Results 1 to 7 of 7
    50t clearance on Cross Check?
    I am thinking about turning my CrossCheck into a fixed gear for the winter, too mix it up!
    I have a FSA 50/34 crankset (43.5mm chainline).
    If I want the chainline to work out, I will need to put the 50t where the inner ring currently is (making the chainline about 41mm).
    Will a 50t clear the chainstay? (sorry I can't test this myself, since I don't have the chainring tool yet)
    Reputation: ianick's Avatar
    From the Surly website:
    Chainring clearance- Manipulated stays so you can fit the size rings you want. Go nuts
    Sep 2012
    <<Chainring clearance- Manipulated stays so you can fit the size rings you want. Go nuts>>
    I'm sorry, I'm not that familiar with frame nomenclature, what does that mean?
    Yes!
    a 50t will fit a CrossCheck...
    P
    Quote Originally Posted by patirwin View Post
    On the inner ring location? I know Surly's site says 'go nuts' but there's practical limits to this.
    Quote Originally Posted by allroy71 View Post
    Why don't you
    1) measure the distance between the chainrings (not just the gap, but the gap + the thickness of one chainring)
    2) mount the crank with the 34 and 50 rings on it
    3) measure the gap between the 50t chainring and the chainstay
    4) If the measurement from 1 is less than the measurement from 3 then you're good
    What cog would you use w/ the 50t chainring? Can you get the same ratio w/ the 34t chainring and a different cog? For winter use I am thinking you would not want that high a ratio to require the 50t ring.
    Reputation: riiz's Avatar
    The 50t does fit at the inner position of a compact dual-ring crankset.
  1. Replies: 12
    Last Post: 03-11-2010, 09:52 AM
  2. Single Speed Cross Check build (cross post)
    By yurtinus in forum Surly
    Last Post: 03-10-2010, 12:09 AM
  3. Replies: 1
    Last Post: 08-14-2009, 03:37 PM
  4. Replies: 14
    Last Post: 08-14-2009, 02:30 PM
  5. Heal clearance on Cross Check?
    By Structure in forum Surly
    Last Post: 10-12-2006, 08:32 AM
