Results 1 to 5 of 5
    1x1 gazzaloddi 3.0 and brakes
    yo.
    so i know that the gazzaloddi 3.0s just barely fit in the 1x1. i was wondering if anyone knows if you can clear the tire with a cantilever or v-brake. i'd prefer not to do discs for...well, we should get into why.
    anyone know?
    Dec 2005
    I'm not sure about Vs but I'm sure you could get a straddle wire long enough to clear with canti's. Someone suggested such a solution for a Pugsley with the Endomorphs. Still with the kind of traction you will get with a Gazzaloddi 3.0 I would think discs are the way to go. You obviously aren't worried about weight.
    Craig
    I believe you have to cut off the V-brake posts to fit the 3.0 tires.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by tedsti
    No, though you might need to partly deflate the tire to get it past the bosses.
    mtbtires.com
    thanks all.
    if i try this, it'll be with cantis, and probably the wide salsa cable hangers.
    i'm just a canti kinda guy. this would be for wintertime trail riding, nothing crazy.
