Results 1 to 11 of 11
    Reputation: Celt's Avatar
    Apr 2005
    geared KM question...
    Can/do you push the rear axle all the way forward when running in geared mode? Does the tire hit the seat tube if you run a reasonable tire e.g. 2.1 or so?
    Linux is for those who hate Microsoft, BSD is for those who love UNIX.
    Depends on your front derailleur. I think there's a Surly Spew article about it, but I. Think you'll be ok. If not the Surly Monkey nuts will help.
    Jason
    Disclaimer: www.paramountsports.net
    As Jason said, it depends on which front mech you use. I had an old style KM with the gear-cables under the BB shell. I found an old Suntour X1 mech cleared my 2" Michelins even fully forward in the drop-outs no problem.
    I think the new KM's require top-pull mechs, which may mean that the monkey nuts are necessary!
    If youre running a front derailleur youll likely need the surly monkey nuts. I run a 1x9 with a 2.2 tire with the wheel all the way forward in the dropouts without a problem.
    Apr 2005
    Thanks for the timely responses guys...
    Forgot to mention that my plan would be a 1x9, so it looks like I'm ok.
    Oh you'll be fine. I'd go with a strong skewer like a Salsa or XT just to be on the safe side. It'll ride awesome and be really easy to wheelie
    Jason
    Apr 2005
    perfect...thanks
    http://surlybikes.com/blog/spew/spew...t_derailleurs/
    Quote Originally Posted by JAG410 View Post
    Reputation: Iron_sparthan's Avatar
    Hi, you can see on the thread my Karate Monkey Geared. I tell you, I used the Tuggnut to set up the wheel against chain pull action.
    The Tuggnut, positiones at the end of the dropouts, would end that and you can set the rear axle on the second hole.
    I used the top swing front der SLX and the clearence is good but not so much. So if you don't use the Tuggnut you should use the Monkey Nuts.
    By the way take a look to the thread and to the pics.
    Cheers
    here is a pic of mine with the wheel forward in 1x9 configuration.
    <table style="width:auto;"><tr><td><a href="https://picasaweb.google.com/lh/photo/u1Y-lWEMG-8sTdqSpch59sIQvnTwBuDABABE2_7myfM?feat=embedwebsit e"><img src="https://lh4.googleusercontent.com/-Ji5UXi4OMU8/TNdT4lf2qaI/AAAAAAAABuQ/wSU7z4DRn5s/s144/DSCN1668.JPG" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="https://picasaweb.google.com/lh/sredir?uname=apbloom&target=ALBUM&id=5295023877678 150465&feat=embedwebsite"></a></td></tr></table>
    Apr 2005
    dude...that's my bike right there, exactly what I'm planning to do.
    Thanks for posting that shot.
    Quote Originally Posted by huevos View Post
    @Celt you are obviously a man of outstanding pedigree and taste. Have some Rep.
  1. Lynskey Ridgeline Dropout question SS/Geared??
    By Socialed in forum 29er Bikes
    Last Post: 05-15-2010, 04:46 AM
  2. Geared for Climbing Question
    By Trent R. in forum 29er Bikes
    Last Post: 04-28-2010, 08:16 PM
  3. Chameleon Question - Geared Setup
    By glueslug in forum Santa Cruz
    Last Post: 05-14-2007, 10:33 PM
  4. Bonty SS vs Geared Question?
    By RickMabus in forum Vintage, Retro, Classic
    Last Post: 04-02-2006, 03:05 PM
  5. Question for geared Crosscheck owners..
    By Pigtire in forum 29er Bikes
    Last Post: 09-30-2004, 09:01 AM
