Results 1 to 9 of 9
    Cheesiest
    Reputation: intheways's Avatar
    Installing star nut on Surly fork
    I'm posting this in the Surly forum, because I figure that Surly forks are burlier than most.
    I went to an LBS to get a star nut installed on my Pugsley fork. They installed it with the dropouts on the ground (carpeted). I know this is a definite bad practice on suspension forks, but is it okay on a steel fork...particularly, a Puglsey?
    It'll be fine, but you'll have to put 25 extra miles on your Pugsley within the 1st month to say you're sorry.
    Jason
    Disclaimer: www.paramountsports.net
    Cheesiest
    Quote Originally Posted by JAG410 View Post
    Hopefully, it will be more like 100
    Reputation: SSSasky's Avatar
    The dropouts of the fork are definitely tougher than the little tabs of the star-fangled-nut. One had to give. I doubt any damage was done (although it's still bizarre that they did it). Also, why is the shop area of your LBS carpeted?
    Cheesiest
    Quote Originally Posted by SSSasky View Post
    I thinks it's bizarre too. It's not the BS I usually go to...I took it to a local shop while visiting in-laws. The carpeted area was actually outside of the shop part of the store.
    My anal-retentive nature convinced me to go back and examine the thickness if the rug. There was a rug on top of the carpeted shop. I don't plan in going back for any work.
    Reputation: seat_boy's Avatar
    I always do mine into a small block of wood, and it's always fine (suspension fork or rigid). What's the accepted practice?
    Cheesiest
    Quote Originally Posted by seat_boy View Post
    Do you put the dropouts or bottom of the steerer tube on the block of wood?
    No message.
    Obi
    Obi is offline
    -_-
    I always use a fork-up mount or at the very least a spare dropout spacer. The plastic ones that come on factory bikes in manufacturer boxes that we usually toss aside for the shipping packages.
    For that matter, it's a fricking bike shop, seriously, WTF? Like they don't have either of the choices I use?
    *Yes, it'll be fine, as long as you can throw a wheel in and it isn't all crooked you're good.
  1. Installing the Star Fangled Nut
    By TheDoc46 in forum Beginner's Corner
    Last Post: 06-18-2011, 09:52 PM
  2. What is a fork star nut?
    By kawarider in forum Beginner's Corner
    Last Post: 01-15-2007, 01:04 PM
  3. help installing a star nut please...
    By mcd in forum General Discussion
    Last Post: 11-06-2006, 08:01 AM
  4. Mavic D521 + Surly Endomorph + Surly 1x1 fork
    By Nikolas in forum Wheels and Tires
    Last Post: 01-20-2006, 11:12 PM
  5. Installing a star nut
    By slyfink in forum Shocks and Suspension
    Last Post: 05-23-2004, 04:08 PM
