Results 1 to 8 of 8
    Mtn View, CA
    Reputation: gddyap's Avatar
    Converting old 1x1 hub to QR
    Not much interest in the SS forum so I figured I'd cross post here. You guys might like it.
    I have an old Surly 1x1 rear hub that uses axle nuts. My bike has vertical dropouts and I would prefer to use a QR instead of having to bring a wrench to remove the wheel to fix a flat. This particular hub uses a proprietary Surly axle so there isn't anything available to convert to QR. Their current hubs can be converted. So I decided to do it myself. I had been thinking of doing this for a long time.
    Here is the hub. Surly 1x1 with a Rhinolite rim. I use a Shimano freewheel.
    Axle removed. Other bearing is still in hub.
    Hub with bearing removed.
    I determined that the axle length needed to be 145mm (135mm drop out spacing plus 5mm per side) so I had to cut it to length. I rough cut both ends with a Dremel to get close to 145mm and then chucked the axle in my mini-lathe to cut and face to final length. Added a chamfer to the threads to make it easier to install the bearing nuts.
    I don't have a drill long enough to go all the way through the axle so I have to drill halfway through both sides.
    Chamfer the hole
    Axle and bearing installed
    Freewheel and Salsa QR
    I have come here to chew bubblegum and kick ass... and I'm all out of bubblegum.
    Reputation: slimhazy's Avatar
    I saw that 4th picture and said to myself, "there's no way he's going to drill out that axle" - but you did!
    Bravo.
    Rhymes with fartmaster
    Wow, nice work!
    Awesome!
    Reputation: SSSasky's Avatar
    Super nicely done.
    Fat boy Mod Moderator
    Reputation: donalson's Avatar
    wow very nice work... amazing what you can do when you've got the right tools
    - Surly Disc trucker
    - '82 trek 560 roadie
    Dec 2010
    May be a dumb question, I don't know so that's why I'm asking. Aren't the axles heat treated from the factory? Do you have to re-heat treat the axle after drilling it? Will that affect the strength at all?
    Nov 2008
    Super cool. Makes me want a lathe!
