Results 1 to 9 of 9
    k^2
    k^2 is offline
    Flamingo
    xx1 Crankset Price ?
    Does XX1 crankset come with the chain ring already, or that one has to be bought separately?
    Most places advertise it around $285. Competitive Cyclists lists it for $285 and it says that it comes with 32 teeth chain ring. However I called a local bike shop and they said that for $285 I will only get the crank. The chain rings have to be bought separately.
    Any experiences out there? I am in process of building a hardtail 29' and I am debating between 1x10 or 2x10.
    Aug 2010
    That's a lot cheaper than I expected, considering that X0, XX, and XTR cranksets are usually $400+.
    Reputation: limba's Avatar
    It should come with a 32 ring. There's at least two guys riding xx1 on this site right now and a few more have ordered it. You'll see reviews coming in soon.
    Warrior's Society
    Reputation: mtnbikej's Avatar
    Sep 2001
    Per BTI:
    https://www.bti-usa.com/public/item/GS2570
    BTI part #: GS-2570
    vendor part #: 00.6118.054.000
    UPC: 710845713248
    speed: 1x9-11
    BCD (ring): 76mm (32)
    interface: GXP*
    length: 170mm
    Q-factor: 156mm
    color: carbon/grey
    Carbon fiber arms mated to a forged aluminum spider with insert-molded aluminum pedal and spindle-interface reinforcements
    Narrow (156mm) or wide (168mm) Q-factor and offered in either drive-side integrated GXP (24mm) or non-drive integrated BB30 (30mm) bottom bracket spindle
    *GXP (Giga X Pipe) cartridge bearing bottom bracket set sold separately: available in 68/73mm threaded or BB92 Press-Fit (either BlackBox ceramic or Team steel bearings)
    *BB30 cartridge bearing bottom bracket set sold separately: available in BB30 or PF30 (either BlackBox ceramic or Team steel bearings)
    X-Sync chainring tooth profile alternates wider, x-shaped teeth with narrow teeth mirroring the chain's internal dimensions to provide optimized chain control (optional, even-size rings available separate from stock 32T offering)
    4-arm 1x9-11sp, 6mm hard-anodized aluminum chainring with optimized X-Sync profiling, alloy Torx chainring bolts, alloy M10/M15 self-extractor crank/spindle bolt, and pedal washers
    710g (GXP) / 650g (BB30)
    I crashed hard enough on my Tallboy to break my leg,
    The carbon is way more durable than most people.
    metrotuned WoS
    Reputation: illnacord's Avatar
    jabrabu: The reason the pricing is lower than typical cranks is due to the single chainring. Essentially a single speed crankset versus the comparisons of high-end double/triple cranksets. If SRAM charged any more than $285 retail for the ss crank, it'd be hard to swallow.
    k2: The LBS is misinformed, the crankset comes with one ring.
    Let's just hope the 11/27 - 11/30 release is true.
    Norðwegr
    Reputation: Vegard's Avatar
    Chainreaction has a few items in stock already, holding off until I can get everything in one go, I can't wait!
    Reputation: CoppellStereo's Avatar
    The crankset retails $285 for GXP and $325 for BB30, whcih both include a 32t chainring. The cassette retails $425
    Reputation: skyak's Avatar
    GXP = 710g, BB30 = 650g
    Are these weights including the pressfit BB? What makes BB30 lighter? Why do frame makers make GXP spec'd frames?
    Reputation: Calhoun's Avatar
    Nov 2008
    Quote Originally Posted by illnacord View Post
    It does seem cheap though considering the DH XO crankset is SS and has a MSRP of $444
    Bandoleros Crew, NM
Hot Deals
Contests
Latest Mountain Bike Articles
