Results 1 to 7 of 7
    Reputation: PanFry's Avatar
    Nov 2007
    KM Fork Concerns?
    I am having some hesitancy running the KM rigid w/stock fork..
    I am never a huge fan of rear facing dropouts as I am concerned about the Q/R shaking loose and releasing the wheel. I am 6'5" 205lbs. ride fast/aggressive XC and plan on using the Mavic Cross29max wheels so they will have decent skewers.
    Thoughts to help me put my fears to bed?
    Many Thanks,
    PanFry
    EXCUSES ARE THE NAILS IN THE COFFIN OF FAILURE.
    Use quality skewers and it won't be a problem. The wheel will never fall out thanks to the "lawyer lips", but if the skewer slips you'll notice the brake rubbing and be able to fix it.
    Jason
    Disclaimer: www.paramountsports.net
    Nov 2007
    right on
    Quote Originally Posted by JAGI410 View Post
    I had similar thoughts but wanted a little peer affirmation
    Many Thanks,
    PF
    Robtre
    Reputation: robtre's Avatar
    6'5" 225 here and to confirm your assumption: YES ITS A PROBLEM! Braking forces drive side of the axle forward and brake side (assuming disc) outward. There are 2 fixes: 1 Surly tugnuts: B-. Nutted axle/ bolt on axle A+. It works. I had XT internal cam skewers and it still moves.
    -rides bikes for fun.
    Quote Originally Posted by robtre View Post
    The OP is asking about the fork.
    In all of the information that is on the internet about Surly bikes or the KM in particular has it ever been mentioned by someone that there is a problem with the fork and a QR? How does a QR shake loose exactly?
    Expert Crasher
    Reputation: GreenLightGo's Avatar
    6'3" , 200lbs - have not had an issue in four years running my 08 KM rigid.
    Happiness depends more on the inward disposition of mind than on outward circumstances. Benjamin Franklin
