    Dec 2008
    KM surly threaded hub question
    i have a 2008 km set up ss with a surly threaded hub. i use a surly tuggnut on the drive side. I have a spare wheelset with big apples that I switch out depending on where I am riding.
    my question is that after a couple of times of removing and reinstalling the rear wheel with the threaded surly hub, why do the bearings get tight? Am I doing something wrong? I adjust the bearings so there is no play in the hubs and i tighten the two locking nuts so they are tight, but after a few times of tightening and loosening the axle nuts, the bearings get tight and I have to re-adjust them again.
    not a huge deal, but just wondering if I am missing something here?
    thanks for any help, JN
    Abby Normal
    Reputation: Holmes's Avatar
    Surly New model hubs are notoriously difficult to adjust properly - I had the same problems with mine. You can try swapping out the original 7901 (adjustable) cartridge bearings with 6901 (non-adjustable) bearings:
    FAQs | The Information Hole | Surly Bikes
    This is the cheapest option but still requires a bit of fiddling to get it just right. Or you can 'upgrade' your hub to their 'Ultra New' axle / bearing setup:
    Surly Ultra New Hub Axle Kit > Components > Wheel Goods > Axles | Jenson USA Online Bike Shop
    I've done this on my rear hub and it's been pretty nice.
    Dec 2008
    thanks for the reply. I figure at some point i will upgrade to the ultra new hub kit, but I can live with this for now.
    curious to hear from other riders who have upgraded if they think it is worth the $45 or just pop in the non-adjustable bearings?
    thanks for any insight.
    Jon BALER
    I think it is worth it. No cone wrenches to fool with, no need to carry a 15 mm wrench, and you can switch to a quick release in seconds too.
  1. Surly Cog question
    By drjay9051 in forum Singlespeed
    Last Post: 08-06-2013, 05:17 PM
  2. Fork size question - threaded please help!
    By op12389 in forum Beginner's Corner
    Last Post: 07-28-2013, 04:58 PM
  3. Older Surly Hub Question
    By Keyaroxy in forum Surly
    Last Post: 06-19-2011, 11:27 AM
  4. CO2 inflators: non-threaded vs. threaded
    By client_9 in forum Wheels and Tires
    Last Post: 04-03-2011, 08:50 AM
  5. Surly Singleator question
    By sasquatch rides a SS in forum Singlespeed
    Last Post: 01-12-2011, 07:37 PM
