Results 1 to 21 of 21
    Dec 2009
    Karate Monkey MDS: no short 431 mm chainstays any more :-(
    Surly says: chainstay length even at the new(er) Karate Monkey OPS is still 431 mm.
    I wonder how this can be
    I you use the singlespeed version, you theoretically have 431 mm - but you need a few mm to tighten the chain, so 435-438 is the shortest cs length.
    Then I tried the QR and the thru-axle version - and you get surprisingly 450 mm and 440 mm.
    Sorry Surly: never ever 431 mm
    Why did you do this?
    Positively negative
    Must...resist...commenting...
    Team Captain
    My last KM (non-MDS) is probably my last KM, and it's been more or less relegated to bikepacking duty. For a real MTB, I'm thinking something like a Canfield is the way to go.
    Jan 2009
    I was going to get a KM mds until I learned this. Nevermind.
    They need to update the geo chart on their website at least.
    Positively negative
    Quote Originally Posted by occamsrazor View Post
    I know nothing about eyelets or rack mounts, but here are the ones on the frame in case anyone is wondering what they are like:
    Quote Originally Posted by aybee View Post
    Monster commuter!
    Sad face.
    Reputation: seat_boy's Avatar
    Well, the previous 431mm chainstays were always tough to obtain in single speed mode. But yeah, it's sad about the KM losing this defining characteristic.
    At least we still have the Ogre!
    WTB: fatbike hub, 170mm QR
    WTB: Large steel 29er (Niner SIR9, Soma Juice, Gunnar Rockhound, Singluar Swift or XL Gryphon)
    Jan 2009
    I have my OG Monkey perfectly slammed in the dropouts with a 32/20 gear ratio, so the effective CS is about 17". with a 1x9 setup, I just let the axle slide all the way into the dropouts. I don't use a front derailleur so it works fine. this is why I won't be buying a new KM unless they revise the dropouts to allow for a 17" chainstay.
    Dec 2009
    They only must make some inserts which have the axle position at 431 mm - perhaps there is an update in the future?
    Positively negative
    Le sigh.
    Oct 2011
    Quote Originally Posted by seat_boy View Post
    Ironic, because I always thought the Ogre was the one that should have lengthened chainstays, given it's marketing as a touring bike.
    Positively negative
    Now that I think about it what differentiates the new KM from the El Mar? And considering they are under the same umbrella...
    I liked it better when Surly made versatile bikes, rather then specializing them all.
    Dec 2009
    I sent an email about the long chainstays to Surly. I tell you, when I got an answer.
    Dec 2009
    Quote Originally Posted by big_papa_nuts View Post
    El Mar frameset comes without a rigid fork, so when you wnt to ride rigid, you have to order it separate. Unfornatutely it is not availiable in frame colot but only in black :-(
    Steering angle of El Mar in 71, so 1 flatter tham KM, which has 72.
    KM is powdercoated, El Mar is wet paint which is not so stable.
    Positively negative
    Quote Originally Posted by DerBergschreck View Post
    Fair enough, but if you were running a bike company do you think it'd be prudent to sell two bikes that were so similar under two different, competing, brand names.
    Dec 2009
    I now have an answer from Surly about this and this is indeed what the are planning to do. It takes a little time, the say "later in 2015" and in the meatime there will come an article on their blog.
    It seems that first they wanted to make possible ridig fat 2,5" tires with front derailleurs. I'm curious about the new MDS chip(s?) next year.
    Jan 2009
    if they come out with a chip that allows a 1x and a 17" chainstay like my current KM, I would buy that.
    Dec 2009
    Looked at the Surly Website and saw this:
    Small Parts | Parts and Accessories | Surly Bikes
    The 12 mm slotted MDS with derailleur mount is new, isn't it?
    So Surly listened tu us - but only for thru axle wheel - not for QR wheel.
    Is there another MDS coming?
    Jan 2009
    that is indeed rad:
    Karate Monkey MDS: no short 431 mm chainstays any more :-(-fs2008_640x480.jpg
    Sep 2014
    Makes me want a KM.
    edit: ...even more than before, if that's even possible.
    Dec 2009
    Quote Originally Posted by mack_turtle View Post
    that is indeed rad:
    Any chance to fix an QR 135 mm axle inside these?
    Sep 2013
    DT Swiss - Conversion kits
  1. Long vs short chainstays
    By OutThere in forum 29er Bikes
    Last Post: 01-14-2015, 09:28 PM
  2. The importance of short chainstays?
    By Dpca10 in forum All Mountain
    Last Post: 04-24-2013, 04:35 AM
  3. You Lika the Short Chainstays?
    By Bluebeat007 in forum 29er Bikes
    Last Post: 12-21-2012, 01:01 PM
  4. define short chainstays
    By dbraxis in forum 29er Bikes
    Last Post: 06-04-2012, 02:39 PM
  5. Replies: 16
    Last Post: 03-01-2012, 12:10 PM
