Results 1 to 5 of 5
    Reputation: Johnny LaRoux's Avatar
    Aug 2005
    Campy Veloce/Centaur on Cross Check?
    I've just bought a Cross Check frame, and am anxiously awaiting it's arrival! I have a full Campy 9 speed Veloce drivetrain with Centaur cranks and 102mm bb, and I'm wondering if the cranks will have enough clearance for the chainstays. I guess I can find out the hard way by installing everything once the frame arrives, but has anyone experienced running this type of set up on a Cross Check?
    If worse comes to worse I'll pick up a different crank and BB, probably a touring triple, or something of that sort, but if I can get it on the road with the Campy, all the better!
    102 sounds like track-length. I would think 111 would be the more appropriate size?
    Aug 2005
    Quote Originally Posted by dankilling
    My mistake...yes, it is 111mm. I think some old Record and Chorus came 102 as well.
    Reputation: bikewrench's Avatar
    Nov 2006
    I have a Cross Check w/ Campy Veloce 10sp that is my do all bike. It's a good time. There is a pic in the owners thread.
    I turn a wrench @ Simplicity Cycles
    http://www.simplicity-cycles.com
    111 should be fine
