Results 1 to 53 of 53
    Reputation: Iron_sparthan's Avatar
    New question here. Adventure Bike on 2014 Surly lineup maybe?
    At first I'm sorry if my english is really bad. I've read about new fat bikes for 2014 and 2 new bikes coming.
    Would be nice ad Adventure Bike like the Salsa Fargo in Surly line up.
    Could be this one of the two new coming?
    What do you think?
    Every Surly bike is an adventure bike!
    Jason
    Disclaimer: www.paramountsports.net
    Quote Originally Posted by JAGI410 View Post
    Amen!
    Surly Cross Check: fat tire roadie
    Surly LHT: Kid hauler
    On One Inbred: SS 26er
    Mar 2013
    I'm guessing another entry for the "29+" platform? Maybe a touring oriented 29x3 that is designed to hold a campsite's worth of equipment?
    Reputation: dfltroll's Avatar
    That was my first thought.
    All good expeditions should be simple in concept, difficult in their execution and satisfying to remember--Alastair Humphreys
    Sep 2012
    It would be nice to see, and it would hopefully be a bit cheaper than the Fargo. The Ogre, I think, is fairly similar to the Fargo, but designed for flat rather than drop handlebars. I've called them flat/drop cousins of each other.
    One thing I actually prefer about the Ogre (and I myself am a Fargonaut) is the rear dropouts. I want to run an internally geared hub, but the Fargo has vertical drops. The horizontal drops of the Ogre, or even Salsa' s own Alternator drops (as on the El Mariachi) would make this much easier.
    If I had it to do over again, I may have gone Ogre, but I didn't have a shop in town with any in stock, and a pretty little Fargo was staring me in the face for months.
    650b all-mountain monster touring drop-bar specific machine!
    Reputation: vikb's Avatar
    Quote Originally Posted by Iron_sparthan View Post
    What do you think?
    A Surly Pugsley with a second 29+ wheelset is a great adventure bike. It will go anywhere a Fargo will go and a lot of other places.
    If you don't want fat tires the Ogre is Surly's equivalent to the Fargo.
    I'm not sure what else you'd want in an "adventure bike" that the two options above don't offer already?
    Safe riding,
    Vik
    www.vikapproved.com
    Probably 2014 new coming could be ( about me of course):
    - An All Mountain 29er Hardtail like new Niner ROS9 or Kona Honzo
    - A new Instigator 29er or 27,5"
    - An Adventure Bike like Salsa Fargo with shorter top tube and new geometry
    - A Pacer disc
    - A 29+ touring/adventure oriented.
    There's no way around a disc CC this year.
    Reputation: Midtown's Avatar
    Feb 2012
    When do the 2014 model bikes start to roll out?
    mwv
    mwv is offline
    I don't know how they could make any more "adventure" bikes. They seem to have every possibility covered.
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    Quote Originally Posted by dankilling View Post
    Isn't that what a 26" LHT disc is when you do the 650B swap? I've even seen it done with cantilevers.
    A garage full of steel frames means happiness.
    Reputation: jesusburger's Avatar
    Hmmmm
    <a href="http://www.flickr.com/photos/27695619@N02/9243810965/" title="IMG_5965 by Bike Jerks, on Flickr"><img src="http://farm4.staticflickr.com/3775/9243810965_7207ae52bb_b.jpg" width="1024" height="768" alt="IMG_5965"></a>
    ^ aww c'mon now, I was enjoying all the guessing
    Those mini-Knards look awesome
    Quote Originally Posted by XJaredX View Post
    I had seen pictures of the frame (the Straggler?) but not the tires. Cool.
    Does anyone with a good eyeball know about what the measurements of that green bike might be? Obviously I don't expect you to quote millimeters, but does it look more like a Crosstrek geometry or or a LHT?
    At first I thought it to be a 700c LHT with disk brakes. Unsure though.
    Click the photo and look at it on Flickr in its largest size. You can view the rear dropout which is interesting. I'd bet it has the same geometry and sizes as a Cross Check. It does have a fair amount of braze-ons which is cool.
    I'm super stoked on that tire and hope it'll be available sooner rather than later.
    I think a disc Crosscheck is definitely in order (and apparently happening as per above). I wouldn't put a disc Pacer on the list of priorities personally.
    If Surly can shoehorn a little extra tire clearance on the Ogre I don't think another 29+ bike is necessary personally, but maybe that's just because it's not as much my area.
    I would still really like to see a "Sport Trucker" come out with XO1 geometry (basically a LHT with relaxed road geometry and lighter tubing). I really think there's good market for a fun, agile 26" road bike that can fit 2" tires. Or there should be!
    Reputation: FatCloud's Avatar
    May 2013
    You can put drop bars on an Ogre, just get a short riser stem.
    I'd say go with On One Midge bars. I'd even say go with a Troll so you can go anywhere in the world and not worry about replacing that 700c wheel.
    If the 29x3.0 knards are 29(+), are those 700x40 knards 29(-)?
    Reputation: seat_boy's Avatar
    +1 on this, I've been thinking along similar lines. Thorn has the Raven Sport Tour which is kind of like this, but saddled by the Rohloff-only setup. And it's quite expensive for a Taiwanese frame. The Handsome XOXO doesn't run big enough for me
    Quote Originally Posted by LostBoyScout View Post
    Feb 2005
    The 41mm Knards should be useful - if they're not frighteningly expensive.
    Personally, the change I'd like to see most on the CC is a longer front centre, so less foot overlap with the front tyre; I'm about to sell one due to this. Lighter, livelier tubing would be nice too. Otherwise the new frame looks interesting and should sell well.
    Quote Originally Posted by satanas View Post
    ... Personally, the change I'd like to see most on the CC is a longer front centre, so less foot overlap with the front tyre; I'm about to sell one due to this. Lighter, livelier tubing would be nice too. Otherwise the new frame looks interesting and should sell well.
    My CC has annoying toe overlap also. I'm thinking of trying Soma's upcoming low-trail fork when it comes out. That should push the front tire about 2 cm farther forward than the stock CC fork. Other than increasing the fork rake and reducing the head angle, I'm not sure how to reduce the toe overlap problem without making the TT longer. And my CC's TT is as long as I can manage comfortably.
    And yes, I'm well aware of the debate over low trail vs high trail geometries.
    Just what is that green frame that jesusburger posted?
    And the Sport Trucker idea is pretty cool too. I have an XO-2 that's way too small for me. I keep eyeballing it and wishing it were bigger.
    Feb 2005
    It will be interesting to see just exactly how the Soma forks come out, i.e., axle-to-crown, offset, brake type, etc. I could really use one (or more) with 1" steerers too. Even another 20mm of offset would still be marginal for me with the CC, though bearable. Another 10mm or so of top tube length would make me happy...
    BTW, apparently Salsa are meant to be releasing details of their 2014 stuff from July 22, and since Surly are also part of QBP they will probably do something similar. No doubt all will be revealed on the Surly blog in the next few weeks.
    Most Delicious
    Reputation: dr.welby's Avatar
    Quote Originally Posted by dfltroll View Post
    Looks like something we were tossing around on the Kogswell list - a vertical dropout (for easy fender compatibility) with the option to use it as a horizontal:
    <a href="http://www.flickr.com/photos/drwelby/4149855411/" title="Dropout V3 by drwelby, on Flickr"><img src="http://farm3.staticflickr.com/2801/4149855411_e5e78aefa5.jpg" width="500" height="341" alt="Dropout V3"></a>
    Apr 2013
    Disc CC
    [PHP[/PHP]
    word
    Quote Originally Posted by jesusburger View Post
    Hmmmm
    Not sure if these are the same or two different bikes?
    Safe riding,
    Vik
    www.vikapproved.com
    Reputation: vaultbrad's Avatar
    Oct 2007
    They look the same to me after cursory examination of grainy interweb pictures via portable technology rectangle. At least the forks and rear rack braze-ons are the same.
    Love the new colour. Loved the Krampus colour as well. What happened to Surly with all these flash powdercoat jobs?
    Safe riding,
    Vik
    www.vikapproved.com
    May 2012
    surly ecr?
    SS in CO
    Reputation: Jayson44's Avatar
    Aug 2005
    my friend and owner of my LBS is in Ogden right now...he keeps posting pics of it:
    J.
    are you a bike shop owner? or a custom builder? I want to talk to you about your website
    Reputation: Nakedbabytoes's Avatar
    The dropouts sortof look similar to the ones that were on my Casseroll but without the tuggnut screws. It was nice for adjustability and options. This frame looks a lot like a CC or Casseroll or Fargo for geo and usage, so is it like that with disks?
    Wonder what the clearances are? I went with a KM since the Cass I briefly owned didn't have the tire clearance in wet gravel I was hoping for. I was even gonna paint it sparkle purple, lol!
    2014 Big Dummy
    2015 Salsa Beargrease Carbon 1
    2015 Ice Cream Truck
    Quote Originally Posted by boogman View Post
    surly ecr?
    Saw picture of it, now I want it.
    Jason
    May 2012
    I don't get it.. is it just a krampus with more holes drilled into the frame?
    It's a 29+ Ogre!
    Jason
    Want a Straggler! Pretty excited about that, hope the release is soonish.
    Have also been comparing the Ogre and Krampus together trying to decide on one and looks like the ECR gets rid of that dilemma!
    Oct 2007
    What does ECR stand for. I guess they couldnt call it the Krogre. Though, with all the braze-ons it could be racked to carry plenty of groceries.
    Team Captain
    enduro camp race
    Krogre! Love it!
    Quote Originally Posted by vaultbrad View Post
    I'm guessing Eric's Camping Rig. Named for Eric, aka Sov at Surly.
    Jason
    ECR=Extreme Camping Rig?
    I don't need one but sure do like it. I'm a bit more excited about the Straggler than I thought I would be. Or maybe it's just the 700x41 Knards.
    Sep 2012
    In Guitar Ted's blog post, here, he referred to it as 'enduro-camping-race'. Though I don't know if that's the official word, that man does always have the info.
    As a Fargonaut who looks longingly at Krampi, the ECR is pretty dreamy to me. The big ol' tires of the Krampus, but with more braze-ons for adventuring, it's pretty rad in my eyes. I might try to get my hands on some of those 700x41 Knards myself.
    never summer
    Reputation: singlefin's Avatar
    Quote Originally Posted by SocratesDiedTrolling View Post
    If I could divide my Fargo into two bikes I would end up with the ECR and a Warbird Ti....ok, back to reality....definitely interested in the new tire offering, and if Surly has a new handlebar.
    edit: guess its the Jones loop bar
    Fargo Ti + Moonlander + Necro Pug + Nature Boy
    Oct 2011
    Quote Originally Posted by dr.welby View Post
    I like this. I just had a frameset built up and my biggest complaint about it is the forward facing dropouts. I much prefer verticals but it's nice to have the SS option of forward facing so this theoretical dropout would be something I would be interested in.
    Most Delicious
    Quote Originally Posted by corwin1968 View Post
    Thanks! Now that there's been better pictures I can see that it doesn't have that extra 'nook'. It looks more like an earlier version I came up with, where you could 'lock out' the horizontal and turn it into a vertical by adding a chainring bolt into the little recess where the horizontal part of the slot starts:
    <a href="http://www.flickr.com/photos/drwelby/4149618854/" title="Dropout V2 by drwelby, on Flickr"><img src="http://farm3.staticflickr.com/2686/4149618854_bb6582d4d4.jpg" width="500" height="341" alt="Dropout V2"></a>
    I like the original version of this dropout better than what Surly came up with. The notch would allow easy "vertical style" dropout use, but the angle of the dropout would allow better wheel retention and better brake adjustment when sliding the wheel around for manual gear changes.
    Apr 2013
    Comotion Pangea Rohloff
    Quote Originally Posted by seat_boy View Post
    If you haven't seen Comotion's bikes you may want to give them a look as well.
    Co-Motion Pangea Rohloff
    Apr 2013
    Bigfoot
    Quote Originally Posted by Spinymouse View Post
    I thought it was just my big feet, but after 10+ years of thrashing my CC I can report the only time I'm aware of the foot bang is when I'm at a stop with my pedaling foot in the 3 o'clock position. That said, I'd also vote for the longer top tube.
    Feb 2005
    ^ When I got the CC it was to build it up as a fixed gear commuter, but there are quite a few extremely tight turns where the overlap is extremely annoying, and with fenders it is much worse; it's also annoying when doing a track stand. The low trail fork (if/when this appears) might help, but I'd personally be happy if the top tube was 1-2cm longer...
    I posted this in the Salsa Fargo thread also. I just recently picked up a lightly used Generation 1 Fargo that I was thinking about trading in for a Surly ECR and I was wondering what your thoughts were. I like simplicity not suspension, so I like how the Gen 1 Fargo is specifically built non suspension corrected. But I would like to be able to run 29+ tires. I don't think that I could justify having them both. Would I be making a mistake by getting rid of this classic bike?
    never summer
    Quote Originally Posted by smporter View Post
    If it makes $ense do both. Run some good touring tires like Marathon Supreme or Mondials on the Gen 1 Fargo and have the ECR do the 29+ duty.
    It is a bit of overlap though. If pavement isn't where your Fargo goes maybe its a good switch. For me the the Fargo serves many purposes and I couldn't give it up with out a comfy bike to ride distance and back roads.
    Feb 2005
    ^ Agreed.
    Also, it's entirely possible that the 29x2.75" Dirt Wizard might fit on the front of the g1 Fargo with ~3mm or so clearance. The Knard would almost fit but not quite, although it might clear by 1mm - not enough for me to buy one to see. No chance at the rear though.
    It'll be interesting to see the geometry for the ECR and some details for the other new Surly stuff.
  1. 2014 Surly Pugsley & Moonlander colors
    By nitrousjunky in forum Fat bikes
    Last Post: 09-30-2013, 08:17 AM
  2. Replies: 19
    Last Post: 06-04-2013, 09:47 AM
  3. Specialized 2013 Mountain Bike lineup
    By MessagefromTate in forum XC Racing and Training
    Last Post: 07-16-2012, 04:46 PM
  4. Replies: 0
    Last Post: 01-21-2011, 08:17 AM
  5. New bike in the SC lineup.
    By unoveloce in forum 29er Bikes
    Last Post: 01-07-2011, 03:35 PM
