Results 1 to 6 of 6
    Mini V Brakes on LHT
    Anyone used Mini V brakes on stock LHT build? Just curious about clearance or any thoughts. I am thinking of upgrading brakes and it seems like a simple solution since they appear to work with the stock levers.
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    Quote Originally Posted by pastpost View Post
    I would have to think they work well. The cyclocross guys that using them and really like the way they perform.
    A garage full of steel frames means happiness.
    troll
    Reputation: brokebike's Avatar
    Jan 2013
    Upgrade to some good pads and you should be fine. I'd worry about whether or not they would limit your clearance for fenders, depending on your tire size.
    Jun 2012
    What size tire will those things take anyway?
    CS2
    CS2 is offline
    Quote Originally Posted by aBicycle View Post
    Use the Paul Mini Moto if clearance is the issue.
    I am not a mini-V fan they are extremely unforgiving of wheel wobble. On the other hand maybe I am blaming the brakes I had for a bad wheel (that couldn't hold true). Once I replaced that wheel they worked great, but I didn't spend much time w/ them after that 'cause I was on the path to selling that bike. The person I sold it to remained happy w/ the purchase though.
