Results 1 to 8 of 8
    2008 Karate Monkey build
    Just picked up a mint 2008 Karate Monkey 18" frame and fork, did an even trade for my 2009 Stumpjumper Comp 29er frame. Now I've got to swap over all of the components, many upgraded, to complete the KM. Should be finished by next week.
    #THELEGEND
    Reputation: Guy.Ford's Avatar
    Schweet, cant wait to see the finished product, keep up posted and congrats. Im building up a KM currently, just waiting on the last few pieces, tires and wheels, cant wait.
    #THELEGEND
    2016 RSD Mayor
    2017 Diamondback Haanjo Trail (Alu)
    Here is the build list... now to just change everything over. Itching!
    Surly Karate Monkey 4130 CroMoly Steel Frame in Gloss Black (18”)
    Surly Karate Monkey 4130 CroMoly Steel Fork in Gloss Black
    Cane Creek S3 Threadless Headset (1-1/8", sealed bearing)
    Thomson Elite X4 Stem (110x31.8mm/0º rise)
    Easton EA70 Monkey Bar Low Rise Handlebar (685x31.8mm/8º bend/4º upsweep)
    SRAM X-9 Front & Rear Trigger Shifters
    Avid Elixir CR Front & Rear Brake Levers
    Avid Matchmaker Brake Lever & Trigger Shifter Clamps
    Ergon GX1 Leichtbau Grips
    Avid Elixir CR Front & Rear Hydraulic Disc Brakes w/160mm Rotors
    Shimano SLX M660 Front Derailleur (w/Shimano shim)
    SRAM X-9 Rear Derailleur
    Shimano Deore Hollowtech 2 FC-M542 Crankset (175mm)
    Shimano FC-M542 Hollowtech Bottom Bracket
    Shimano M520 Clipless Pedals
    Shimano SLX HG61 Cassette (9-speed, 11-34t)
    SRAM PC-971 Chain w/Power Link
    Thomson Elite Seatpost (27.2x410mm)
    Thomson Seatpost Clamp (30.0mm)
    Specialized Phenom Saddle w/Hollow Cr-Mo Rails
    DT Swiss X470 29" Rims
    DT Swiss 1.8mm SS Spokes w/alloy nipples
    Specialized Hi Lo Disc Front Hub (sealed cartridge bearing)
    DT Swiss RWS 9mm Quick Release (front)
    Shimano M525 SL Rear Hub
    Shimano SLX Quick Release Skewer (rear)
    WTB Weirwolf LT 29x2.55" Front & Rear Tires
    King Cage Stainless Steel Bottle Cage
    Ahearne Cycles Stainless Steel Flask Holster Cage
    Here she is.
    Just need a Thomson seatpost clamp (I'm picky) and the project is complete.
    I may also remove the white Surly sticker and go black on black like I did with my Cross Check. Haven't decided yet. Merely aesthetic.
    But the main issue I'm having.....
    - I can't seem to get the rear wheel correct, didn't tighten up the skewer enough the first time I took it for a test drive and the wheel popped out. No big deal, was just doing 1mph around a lot, and the wheel stayed within the dropouts. Now I did my best to place the wheel centered in the dropouts evenly and tightened up the rear skewer nice and firm, but can't seem to get it perfect... the tire either rubs the FD, or is too far away from it, or too left or too right (on the stays). Any suggestions?
    Reputation: fourthree's Avatar
    Dec 2010
    Monkey nuts. They are essentially spacers that go in the front part of the dropouts to remedy the problem you describe. They came with the frame when I bought mine.
    See the article at surlybikes.com, click on "The Information Hole" and then "Karate Monkey and Front Derailleurs". (I don't have enough posts here yet to post a link.) Runnning a rear derailleur, I'd want the axle all the way forward in the dropout. If that causes FD interference, either the tire or FD can be changed, or Monkey Nuts can be used to locate the wheel more rearward.
    Excellent, thanks for the help. Biking over in a few minutes to pick up a pair my LBS has in stock.
    Some more photos of the build.
  1. Karate Monkey Build + Rohloff
    By brettsportler in forum Surly
    Last Post: 09-11-2009, 01:14 PM
  2. Karate Monkey Build
    By migmi in forum Surly
    Last Post: 08-03-2009, 05:27 PM
  3. Help me build my Karate Monkey Please!
    By Burrito Eater in forum 29er Bikes
    Last Post: 02-28-2007, 07:06 PM
  4. Karate Monkey SS Build
    By mtb_biker in forum Singlespeed
    Last Post: 05-17-2005, 05:23 AM
  5. What did it cost to build your Karate Monkey?
    By Threesticks in forum Singlespeed
    Last Post: 10-25-2004, 10:24 AM
