Results 1 to 3 of 3
    Aug 2010
    XX1 derailleur installation question
    The XX1 derailleur comes with a plastic piece installed. Should this be left installed when installing the cable to get the proper cable tension, or is it just there for shipping?
    I searched the SRAM website for an XX1 derailleur user manual, and they don't seem to have one specifically for XX1. There is a service manual, but it only shows how to attach the derailleur to the bike, not how to set it up.
    ban
    ban is online now
    I've removed it from the 2 XX1 derailleurs I have installed so far w/o any issue in the installation, I think it's just there for shipping
    Feb 2010
    The plastic piece is to stop the pulley cage from colliding into the shifter guide. If you adjust the H screw so it moves the cage away then the plastic piece can be move and you can install and adjust as normal. If you have 135mm frame bike which is the problem I have... you will need to get a new hanger with 3.5mm more meat on it to offset the derailleur so you can use the 10T cog... For 142mm frames no issues once H screw is adjusted to 10T cog.
  1. S3 direct mount front derailleur installation
    By erichwic in forum Specialized
    Last Post: 05-27-2015, 11:33 PM
  2. New Rear Derailleur Installation - Binding and stretching in low gear
    By S0RRY in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-09-2013, 10:03 AM
  3. MRP XCG installation question
    By mast3rof0 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-23-2013, 06:05 PM
  4. Brake installation question
    By Camber11 in forum Brake Time
    Last Post: 10-15-2012, 06:00 PM
  5. New Fork installation question
    By lnc0321 in forum Beginner's Corner
    Last Post: 11-02-2011, 08:21 PM
