Results 1 to 6 of 6
    Dec 2009
    Krampus with setback or straight seatpost?
    Building up my Krampus this month and thinking about seatpost offset or not.
    Everybody makes trailbikes with steep seatangle (74 or sometimes 75 degrees), Surly gave the Krampus a slack 72,5 degree *and* a setback seatpost.
    I wonder: is there a reason for sitting more over the rear wheel on a Krampus? Does Surly know something others don't know?
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    The large wheels mean chainstays have to be a bit longer. Maybe it's mostly compensating for this? With a slack seat tube and setback post wheelies are easier.
    Dec 2010
    Unless you have extremely long arms/upper body, I'd suggest a seatpost without any offset. The TT on the Krampus is long and a straight seatpost should work fine..
    Saul is 100% correct, as well.
    Reputation: vikb's Avatar
    Quote Originally Posted by DerBergschreck View Post
    I use a seatback seatpost and it works fine with my Brooks B17.
    You have to get the saddle to the correct spot relative to the BB for your body. Whether you need a setback seatpost on the Krampus to do this depends on your body and the length of the saddle rails.
    Safe riding,
    Vik
    www.vikapproved.com
    Aug 2013
    Use a setback seat post to adjust the lower half of your body relative to the crank/pedal. Reach adjustments should be made with the stem length and frame size.
    Aug 2013
    Woops. Double post deleted.
  1. Replies: 0
    Last Post: 09-11-2013, 05:30 PM
  2. New Seatpost: Setback or straight?
    By 007 in forum General Discussion
    Last Post: 04-05-2012, 11:47 AM
  3. setback seatpost?
    By weekendthrasher in forum Bike and Frame discussion
    Last Post: 12-04-2011, 12:32 AM
  4. setback versus straight?
    By weekendthrasher in forum All Mountain
    Last Post: 11-22-2011, 08:37 AM
