Results 1 to 10 of 10
    Big Dummy and Bill... Best Friends Forever!
    It's based around a studded heim joint. Pulls like its not even there. Zero play connection. Perfection.
    Attached Thumbnails Attached Thumbnails Big Dummy and Bill... Best Friends Forever!-bigdummyandbill.jpg
    Reputation: GrampBredo's Avatar
    Looks nice, I wonder if there's a particular reason for such a long arm?
    Quote Originally Posted by GrampBredo View Post
    The longer the arm the less the angle is on the heim. You could easy get away with half the length but it really makes no difference besides that angle.
    That's awesome.
    Reputation: mattbryant2's Avatar
    Apr 2005
    Yes!
    May 2010
    Want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want want.
    I like it.
    Nice! Load that baby to the gills and take more pics!
    Dec 2010
    The problem with that mounting position is if you load up the trailer with heavy gear then you could have problems with front wheel lift or odd handling, but im sure you know that anyway, its all right if your making sure you keep heavy loads over the trailer axle i suppose.
    Quote Originally Posted by dickyelsdon View Post
    Considering the length of the the Big Dummy, my 195lbs, this is a complete non-issue. The amount of weight required to lift the front end to where it would not be rideable is enormous. There just isn't a long enough lever with the trailer to make it matter.
    And the proper way to load a trailer is over the axle. That's how you load a trailer. Surly even specifies a 300 pound weight limit with a 50 pound tongue weight.
    wants a taco
    Reputation: nubcake's Avatar
    Nov 2007
    I am considering getting a bill to be pulled behind my xtracycle as well but was thinking of a way to make it work. If I pull the trigger at some point on the bill do you have any interest making another one of these to sell for profit?
    Just another cycling blog...
    The Long Way Home
  1. Big Dummy makes me smile like a Big Dummy...
    By lawfarm in forum Cargo Bikes
    Last Post: 08-26-2010, 07:14 PM
  2. Replies: 2
    Last Post: 10-15-2008, 05:13 PM
  3. Replies: 18
    Last Post: 10-10-2008, 07:22 PM
  4. helicopter bill, $24k. hospital bill...
    By fc in forum California - Norcal
    Last Post: 06-30-2006, 04:52 PM
  5. Replies: 46
    Last Post: 06-29-2006, 12:33 AM
