Results 1 to 5 of 5
    Bar-end shifters and brake levers (X-post with Cyclocross forum)
    I am building up a Cross Check with a Salsa Woodchipper Bar and trying to understand what I need to order as shifter and levers.
    My questions to the ones who already have experience with this kind of build are:
    - What Cane-Creek SCR-5 levers (regular or compact) will better fit my hand/bar combo? My hand size is a large in most of the glove brands.
    - Will the Dura-Ace SLBS77H 7700 9 speed bar-end shifters work with any 9 speed Shimano rear derailleur?
    Franz
    Franz:
    I will give it a shot (see bold text within your quote area):
    Quote Originally Posted by fb71 View Post
    I don't (yet) have a Woodchipper on any of my bikes, but I have a similar bar (WTB mountain drop) and have similarly sized hands -- I'd say go with the regular size SCR-5 levers. That's the size I have on a couple of bikes. It's a nice lever.
    This one is easy -- YES! I have those shifters working Shimano 9 speed road and MTB rear derailleurs on a couple of bikes.
    Franz
    Hope my answers are helpful to you! Sounds like a great bike you are building.
    Dale
    Reputation: pedalmunky's Avatar
    I don't have a Woodchipper either, but I do have a dirt drop bar as well - the Gary 2. No CC SCR-5's either, but I'm running Tektro 520's. For whatever it's worth, I really like my setup. And I'd say go with the regular sized levers instead of the compact.
    I also happen to run those DA bar-end shifters and love them. They're precise, easy to adjust, and since I'm usually in the drops, fairly easy to reach and actuate. I run them with an old XTR 9 speed der I had in my spare parts bin, and they've been spot-on since day one.
    I'd suggest you trying to route the housing up along the bars under the tape, exiting by the stem. I ran them traditionally at first, looping out under the bar-ends to the shifter bosses on the downtube. After a few months, the cables flapping around down there started to bug me, so I re-routed them under the tape. Looks much better and shifts just as well.
    All mountain bikes are all-mountain bikes.
    Thanks for your help. I'll post pictures once it's done.
    TrinityRiverKerplunk
    On my CC I use older Cinelli bar and stem combo. I can't answer your question about bar set-up, but I do use the DA bar ends as well, but with a 1987 Shimano 600EX shortcage RD. This is 9spd, btw.
    I ended up drilling holes in my bars so I could run them internally. No messy housing to deal with.
    Good friction shifting is getting hard to find nowadays....
  1. Replies: 2
    Last Post: 11-22-2011, 03:24 PM
  2. Shifters and brake levers for Nexus 7
    By matt_outandabout in forum General Discussion
    Last Post: 05-02-2009, 06:43 AM
  3. LBS wants $95 to instal two brake levers and 2 shifters
    By whenimsixtyfour in forum Beginner's Corner
    Last Post: 02-14-2009, 09:00 PM
  4. Anyone mounting shifters outside the brake levers??
    By bc3 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-02-2008, 05:13 PM
  5. Grip shifters and brake levers
    By hastabnasta in forum Women's Lounge
    Last Post: 05-18-2007, 04:18 PM
