Results 1 to 25 of 25
    JRR
    JRR is offline
    KM and quick release?
    Looking at getting a KM all I really need is a frameset if a QR rear wheel wont slip.If it does I will just buy the complete which comes with a bolt on axle.anyway whats your thought on running aQR on a monkey.250# using long lever and small cog?By the way would a king hub with fun bolts work without slipping?
    #THELEGEND
    Reputation: Guy.Ford's Avatar
    From my experience running single speed, it will slip, even with fun bolts, without a chain tensioner. Gears you'd be fine.
    #THELEGEND
    2016 RSD Mayor
    2018 Diamondback Release 5C
    2017 Diamondback Haanjo Trail
    JRR
    JRR is offline
    Doesnt the KM come with a tug nut for chain tension or is that an after market thing and can it be used with QR.Really like geometry of the KM over the EL mar. but the drop outs have to work or that a deal breaker
    lord of my world
    Reputation: surlywhore's Avatar
    Dec 2005
    I had a KM for 6 years and never had the rear slip bolt on or QR. just use a high quality or steel skewer.
    drop outs will work, you may have to ham fist it to close the QR. an enclosed cam QR will make it hold better, just ask sheldon Bicycle Quick-release Skewers
    Tugnutz will make it better, they have a little washer piece that will make it work with a QR
    #THELEGEND
    Quote Originally Posted by JRR View Post
    Tuggnut is after market, does not come with frame.
    #THELEGEND
    2016 RSD Mayor
    Fat boy Mod Moderator
    Reputation: donalson's Avatar
    like GuyFord said it doesn't come with a chain tug... use a shimano type QR and you'll be fine Bicycle Quick-release Skewers
    - Surly Disc trucker
    - '82 trek 560 roadie
    Jan 2009
    I have some nice Shimano QR skewers on my bike and it stays tight and straight with the help of a single Tugnut on the drive side. however, I don't need the Tugnut anymore because I put a 32/20 gear on it and the axle fits perfectly in the forward-most position in the slots. I have to use a master link in my chain (KMC z610hx) to remove it though, which is kind of a pain. it's worth it though because having the wheel that far forward makes this a wheelie machine!
    Reputation: seat_boy's Avatar
    I had a frame with KM drops and good Shimano QRs--slip city until I added a chain tug. This was frustrating.
    Monkey Junkie
    I've had some slippage issues on my KM using a Shimano QR. You really need to get the QR as tight as it can go for it not to slip. I would get a tuggnut for the drive side unless you go bolt on. I've kicked myself for not getting a tuggnut since I bought the frame..Surly needs to make a cheaper version of them.
    Jan 2009
    who says you have to use a Surly Tugnut? they are nice, but any chain tensioner with an adapter to fit your QR skewer should do just fine.
    I ride fixed and SS w/ XT skewer, no slipping. I did have slipping, even geared, w/ a burley trailer skewer. But my daughter has outgrown the trailer so...
    Monkey Junkie
    Quote Originally Posted by mack_turtle View Post
    This is a valid point. I had considered getting a cheap chain tensioner and using the Surly QR adapter/washer. Wasn't certain that it would work well. I've never used chain tensioners before except for the "built in" ones that came on my monocog flight to push the sliders back.
    Reputation: jesusburger's Avatar
    The drive-side on my Cross-Check would occasionally slip forward using a Salsa skewer, no matter how hard I did it up. Using a Shimano XT cam-style skewer has fixed the problem.
    It was always when I stood on the pedals to grunt it up the start of a climb and as a singlespeed Pugsley rider that was a habit too hard to break ;^)
    ya my KM had issues with the hope skewers... used an old (mid 90's shimano LX skewer cranked down hard and it was fine.
    Dec 2009
    I use Deore XT Hubs and skewers and they don't slip. A friend of mir usese Deore hubs and skewers and has no problems, too.
    Jan 2009
    Quote Originally Posted by CycleAddict View Post
    then again, your choices for tensioners that also open beer bottles are limited.
    then again, again, I have found that a SPD mountain pedal works just as well for this purpose, so I don't need any special components to open bottles.
    My KM came with monkey nuts ( their wording) . Small locking spacers that spaced the rear wheel back a ways. Wouldn't that fit the bill? Assuming the wheel is slipping forward. I have nutted axles, so no issues for me.
    Nov 2007
    Quote Originally Posted by leeboh View Post
    No. Those are for using a front Derailleur.
    Yes but would work to keep the drive side from slipping forward, right?
    Reputation: Polk's Avatar
    I think it comes down to how and where you ride. Around me there are a lot of short, steep hills that really require some power. Almost everyone can make a Shimano QR slip, and many can even slip a bolt axle. People have even slipped the non-drive side if they only use one tensioner (yes, I ride with some strong riders).
    When I ran my KM single speed, I used a tensioner on each side. No chance of anything slipping, plus I could take the wheel off and put it back on in the same position each time. I personally like Redline tensioners; lightweight and easy to use.
    I weigh 225 and use an xt skewer without problems.
    Dec 2009
    And how do you thighten the chain after a while?
    Reputation: thickfog's Avatar
    Oct 2010
    Quote Originally Posted by DerBergschreck View Post
    You have to wait until it wears enough to shorten it! Half links help here.
    CRAMBA Chairman
    Oct 2010
    Quote Originally Posted by Polk View Post
    Polk, what size does one buy for a std qr axle? They have 14mm and 3/8.
    CRAMBA Chairman
