Results 1 to 3 of 3
    FAT-BIKE.COM Groupie
    Reputation: deleteyourselph's Avatar
    Changing shifters on my Crosscheck
    So I have given my bar end shifters a fair go, and surprisingly I'm not too disatisfied. I just scored some 105 brifters pretty cheap, so now I have the urge to put them on. Here's where I'm clueless. I was told all I would need is a 10 speed cassette. Supposedly these 105 5600 shifters are 10 speed. When I shift the entire brake lever (mimicking shifting to an easier gear) I only get 9 clicks. My only other thought is, is there only nine clicks available because your chain is always on "a" gear, so you only have nine other available cogs to shift to? I hope so, because otherwise I was had. Either way, I want to make sure before I start ordering other parts. I figured on a cassette and rear derailieur, although my lbs said the deore long cage derailieur would work fine. I'm not quite sure what would make some pick between a short/medium/long cage der. I had a Trek 2.3 that I enjoyed the gearing on.
    Trek 2.3
    50/34 and 12-30
    My Cross Check
    36/48T and 11-32T
    Either way, what would be a good compromise? I can't afford a new crankset right now, but I could probably afford the cassette and a rear der if I have to. I'll probably get a 105 crankset, front and rear der. eventually anyways. Just looking to get going soon is all. I was figuring on getting a 11-28 cassette. I'm assuming I'll have to get new front chainrings. Just looking for a little guidance/input is all. Thanks in advance!
    Oh yeah, the barends aren't going to waste. They will be going on my Pugs before winter hits.
    "You don't cross my ***** line, I don't cross your ***** line".
    - James Lahey Sunnyvale Trailer Park Supervisor
    Reputation: Bald_Ben's Avatar
    May 2005
    5600 is a 10-speed group.
    If you want to match the gearing of your other bike, try playing around with this:
    Sheldon Brown's Bicycle Gear Calculator
    Quote Originally Posted by deleteyourselph View Post
    Correct
    10-click-9-click-8-click-7-click-6-click-5-click-4-click-3-click-2-click-1
