. Is this a false hope?
    In theory if the DW is actually 0.25" narrower including the side knobs that buys you an extra 3mm of clearance on each side. However the side knobs may eat into this clearance depending how Surly measured the width.
    Either way you aren't left with much room and the wheel needs to be pushed to the far end of the dropouts which may cause shifting problems.
    If you want a DW anyways for the front of your bike it doesn't hurt to buy one and see if it works in the rear.
    Keeping in mind the Ogre's rear is spec'd for a 2.5" tire.
    Safe riding,
    Vik
    www.vikapproved.com
    Reputation: savo's Avatar
    any update on DW 29 availability?
    Spring 2014.
    Safe riding,
    Vik
    www.vikapproved.com
    I'm looking to put a pair of the 26'' versions on my 1X1 and here in the UK they are due to land January 22nd.
    Will check on the 29'ers.
    Jamie
    I just came across this thread, and followed the link to the catalog......
    Look at the catalog again!!!!!
    26 x 2.75"..... Yes
    29 x 3.0".....Yes
    Catalog schmatalog, anybody gotz da goods?
    Quote Originally Posted by Flyin_W View Post
    Latest word on the street is Aug 2014 for the 29+ DW.
    Safe riding,
    Vik
    www.vikapproved.com
    Damn.
    I was hoping for a 29x2.75 to fit in my fox 34 fork
    Quote Originally Posted by savo View Post
    Damn.
    I'm going to stick with Knards and dremel my fork brace for clearance.
    Safe riding,
    Vik
    www.vikapproved.com
    nvphatty
    Guest
    Quote Originally Posted by vikb View Post
    pics or it didn't happen.
    Quote Originally Posted by nvphatty View Post
    I'll document it when it happens.
    I have quite a few bike projects on the go a ton of blow down to clear off the trails so my plate is full.
    I should have it finished by the 2nd to 3rd week of March.
    Safe riding,
    Vik
    www.vikapproved.com
    Dec 2010
    Quote Originally Posted by sasquatch rides a SS View Post
    I'll offer you the same 100% Satisfaction Guarantee I do with all my blog posts. If you are not totally happy just let me know and I'll give you a full refund of everything you've paid me to generate the content that's made you dissatisfied.
    Safe riding,
    Vik
    www.vikapproved.com
    Dec 2010
    nvphatty
    Guest
    i lost my head
    Safe riding,
    Vik
    www.vikapproved.com
  1. Replies: 0
    Last Post: 05-09-2013, 11:13 AM
  2. Anyone get their hands on a Surly Knard 29x3"?
    By trrubicon06 in forum 29er Components
    Last Post: 04-11-2013, 06:04 AM
  3. Any short rider(5'6" tall) riding 22.5" TT dirt jump frame?
    By giangnguy3n in forum Urban/DJ/Park
    Last Post: 03-25-2013, 05:29 PM
  4. Anyone get their hands on a Surly Knard 29x3"?
    By trrubicon06 in forum Fat bikes
    Last Post: 01-03-2013, 04:46 PM
  5. Replies: 2
    Last Post: 11-15-2011, 06:30 PM
