Results 1 to 25 of 25
    Feb 2012
    XX1 jumping cogs when back pedaling
    Please any help or advice on this.
    Just had XX1 put on 2012 Stumpjumper expert carbon 29er. When i back pedal it jumps from the 10 cog to the 12 cog. I am using a grip shift and it runs up and down the cassette no problems when forward pedaling.
    Everything looks in line out the back.
    Also having same problem on friends S Works enduro with XX1.
    Do i need to adjust Derailleur screws.
    Mine did this a couple of times - I'm wondering if it has something to do with the clutch? I had my mechanic do the entire build and check everything for ea race (he also works for us at the races). Setup is spot on as far as I can tell - but noises and this issue makes me wonder if that tension bolt is too tight?
    142+ rear end ? I hear there is a special adaptor you need from specialized. Maybe?
    Reputation: bikeguy0's Avatar
    Same problem here. Mine only does it when in the 42. All other gears I can back pedal fine without it going down the cassette.
    My Team: Feedback Sports Racing
    Update: I was doing some service on the bike last night. The chain derails off the front of the cassette due to the extreme chain line when I am in the 42. When pedaling forward the rear derailleur holds the chain on the cassette but not when back pedaling.
    I adjusted the high limit screw to allow the chain to be closer to the spokes but that doesn't do squat since it is an issue from the front of the cassette. I'm not sure there is anything that can be done to address this. I guess just don't back pedal in the 42.
    ban
    ban is online now
    mine does the same in the 42 cog....but I'd prefer it wouldn't do that in fact, let's see if someone has found out a solution to this
    Jun 2013
    Mine also jumps from 10 to 12 on back pedal. I've checked and marked the tooth, only happen on 1 particular tooth on my 10 cog. Asked the local distributor, and they blamed on stiff chain links (even though its brand new). Still no solution...
    Reputation: rcjonessnp175's Avatar
    Aug 2010
    Mine also jumps gears pedaling backwards in the 42 toother. Also on a stumpy evo with 142+
    Mar 2006
    I just viewed this thread and try to put mine in 42T back and pedaled backward also, after almost 2 crank rotations it jumped to the next lower sprocket, I will try to know why...mine is a Ibis HD 160
    JNG
    JNG is offline
    Oct 2011
    Mine jumps from the 10 tooth to 12 tooth cog when back pedaling. I added a washer between the derailleur and the hanger/dropout so I could adjust the high gear limit screw farther - more outboard. The jockey wheel should be lined up with the outer edge of the 10 tooth cog and I couldn't do that without the 1.6mm stainless washer that I added. After I was able to adjust it properly it still jumps or tries to jump occasionally while on the bike stand - maybe ever 4 or 5 complete revolutions of the chain. But while riding it (full suspension) it seems to run smoothly. Something about the slightly compressed suspension while sitting on it seems to have made a difference.
    Reputation: Epic_Dude's Avatar
    May 2010
    My XX1 setup runs fine in every gear going forward, however like others have posted, when in the 42T cog and I back pedal on the stand it will jump down a cog or two. No problem when in the 10T cog when pedaling backward. Must be a function of the chain line and the narrow stackup of the cogs. Since it doesn't cause any issues while riding I would write it off as a non-issue and just enjoy my 1x11 setup.
    Any updates on this issue?
    We Ride In God's Country!
    So I just learned to deal with it. The only time it becomes a problem is when I f up a steep section and have to back pedal to get the cranks in the right position to restart. What I usually do is just downshift one cog and that will put the derailleur in the right place for where the chain dropped to.
    Hope that helps.
    Oddly enough, nearly a year later and numerous 24hr solo & other endurance events (and all the saddle time to prepare for them) and the issues is either non existent or I don't notice it anymore.
    I will say that sometime last year (Jul or Aug?), SRAM warrantied my rear derailleur and my awesome shop mechanic has kept the bike running through all the racing and training - I've already been through 3 chains just to give you an idea of the hours.
    Feb 2010
    bikeguy... have you tried to double shift up 2 gears? If you can't...then it's probably your problem. The b-tension is set too high... you need to make sure the jockey pulley is set low enough to clear 2 gears up. On the 42T cog...it's really big...so you have to set the b screw to be low enough to clear the 42T cog. The other thing is to play with the shifter tension on the handlebar and go both directions until you don't hear any noise from both directions...
    this is of course you had set your H and L screw correctly.
    Reputation: giantdefy's Avatar
    Jun 2010
    I don't have an xx1 but I've had bikes where the chain would skip when pedaled backwards. The fix was to adjust the B-tension screw.
    Reputation: engrmariano's Avatar
    hi guys, what size are your chainrings?
    a friend was using 30t with no issues. then when he moved to 34t, the same issue came out but only in 42t and some ghost shifting when mashing the pedal.
    my initial adjustment was to set the suggested 42t-to-jokey distance (12-16mm). the ghost shifting improved, just needs a little barrel adjustment.
    PIVOT
    Mar 2006
    This happen to me but sometimes just because need some lub on the chain and only in 42T. today I just was riding and when see the chainline with my 32 chaining and the 42T rear, it looks like is too bent from out in the chainring, it make when I pedal backwards the chain try to self-aligning jumping to the 36T, I just got the recommended spacers in my BB. I will experiment removing the 2.5mm spa error from the drive side and place just one of 1.5mm or 1mm to see if still jumps. I will keep updating.
    Apr 2014
    Any sollution to this?.. Mine happens when in 42T, which is really annoying, if only I could "move" the problem to the 10T Cog, i would be quite happy. Perhaps the spacer sollution mentioned in previous post could do just that?
    This happens on both of my xx1 bikes on 42 cog only. I don't see it as a problem because I never back pedal while climbing a steep hill or mountain.
    18 Focus Raven Lite
    17 Focus o1e
    17 Yeti ASR-cT
    16 Bianchi Specialissima
    15 Echo Big Deal
    Apr 2014
    Well i dont back pedal when i am moving, but if the mountain is too steep or technical and I stop midway, I need to to get the pedal in the right place to start again, and this happen multiple times when I ride. I live in Norway and the terrain is quite technical I would say.
    Sep 2014
    30tooth front for me. Only occurs in 42 cog. If I back pedal slowly it will grudgingly stays put (lots of noise and crunching). If I back pedal fast it drops down 3 cogs. The ONLY time I notice this is on the bike stand. It's never been an issue while riding. Of course if I'm in need of the 42 cog I've got other stuff on my mind and likely a pounding heart to distract me.
    Oct 2013
    30T up front on my Sight and same problem with my 42T while backpedaling. Anyone with any fixes?
    Nov 2013
    I have a 32 oval up front on my XX1. Not only does the chain fall down off the 42T on back pedaling but it also does it when your just pushing the bike backwards...for example in the garage. It did this with a 28 T and also 30T so I don't think it has anything to do with whats up front. My girlfriend's X1 (also on a Bronson) does not do this at all. B screw adjustment (12mm-15mm) seems perfect, for shifting anyway. Nice n crisp. Come on SRAM help us out a bit.
    Reputation: Rockrover's Avatar
    IMO, it's all about the chain line and tooth design on the cassette. I had the same issues, until I put a GXP direct mount sprocket on the front. The GXP moved the chain line inboard -6mm. Now I can back-pedal all day in the 42t and no issues (not that I ever did anyway).
    I ride an Enduro 29 and I was okay with stay clearance with a 26t and should be okay with a 28t sprocket, however a GXP 30t would not clear the stay...Other chain stay designs (narrower) probably could, but your results may vary.
    Santa Fe, NM
  1. Back Pedaling Issue
    By ronyc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-12-2012, 02:36 AM
  2. Big-big +2 link chain setup & issue w/back pedaling
    By awai04 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-09-2012, 11:19 AM
  3. I9 SS hub, how many cogs can you fit on it?
    By Fulton in forum Singlespeed
    Last Post: 12-15-2011, 04:08 PM
  4. Chain jumping when pedaling
    By madjuly in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-02-2011, 01:34 PM
  5. Which cogs to buy
    By dw67 in forum Singlespeed
    Last Post: 02-28-2011, 07:43 PM
