    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    The Impossible Dream
    Winter is coming to North Ohio. I've got a few projects lined up. One is trying to put together a 20 lb or less Pacer. My budget is limited. I have a 54 frame fork and headset. My parts bin is filled with Campy Veloce and Centaur parts. Not quite sure if you could do a Centaur equipped bike or not. I'm sure the steel fork will have to go. Any recommendations?
    A garage full of steel frames means happiness.
    Enve wheels, DA everything should get you there.
    My steel road bike is at 19lbs, and it's got 1600 gram wheelset, DA 7800 cranks, Romin Ti saddle, light bullhorn bars, one front brake and no gears. Trying to get your 4.5lb steel frame under 20lbs will take some $.
    CS2
    CS2 is offline
    Quote Originally Posted by phsycle View Post
    DA is nice but out of the picture. I'm trying to make due with what I have in the parts box. I know I'll need a seatpost, stem, handlebars, saddle and some other small parts. I have most of the group. Just how much does a Pacer complete bike weigh? I'm talking about the one Surly sells.
    I doubt that you will get under 20lbs with Veloce and Centaur, but I guess it highly depends on your wheels, too.
    Not sure about the complete build weight. Looks like 105 components with tank wheels and 28mm tires. Probably 24lbs or so, I'd guess.
  1. Your dream bike. How do you dream you'd get it?
    By andyb_aka_shredward in forum Passion
    Last Post: 01-10-2015, 12:45 AM
  2. Mission Impossible
    By Babajista in forum General Discussion
    Last Post: 04-03-2013, 11:17 AM
  3. Need Some Help With The Impossible.
    By That Tall Freak in forum Clydesdales/Tall Riders
    Last Post: 02-24-2013, 06:06 PM
  4. Who can do the impossible?
    By Dag Nabbit in forum Arizona
    Last Post: 06-27-2012, 04:47 PM
  5. Mission impossible
    By twin in forum Mexico
    Last Post: 11-23-2011, 01:36 PM
