Results 1 to 5 of 5
    Nov 2008
    700c clearance in 26" Disc Trucker fork?
    For those of you with 26" Disc Truckers (or 26" LHT's), would you do me a favor?
    I'm interested in how much clearance the fork has with a 700x32 tire (preferably a Pasela), measured from the top of the tire to the bottom of the fork crown. A picture or two would be golden!
    I'd like to put a 26" Disc Trucker fork on my Steamroller. Both forks have the same axle-to-crown distance, so the geometry stays the same. Ideally I'd like to run a 32mm Pasela and fenders, but it could be tight.
    Many thanks!!
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    How about a 650B?
    A garage full of steel frames means happiness.
    Well, I don't have a Disc Trucker, but I do have 32mm Paselas mounted on my Cross Check. So I measured the height of the tire with my calipers and came up with 29mm. The tire plus the rim, Mavic MA-3, is 47mm. Don't know how the MA-3's measure up against your rims, but seem "normal" sized enough to me. So a little beer math...700c wheel is actually 622mm in diameter or 311mm in radius. 311 radius + 47 tire/rim height = 358mm total wheel/tire combo radius. DT fork ATC is 376mm. So, you should clear it by not quite a couple cm. ...in theory, at least. ...unless you have a crazy tall rim. Width-wise, my Paselas measure 32mm right on the nose (and that's with probably 70 psi or so, because I haven't aired them up in a few weeks) Surly doesn't list the width of the fork, but my Mark 1 Eyeball says it should fit, even though the fork tapers a bit near the crown. So, how's that for a WAG? Don't think its quite enough info to make a purchasing decision, but helpful a little anyway I hope.
    Quote Originally Posted by keevohn View Post
    Many thanks!!
    The rake is dramatically different between the forks. Not sure how that will effect handling.
    Nov 2008
    bolandjd -
    That's helpful, thanks! It didn't occur to me to just measure the height of my Pasela + Delgado Cross combo... duh! Although your measurements don't account for the thickness of the fork crown, 20mm+ between the top of the tire and the crown race should be ample.
    Saddle Up -
    You're absolutely right about the rake. I've found that the handling feels a little sluggish with the stock 38mm fork and 32mm tires. 45mm rake would sharpen things up nicely!
