Results 1 to 5 of 5
    Jan 2009
    Krampus and Maverick DUC32
    This may be of interest to some.....
    I fancied putting some bounce on the front of my Krampus and having seen the lack of clearance with Fox and other forks I thought that the DUC32 would be a good choice.
    I found and bought some on eBay for a decent price, and then got to adapting them.
    The first thing was the short headtube on the Krampus. The DUCs will take a minimum HT length of 130mm, and the Krampus is about 105mm with the headset. So I had to machine up an extension to the steerer nut. It was a tight fit (I knurled it) and it was epoxied in place. So far it seems pretty sturdy. But in future I may machine and tap a longer one piece steerer nut.
    I then checked to see how much I had to reduce the travel by to make sure the tyre cleared the crown. The standard Maverick travel reducers are 35mm long, but I machined up some 48mm long to take into account the larger tyre diameter.
    The fork had come with a 26" wheel on a Maverick hub, but luckily my existing wheel has a Hope Pro2 hub, and they do a Maverick axle. Having read on here of some problems people have had as the finish on it is smooth, I knurled the ends of the axle - a solution suggested by an ex-Maverick employee.
    Here are some pics of the bike built up. I've been out for a couple of rides so far, and it's working great
    Loads of room....
    And with my mates Karate Monkey for comparison....
    Well done!
    tardcore
    Reputation: pjlama's Avatar
    Looks awesome! Nice work! I'm thinking of going with the Manitou tower pro, I heard it fits.
    Did you make any extras?
    Jan 2009
    Nope, but pretty easy if you have access to a lathe.
    Happy to post diagrams & dimensions, etc.
  1. Help Converting 15mm to 24mm Maverick DUC32
    By gfowkes in forum Wheels and Tires
    Last Post: 03-16-2013, 09:00 PM
  2. Maverick DUC32 Forks V Fox 150
    By mazspeed in forum Maverick
    Last Post: 06-14-2012, 12:08 PM
  3. Maverick DUC32
    By modifier in forum Shocks and Suspension
    Last Post: 09-19-2011, 06:58 AM
  4. Replies: 0
    Last Post: 03-31-2011, 05:56 PM
