Help trying to find a green pacer frameset size 54cm
i know this is sort of a wanted ad but i'm chasing last years (or 2011??) green frameset in size 54. i've done the online look and asked a few sellers but not had any luck.
if you have one, new or used or know of any stores that have one, can you let me know?
cheers
Steve
Steve, did you change your mind about the sea foam CC?
struggling with the choice, i plan to run all roadie gear on this one so decided a Pacer might be a better choice. also seems the frame sizing suits me better. a 54 Pacer is a slightly better fit than a 54 xcheck.
to muddy the waters even more i'm watching another frameset locally (Jamis Eclipse), if i miss out on that i'll most likely go the xcheck.
Not loving the pacer blue, more liking the hospital foam green, would love the green pacer though.
I have a Sparkle Boogie Blue 52cm Pacer frameset still in the box waiting to be built. I quite like the colour. I'm thinking a light weight 650b build.
any chance you could take a pic of the colour out in the light??? i'm struggling to get a good look at it. you're 5'8" right? (or 5' 7"??)
I'll put up a photo as soon as I can. 5'7-8"ish.
much appreciated
how will the 52 fit you? would you run a 100mm stem?
I'll be a using a 90mm stem, the 52cm is slightly long for me. I would prefer a 535mm top tube. I have long legs, short torso for my height.
i'm undecided on frame size, was thinking 54 but i know i could easily make a 52 work as well.
I'm not sure if you're still looking for a 2011 Surly Pacer in Green but Lickbike.com has them. I just ordered one the other day and am anxiously waiting its arrival.
Lickbike.com | Surly Pacer road frameset'
thanks anyway but i found another frameset (non surly for a change)
By appleSSeed in forum 29er Bikes
Last Post: 10-07-2012, 04:31 PM
By sachase in forum Surly
Last Post: 11-06-2011, 09:05 AM
By need4gforce in forum Cyclocross
Last Post: 09-09-2011, 11:55 PM
By lpt1 in forum Singlespeed
Last Post: 03-18-2011, 08:51 AM
By BOSS100X in forum Niner Bikes
Last Post: 02-22-2011, 09:03 AM
- You may not post replies
- You may not edit your posts
Forum Rules
