Page 20 of 28 FirstFirst ... 10161718192021222324 ... LastLast
Results 951 to 1,000 of 1359
  1. #951
    Oct 2012
    Quote Originally Posted by ohcaras View Post
    Very nice!
    What is that strapped to your top tube?
    TiGr bike lock... Also a Zefal HPX frame pump which is hard to see in the picture.
  2. #952
    achiever
    Reputation: redwarrior's Avatar
    Quote Originally Posted by evandy View Post
    No argument here....
    Attachment 876165
    What are you running for a generator hub? And the light?
  3. #953
    Reputation: FatCloud's Avatar
    May 2013
    Quote Originally Posted by redwarrior View Post
    Here's the latest iteration of my Cross Check.
    46cm frame
    Rival 48/34 crankset
    older XT rear derailleur
    Tiagra front derailleur
    105 9spd brifters
    Salsa Cowbell 3
    Velocity A23's on Ultegra hubs
    Clement MSO 40's (could not get them to set up tubeless )
    Tektro CR720's w/ Koolstop salmon pads
    haven't had a chance to ride it yet this way yet-need to throw on some fenders & I'll be able to get out this weekend
    CC by m2phast, on Flickr
    Prior commuting set up from a few years back:
    crosscheck by m2phast, on Flickr
    How are those Kool Stops treating you up front? I found they gave me too much fork chatter. The only way I found I could increase stopping power was with Mini Vs, then my nerdy techy friend went off about Avid Cantis and how much he loves them on his racing rig.
    OH and his non-racing rig is this;
    SFR Russian River 300k by Worn Treads, on Flickr
    His is the one in back with pink tape. Mine's the one with fat tires and midge bars.
    Some X-Check on X-Check porn.
  4. #954
    achiever
    Quote Originally Posted by FatCloud View Post
    I haven't ridden with the Kool Stops yet. I should be able to get out Saturday & it's going to be a sloppy mess of a ride up here in the Northeast.
    I've got the set up with a good amount of toe in so I imagine that they'll work ok...
  5. #955
    Reputation: ohcaras's Avatar
    Mar 2011
    Trying to decide where to cut the steerer tube on my new fork. I've got about 30mm of spacers under the stem right now and the test fit seems good. The bars are a tad under the seat and it feels good. I haven't actually ridden it this way so I want to leave me some room for adjust-ability just in case I decide I don't like the position. I was thinking that leaving a total of 50mm (~2 in.) would be ok, does that seem acceptable? I'd start out with a 30 mm stack below the stem and use the other 20mm of spacers above, and switch accordingly.
    Looking at a lot of the pics in here, it seems like a lot of people use tall stacks under the stem and have the bars set just a bit above the seat height. Am I overthinking this? I'll be chopping it later at the shop so just want to be sure.
  6. #956
    I would be on the safe side and go up another inch or two. I think I have 40-50mm under the stem and wish I had left another 10-20mm more. But worst case, you buy another fork and sell yours, so shouldn't be out that much.
    redwarrior - I also just put Salmon pads on the CR720's. I haven't ridden them yet, either. Hopefully not a lot of chatter.
  7. #957
    Oct 2012
    The hub is the current Shimano Alfine... 3N71, if I remember correctly. There are a couple models that change around based on disc brakes / etc.
    The light is the Bausch & Meuller Luxos B. Fantastic light that I would happily take anywhere. Super bright, wide beam pattern, built in standlight. I've read some good things about the new Schmidt Edelux 2 as well, although I haven't seen it in person.
  8. #958
    achiever
    Cross Check pics please
    Nice. A local framebuilder uses Supernova hubs, lights & I've seen him recently use a USB charger stem cap thingy from them as well. Really nice stuff.
    Got out in the slop today & the Kool Stops generate some fork chatter but nothing I'm concerned about -can't actually really feel it.
    I really like the Cowbells & brifters. The bars are 44's & I'm coming off 46 woodchippers so the flat top feels really narrow but the hoods are great. Have to say I prefer the drops on the woodchippers, though. They just feel natural. I'm going to ride the cowbells for a few months & see if I want to go back to the woodchippers after I've given these a fair shake.
    All that said, I love this bike! I better -it's got to get me through D2R2 (http://www.franklinlandtrust.org/epic.html) which was actually the plan when I built originally built it up in 2010.
  9. #959
    One Colorful Rider
    Reputation: Normbilt's Avatar
    St Fatties Day Ride
    Fatties Fit Fine
    <iframe src="https://www.flickr.com/photos/33936975@N00/13218525094/player/" width="480" height="640" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
    <iframe src="https://www.flickr.com/photos/33936975@N00/13218523964/player/" width="640" height="480" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
  10. #960
    Dec 2013
    Here's mine, third incarnation of it. Started with downtube shifters, these bars and road tyres. Then it became a road bike with mostly DA9 speed.
    This setup allows me to switch bars to drops (VO thumb shifter mounts), but I don't think I will for now.
    The current setup is for some light gravel riding and a race I am entering. The DA groupset got transfered to a NOS caad2 cannondale.
  11. #961
    Reputation: seat_boy's Avatar
    Nice looking build! I like the flat bar CCs.
    Quote Originally Posted by Kabouterwesley View Post
  12. #962
    Tires?
    Which tires are those?
  13. #963
    Reputation: Bullit_cn's Avatar
    Quote Originally Posted by patirwin View Post
    If you click the photo,
    The tires says "furious fred"
    Not sure what size though ;-)
    When trails gets tougher, Just stand up and deliver.
  14. #964
    Quote Originally Posted by seat_boy View Post
    Like the colour too,
    Might as well retire my black CC and have it repainted something similar :-D
  15. #965
    Reminds me of this build:
    Not mine
  16. #966
    Mar 2011
    Anyone buy a complete cross check and upgrade the wheels? I'm looking for a cheaper set for nasty weather commuting duty, let me know.
  17. #967
    Dec 2013
    As mentioned already: Schwalbe Furious Fred indeed.
    size is 29x2.00, fit is similar to big apple/fat frank etc., but with some knobs.
    very fast and light. Nightmare to get on the rims.
  18. #968
    Mar 2011
    Quote Originally Posted by Normbilt View Post
    St Fatties Day Ride
    Fatties Fit Fine
    Let's see some pics of the whole bike!
  19. #969
    Ergon GC1 + On One Fleegle = Love.
  20. #970
    Quote Originally Posted by nameresu View Post
    Nice bike! Love my Fleegle too - just enough bend to be comfy, but not too much.
    Surly Cross Check: fat tire roadie
    Surly LHT: Kid hauler
    On One Inbred: SS 26er
  21. #971
    Reputation: jesusburger's Avatar
    Another Auckland tourism commercial brought to you by Surly. Put my old 35c touring tyres on the MonsterCheck after three years riding fat. Man, sure feels fast on pavement but I'll be swapping back when (if) it ever rains down here.
    I'll post smaller shots as the Flickr links seem to distort if you're not logged-in to MTBR.
    My "work-stand"
    <a href="https://www.flickr.com/photos/79498713@N00/13071244333" title="Workstand by Antoine, on Flickr"><img src="https://farm3.staticflickr.com/2197/13071244333_2601362811_z.jpg" width="640" height="427" alt="Workstand"></a>
    Deep under North Head in the old military tunnels.
    <a href="https://www.flickr.com/photos/79498713@N00/13417051443" title="Tunneling by Antoine, on Flickr"><img src="https://farm4.staticflickr.com/3767/13417051443_7b89e8f377_z.jpg" width="640" height="427" alt="Tunneling"></a>
    Riding singletrack down Mt Victoria.
    <a href="https://www.flickr.com/photos/79498713@N00/13395233873" title="Tourist On The Singletrack by Antoine, on Flickr"><img src="https://farm3.staticflickr.com/2839/13395233873_bbe5566402_z.jpg" width="640" height="427" alt="Tourist On The Singletrack"></a>
    Standing on a volcano looking at a volcano. (Rangitoto, only 600 years old)
    <a href="https://www.flickr.com/photos/79498713@N00/13397455965" title="Need / Rain / Bad by Antoine, on Flickr"><img src="https://farm4.staticflickr.com/3743/13397455965_eb7fcf23ca_z.jpg" width="640" height="427" alt="Need / Rain / Bad"></a>
    Entrance to the WWII generator rooms on North Head.
    <a href="https://www.flickr.com/photos/79498713@N00/13395573915" title="Military Decay by Antoine, on Flickr"><img src="https://farm8.staticflickr.com/7436/13395573915_27598a7e45_z.jpg" width="640" height="427" alt="Military Decay"></a>
    Yellowy green patch of grass was Mt Cambria (volcano) before it was mined away.
    <a href="https://www.flickr.com/photos/79498713@N00/13348342795" title="City Of Volcanoes by Antoine, on Flickr"><img src="https://farm4.staticflickr.com/3826/13348342795_d0980256f5_z.jpg" width="640" height="427" alt="City Of Volcanoes"></a>
    Some very "NZ looking" Manuka Tree bush.
    <a href="https://www.flickr.com/photos/79498713@N00/13135672693" title="Trail through the Manuka Trees by Antoine, on Flickr"><img src="https://farm4.staticflickr.com/3696/13135672693_ed9b4e0849_z.jpg" width="640" height="427" alt="Trail through the Manuka Trees"></a>
    The new Flickr interface really sucks balls, but I have a lot of cycling shots in my photostream if you're interested:
  22. #972
    Reputation: chefmiguel's Avatar
    Wonderful pictures, calling travel agent now.
    Technology dragass
  23. #973
    jesusburger - nice pics! looks like some awesome riding. what handlebars are you running? Midges?
  24. #974
    achiever
    A couple from my ride today.
    That guy by m2phast, on Flickr
    Up above it by m2phast, on Flickr
  25. #975
    Reputation: drmayer's Avatar
    Commuting mode (minus rack)
  26. #976
    Mar 2011
    What size tires are you running? Did you have to modify the fenders to get them under the v brakes?
  27. #977
    Cross Check has no problems running v-brakes and fenders. No modifications needed. Not sure about the mini v-brakes.
  28. #978
    Mar 2011
    Gotcha. I assumed those were minis, couldn't tell from the pics. I have a mini v tektro on the rear and had to do a little modification so that my Knard wouldn't rub the brake when applied. There's definitely no room for a fender there.
  29. #979
    Ariolimax columbianus
    Reputation: nativeson's Avatar
    Apr 2005
    My cobbled cxcheck always faithful. Cross Check pics please-imageuploadedbytapatalk1397095795.790168.jpgCross Check pics please-imageuploadedbytapatalk1397095823.123663.jpg
    Backyard poseur shots.
  30. #980
    Sweet! You need some white wall tires to complete the bobber look.
  31. #981
    Reputation: dfltroll's Avatar
    I've used Schwalbe 700x38 Marathons with SKS P45 fenders with no special modifications. I tried to fit 41 Knards with fenders and it was a no go without lots of fender futzing and a crappy fender line.
    All good expeditions should be simple in concept, difficult in their execution and satisfying to remember--Alastair Humphreys
  32. #982
    My CC back in utility mode:
  33. #983
    Short 14 miles road/3 miles dirt ride today.
  34. #984
    What handlebars are you using?
  35. #985
  36. #986
    Quote Originally Posted by mpw29er View Post
    [IMGhi mate nice ride ]http://img.tapatalk.com/d/14/04/25/a4asumym.jpg[/IMG]
    Hi mate nice ride is that the new Brooks Cambium saddle? If so how does it ride?
    Regards.
    Stephen.
  37. #987
    Quote Originally Posted by Surly in OZ View Post
    Regards.
    Stephen.
    The cambium is great. I've had a B17 in the past and I much prefer the cambium. It doesn't really have a break in period and feels very comfortable.
  38. #988
    Oct 2013
    he doesn't care about my other bikes at all, but he loves my cc.
  39. #989
    May 2012
    Quote Originally Posted by phsycle View Post
    are those BG R&R tires? how you like em? 43c's clearance good?
  40. #990
    May 2013
    SFR Fleche by Worn Treads, on Flickr
    Cross Check coming out of Yosemite during my Fleche run.
  41. #991
    Quote Originally Posted by boogman View Post
    No issues with clearance. Bit tight to get it to fit between the brake pads when mounting the wheel, though.
  42. #992
    Reputation: aegolius's Avatar
  43. #993
    Today's ride. Stopped at one of the ponds near my home.
    You can't see them in the picture, but the black flies were swarming pretty bad.
    Good motivation to get back on the bike and scoot as fast as I could, even though the sun and the air were telling me to hang out at the pond for a bit.
    Spinymouse
    11 KM SS
    13 CC Rando-Check
    13 Pugsley
  44. #994
    Jun 2012
    How well do those BG R&R tires work on road and off? Slow on road? Grip in gravel?
  45. #995
    Feb 2012
    here's mine these days, the xcheck is fast becoming my go to bike, love it!
    Love the R&R's, just got them on, roll nice on road and grippy on dirt.
  46. #996
    Not a fast tire on the road or on rugged trails but not complaining as its probably more of a rider issue than a tire issue. Off road it's not for every trail but smooth single track, gravel paths it's perfect.
    Technology dragass
  47. #997
    Oct 2012
    Here's my CC. Enjoy.
  48. #998
    Nice!
    Cool CC. Where's that pic taken from? Looks familiar...
  49. #999
    Oct 2013
    it was on the surly blog:
    Remember That One Bike, That That One Guy Had? | Blog | Surly Bikes
  50. #1000
    Jun 2012
    Hey, do any of you know of any good 26mm clamp stems for 1/8th steer tubes? I know there are some really pricey ones and some kind of cheap crappy ones, but what about high quality ones that aren't $100?
