Results 1 to 16 of 16
    best brakes for Pacer
    Dear all,
    I just built up my new Pacer using some parts from my old road bike, including a pair of 105 brakes from around 2003. However, after I got used to my SD7 brakes on my crosscheck, I really lost confidence regarding the stopping powers of the 105. What is a good alternative for the Pacer? Obviously, I canīt use SD7...
    best,
    Reputation: vaultbrad's Avatar
    Oct 2007
    If I was going for "best" I'd be very tempted by the Paul Comp centerpulls. I'd choose silver.
    wow, those are indeed nice brakes. However, the come at >100 USD per piece :-( Any cheaper options out there?
    you could try mini-Vs (they work w/ any lever).
    Hi Hardy,
    problem is that the Pacer doesnīt come with a frame prepared for those sort of brakes...
    Best is the Paul's. Everything else is just meh. My road bikes have brakes that work, but they're not my discs and they're not like my Avid Ultimate canti's either. Just get the Paul's.
    Kaishingo
    Reputation: wuzilla's Avatar
    The Pauls come in a centermount version (to fit a pacer).
    Now if you don't feel like dropping that kind of dough...I put Tektro R-538's on my wife's Casseroll. Excellent stopping power on the steep dirt-road pitches we ride, and the q/r allows her 35mm tires to pass with no prob. I was planning on putting the same brakes on my Pacer (however, all that eye candy above has me rebudgeting)
    Quote Originally Posted by wuzilla
    Yeah, which is why somebody suggested them?
    The point about 'the frame not being prepared for those type for brakes' was responding to the suggestion of mini-Vs. The Pacer won't accept mini-Vs.
    Reputation: jesusburger's Avatar
    I'd try some new Kool-Stop pads before you splash-out, especially if your existing pads are old (i.e. hard).
    x2 on new pads- either Kool Stops or SwissStop of you can find them. Also, better brake cables/housings will improve the feel and power as well.
    Tektro 538 and Paul Racer M brakes
    I have had both the Tektro 538 and the Paul Racer M brakes on my Pacer (not at the same time), and both work just fine. The Tektro 538 brakes are astoundingly nice for the $50-60 retail price per pair. Throw on some Kool-Stop pads for $14-15, and you have a very nice set up. The long-throw quick release is especially cool, especially if you are using 28+ mm width tires.
    I went nuts one dreary winter day and ordered a set of Paul Racer M brakes in "High Polish" finish. I have fenders (35 mm wide Planet Bike Hardcore) on the Pacer, and the dual-pivot Tektros would push the front fender over to the side a bit when engaged. This, of course, was totally unacceptable! So, for a mere $200 more than the Tektros cost, I have a beautiful set of Paul Racer M brakes and the front and rear cable hangers needed for center-pull brakes.
    The Pauls are stunning in appearance, and they work just fine, but I can't really say they stop any better than the Tektros. My front fender, however, stays stock-still when the brake is engaged. Of course, having a brakeset that cost me about 2/3s of what I paid for the Pacer frame is pretty crazy. But, what the heck, it's only money.
    You can't go wrong with either option, but on a bang-for-the-buck basis, the Tektros are hard to beat.
    Dale
    Bang-for-buck it is! I guess I will first get some good new pads, and if still not enough I will go for the Tektros...Paulīs look very nice, but for the moment thatīs not the budget Iīm looking for...
    best,
    Reputation: Hand/of/Midas's Avatar
    Quote Originally Posted by brettsportler
    best,
    So get some pads, and put the money you save into a Paul Brake Futures Fund.
    Just to let you know, I installed some new Kool stop pads (the salmon-colored ones), and it's an amazing upgrade in braking power! So far, no need for fancy Paul's...
    Reputation: Iron_sparthan's Avatar
    Take a look to TRP pivot brakes. Totally made by cnc.
    Quote Originally Posted by Iron_sparthan View Post
    by Tektro Racing Products, nice stuff indeed.
