Results 1 to 6 of 6
    Cross Check single speed rear hub 130 vs 135
    Hi all, I will be getting a CC frame soon. What are the pro's and cons of the 130 vs 135 width rear hubs. I want to build wheels with the Velocity A23 rims and Surly hubs.
    Thanks, MikeB
    Given the choice, I go with 135 hubs. Disc hub with rim-brake compatible rim for max swap-ability between frames that take 700/29er wheels.
    135 will have slightly less dish...really negligible though.
    You've already chosen your hubs, but one benefit of 135 hubs is the greater number of options to choose from.
    Oh noes. I'm going to drink the Kool-Aid.
    Agree 100% with jcaino
    Positively negative
    Personally I used a 130 hub and just respaced it to 132.5. You could do the same with a 135 but you have to pay more attention to the axle protrusion.
    I think it more comes down to useage. 135mm are generally for MTBs and thus better sealed, a 130mm road hub may save you a few grams.
    Go with 135mm. It'll spread the chainstays out and give you a little more tire/fender clearance.
    Surly Cross Check: fat tire roadie
    Surly LHT: Kid hauler
    On One Inbred: SS 26er
    Thanks for the help, I have been checking out the Straggler. May go that way. Decisions, decisions.
  1. wanted, rear single speed cog
    By zukrider in forum Colorado - Front Range
    Last Post: 11-14-2012, 08:33 PM
  2. Single Speed rear tire. What do you run, and why?
    By HotRodTodd in forum Singlespeed
    Last Post: 08-19-2012, 06:31 PM
  3. Replies: 37
    Last Post: 12-17-2011, 10:16 PM
  4. Replies: 12
    Last Post: 09-17-2011, 04:19 PM
  5. Surly Cross Check Single Speed Rear Cog Set-up Help
    By tenacean in forum Beginner's Corner
    Last Post: 08-23-2011, 06:12 PM
