Results 1 to 22 of 22
    Jun 2014
    ECR - Rack 'em up
    Hi all,
    I'm wondering what my options might be for putting racks on my ECR. Personally, I'm looking for more minimalist racks to support the weight of big saddlebags and such - not to carry panniers. But, if we're talking racks, feel free to add the bigger ones to.
    Some online scouring reveals the following racks do work
    Tubus Vega - great piece on it, looks too tight for knards though..
    Old Man Mountain Sherpa - another detailed piece
    Possibles
    I've seen references to Nitto (Marks rack) and Bontrager (unnamed) but no positive IDs.
    Won't work
    Tubus Duo - see ECR main thread
    If you know something, please chime in. Thanks!
    Nitto R-10
    I put a Nitto R-10 on my Karate Monkey, and have since moved it over to my Pugsley. I use it to support a Carradice Camper Longflap. It's a really nice minimalist rack. No clearance issues on either bike.
    https://www.benscycle.com/p-2107-nit...ear-rack.aspx?
    Spinymouse
    11 KM SS
    13 CC Rando-Check
    13 Pugsley
    Jun 2014
    Huge Fans of Old Man Mountain Racks for the Surly ECR
    Mar 2014
    I'm not a fan of the OMM racks. That rear rack sits way out in space...going to load the bike a bit oddly.
    Nice Racks sure as hell aren't minimalist, but they're great and the fit very well. I've had the rear version mounted both front and rear, and it works great - solid, level, quiet and has supported a weeks worth of groceries in panniers with a 12 pack bungie netted on top.
    off topic, glenngineer, can you take a picture a close up picture of your front fender. i'm just curious it was attached. thanks
    Jun 2014
    Will play around with the Surly Rack today, my experience on the trail is they want to rattle loose so tug nuts and extra tug nuts are a must.
    I also did two trips with the Salsa Down Under (HD) but didn't like two things - felt the load was to far forward so it affect handling and for riding on single track with brush the panniers sit so low you have to really be careful to not get "caught in the bushes"
    What I have discovered is the Ostrich Rear Saddlebag makes an awesome front handlebar bag on the Jones bars so have been going that route over a front rack
    Mar 2014
    Quote Originally Posted by pokerface View Post
    That's a Planet Bike Cascadia 29er. It's too damn small for a 3" tire, but it does alright.
    There are two issues with the stock installation - the fender stays are too thin and cause the fender to wobble, and metal arms that join the actual fender to the stays position the upper stay eyebolts in such away that they tend to rub the tire. These problems exasperate each other.
    To get firm up and quiet down the fender, I bent the mounts on the fender itself out, and replaced the eyebolts with some 5mm eye bolts from Velo Orange. I replaced the fender stays with 303SS 5mm stock I had, cut and bent in a vice to fit. I joined the new stays to the fork mounts with R clips, again from Velo Orange.
    The 5mm stay is vastly stiffer than the roughly 3.5mm stock stay, and the modified connection to the fender itself keeps the eyebolts out of the way.
    Velo Orange parts:
    Eyelet Bolts, 5mm, Pair Closed-type - Fenders - Accessories
    VO R-clip 4-pack - Fenders - Accessories
    Pictures:
    I still have fantasies of widening the fenders by 20-25mm like a few over our fatter friends have, but I know I don't have the steady hand to do it with a razor or dremel cleanly, and I don't have a band saw.
    glenngineer, thanks. ingenious. i'll try to set my cascadia like yours.
    Mar 2014
    Thanks man. I do the same thing out back, I just pulled it off to mess with my wheel position a bit. I also added a modified rack stay I had laying around to stiffen up the rear even further, I drilled a few holes in the fender and zip tied the stay on, then bolted the stay to the center cylindrical boss on the rear rack. Rock solid.
    Old Man Mountain racks fit front and back very well. Big O Manufacturing makes fenders for the ECR/Krampus. Battery not included.
    ECR
    ECR is offline
    carfree
    Sep 2013
    Another Tubus Vega here and it is a tight fit with Knards on Rabbit Holes. In my case, if wheel was not perfectly true, at max PSI I got minor rubbing with unworn side knobs where the wheel was not true. With a true wheel and/or less pressure the rubbing disappeared. I imagine a narrower wheel may not be quite so tight, but I really like the narrow profile of this rack.
    Reputation: vaultbrad's Avatar
    Oct 2007
    ^Great looking bags. What are they?
    ECR
    ECR is offline
    carfree
    Sep 2013
    Quote Originally Posted by vaultbrad View Post
    https://www.frostriver.com
    Reputation: backcountryeti's Avatar
    Quote Originally Posted by ECR View Post
    Great looking bike! Canvas looks perfect on the ECR. Well done.
    Reputation: jaru's Avatar
    Aug 2014
    edit
    Aug 2014
    Quote Originally Posted by Glenngineer View Post
Name:	2014-06-23 20.55.18.jpg
    How did you manage to get your 'nice' rear rack level if I may ask? I'm having a hell of a time with the back rack and a medium sized ecr ... my provided struts are just too short!
    Mar 2014
    I didn't do anything, but I am on a large frame
    That raises the stays and brings the rack eyelets closer to the rack, making fit easier compared to the medium frame.
    I'd fab longer rack stays out of steel tubing-cut it to length, crush one end in a vice and drill a mounting hole through the crushed faces.you'd probably need to do a bit of grinding to make the crushed end clear the frame, but it'd be an easy enough job.
    If you don't mind spending a few dollars, you can get factory-made long rack struts. Nitto ones are available in up to 350mm length. I'm not sure how that compares to the length of the ones you're having trouble with.
    https://www.benscycle.com/p-2106-nit...ruts-pair.aspx
    Other brands and sources may also be available.
    Good luck.
    Spinymouse
    11 KM SS
    13 CC Rando-Check
    13 Pugsley
    Aug 2014
    Tha'ts an idea actually.
    I'm not a fan of the stainless steel look anyway. Could make myself some black ones.
    Quote Originally Posted by Spinymouse View Post
    Good luck.
    350mm! Jeez they are huge, would more than do the job!
    Thanks.
    Dec 2016
    Big O fenders + ECR installation tips?
    I bought a set of the Big O fenders based on your post here. They look great! Do you have any installation tips, or can you point me in the right direction to where I can find some? Much appreciated!
    Dec 2016
    Quote Originally Posted by pwd81 View Post
    Hi pwd81, I bought a set of the Big O fenders based on your post here. They look great! Do you have any installation tips, or can you point me in the right direction to where I can find some? Much appreciated!
    Ambassador of Chub
    Reputation: Smithhammer's Avatar
    Jul 2015
    I would also put the Blackburn Outpost Fat Rack on the list. I have one, and while I haven't used it on my ECR yet, the rack is adjustable in width to fit anything from 2.8" up to 5" and I found it to be very solid with a load riding off-road. Easy and straighforward to mount and remove as well.
    "The only way we can truly control the outcome of a ride is not going on it, which is a choice I'm unwilling to make." -K.B.
  1. Roof rack or hitch mount rack for Ford Escape?
    By Birdymkr in forum Cars and Bike Racks
    Last Post: 04-08-2014, 09:44 AM
  2. OMM Skewer rack, or weld stand offs for a rack?
    By The.Dude.Abides. in forum Bikepacking and Bike Expedition
    Last Post: 02-25-2014, 05:26 PM
  3. Rack on an El Mariachi? Moose rack for Burly Picolo
    By jh_on_the_cape in forum Salsa
    Last Post: 02-24-2014, 08:52 AM
  4. Rhino-Rack Discovery Roof Rack Bike Carrier
    By Doug_ID in forum General Discussion
    Last Post: 04-18-2012, 07:54 AM
  5. Honda Fit Sport: Hitch Rack or Trunk Rack?
    By EVERYUSERNAMEISTAKEN in forum Cars and Bike Racks
    Last Post: 07-18-2011, 12:48 PM
Members who have read this thread: 15
